Question about Babybjoern Baby Sitter 1-2-3
Where do you put the water to heat the bottle
    Problem Solver:
  • 13 Answers
In a bowl or pitcher or something... any container that will allow you to cover most of the bottle in water.
Posted on Nov 14, 2009
Is it safe to drink bottled water that was left in a car?
That depends on whether the water is the original water which came in the sealed bottle, how long its been in there, how hot it has become and how many times it's been heated. If you left it overnight and it didn't heat up, it's probably OK. If it's been in a hot closed up car all day, pitch it. Another mistake is to reuse the bottle, adding tap water repeatedly and never washing the bottle, allowing germs to grow and grow. Don't do it.
Jul 16, 2017 | Wine & Spirits
Tip
Bottled water appliance precautions
Hey Culligan Man!
My family has enjoyed the convenience and health benefits of drinking bottled water for several years. We have used a drinking appliance where the bottled is upturned and the water is gravity-fed. The water is then heated and cooled and served from hot and cold spigots. (I've seen other types of dispensers when the bottle goes upright inside the cabinet and is pumped into the water pitcher.)
The heated water quit working recently but the refrigerated part was OK. After noting how some members of my family used the dispenser, I have solved the problem. It is caused by the water level running too low in the mini water heater causing the element to burn out. Low water doesn't harm the mini-frig part. Low water levels are caused by using the bottle past empty and continuing to take water until it almost stops coming out. This "starves" the water heater, consequently burning out the element! Always replace the bottle on top before it gets past empty! If it gurgles considerably, it's filling up a nearly empty water tank probably with a burned-out element.
Maybe manufacturers can address this problem of too low water levels in subsequent models.
Regards,
Bob K.
on Feb 28, 2010 | Kitchen Appliances - Others
Do drano, water, n foil in plastic bottle make the bottle explosive?
We used MRE heaters in the army, busted up a few, put them in with some water, capped. The heat and vapors would start boiling, and pop! It was loud and probably as big as what your looking for.
Apr 24, 2016 | Miscellaneous
Is freezing water in a plastic bottle harmful to your health?
Yes, but not as harmful as heating water in a plastic bottle.
Aug 29, 2014 | Refrigerators
Water reserve bottle is emptying and engine is getting how
flushing a radiator is a waste of time and money as blocked cores do not flush. Have a pressure test done on the coolant system and check for external leaks. have a compression test done to check for head gasket and cracked head. Have a flow test done on the radiator and if shows signs of blockage replace the radiator .. Always fill the radiator at the radiator cap and not the reserve bottle. The reserve bottle water will not go down until the engine coolant starts to cool so if it is going down when the engine is hot then you have a bad leak in the reservoir bottle.
Jan 07, 2014 | 2000 Oldsmobile Intrigue
Refilling cooling system
before doing so put a radiator flush in the expansion bottle.ran the car for about 20 miles then drain it.refill with 50/50 anti freeze mix.put your heating on full to bleed out the air .ran the engine till water getting hot .then refit the expanion bottle cap.
Dec 15, 2013 | Cars & Trucks
Car blows out cold air but steam out the bottle
I would install a new thermostat. The only way to check a thermostat is to heat it up in a pot of water on the stove and make sure it opens and closes. Make sure it's in the right way, and make sure the radiator is full. You may have to loosen a heater hose to get the air out of the system. I usually let them warm up with the cap off to make sure it's all "burped" out. Once you have everything full if it still overheats, you may have a water pump problem. Squeeze your rad hose right shut if you can. When you release it, you should feel a gush of coolant go through it. If you don't, your water pump may be no good, and will have to be replaced.
Jan 17, 2013 | Cars & Trucks
3 months ago i changed to a new radiator after going trough water bottle after water bottle.Things were fine.Now im over heating again with the problem being the pressure cap of the water bottle apparently...
There is no water bottle
All vehicles have a coolant recovery container
When the vehicle warms up ,some coolant goes
past the radiator cap into it
At night when cool, the radiator draws back what
it needs
Been that way for 50 years
That container isn't under pressure as you can see
You have to diagnose the engine overheating issue
You have a new radiator,I would assume new thermostat
& rad cap,so continue on
It is very old, so a head gasket wouldn't be a supprise
Aug 02, 2011 | 1990 Jeep Cherokee Limited
'clunking' sound
Yes, try removing the cat you ran over last week.
Actually, the clunking could be several things. First, check to make sure that the nuts holding the wheels on are very tight. If they are pneumatic, check the tire pressure to see if it is at the proper level. If they are flat-free, these tires won't have valve stems and have a semi-solid core instead of a tube. Chairs that sit in one place over a period of time will develop a flat spot on the tires. Usually, if it hasn't been too long, they will go away with driving and or warm weather and driving, otherwise, you need to replace the offending tire or buy some earplugs.
Sep 28, 2009 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
How much soap and how much water do I put in the Bissell pro heat?
You are supposed to buy the Bissell soap. On the bottle depending which cleaner you need. The directions are on the bottle. Please do not use house hold cleaners because you can cause serious damage to the vacuum.
Go here, this pg. shows the 7901-1 click the user guide pdf & print the instruction if you choose:
http://www.bissell.com/Bottom_Menu/Product_Search.aspx?Criteria=7901-1+ProHeat+
Good cleaning!
Please vote..........
Jan 16, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Babybjoern Baby Sitter 1-2-3 Logo
Top Babybjoern Baby Gear Experts
Dorel UK
Dorel UK
Are you a Babybjoern Baby Gear Expert? Answer questions, earn points and help others
