Question about Car Audio & Video
Rockford/fosgate RFX9020M Hi, I have this CD/radio/amp unit in my sailboat. If trhe battery is fully charged all is well. If the battery sits overnight, when the deck is turned on there is a chirp out of the speakers. It starts softly and builds quickly to a loud thump. This repeats about once a second and it doesn't matter if a CDis playing or the radio is on. The battery isn't discharged to the point where the inverter won't work etc. It is still in the 12.5 volt range. Nothing else would be connected or on at the some time as the deck is giving this problem. Any ideas? Thanks, Doug Brown - Georgian Bay Canada
SOURCE: Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Posted on Jul 09, 2007
KaeZoo
  • 156 Answers
SOURCE: rockford fosgate rfx-9200
If you're talking about the amplifier's power terminals, the positive terminal is designed to be wired directly to the battery (be sure to fuse the amp power wire near the battery terminal). The negative terminal should be bolted to vehicle chassis metal for a ground connection. The only amplifier connections that go to the back of the head unit are the remote turn-on wire and the RCA cables.
Posted on Aug 16, 2007
jrod1125420
  • 161 Answers
SOURCE: audio electrics
chances are if you got it from ebay there are going to be missin plugs for that unit.....and if i had to guess the two wires would be power (12v) n ground which should be red and black but differs on different cars.
Posted on Oct 01, 2008
yungdub
  • 93 Answers
SOURCE: Rockford fosgate amp keeps shutting down when volume is cranked
your cd player cant handle all the power, time to upgrade to a cd player with at least 80w10
Posted on Jun 14, 2009
  • 814 Answers
SOURCE: Magnavox CD Player Clock Radio not working
This Clock/Radio/CD player has had component failure problems. The unit is probably not worth repairing. The reason is the parts and repair information is probably very limited. The cost of the repair with parts and labor will be expensive. This repair would probably cost you more than just buying a new Clock/Radio/CD player. I hope this information helps you with your problem. Thank you for using FixYa and have a nice day!
Posted on Jun 15, 2009
Where is the fuse located on my p500 2 rockford fosgate amp
Internal or external? Those are protected externally as close to the battery as possible. Check the wire size and color at the amp and then go look for it at the battery under the hood. You should be able to see the installers additions. Inside the unit is another matter.
Feb 03, 2017 | Rockford Fosgate Car Audio & Video
Hello, My rockford fosgate in dash unit is not
Are your rear speakers smplified or ran directly off of the radio?
Jul 29, 2011 | Rockford Fosgate Stereo Audio+video Rca...
How to connect amp to stock radio in a 2002 volvo. hi low input.
You can buy a decent hi to low crossover box from any stereo shop, peripheral makes em, so does rockford fosgate, even scoshe at walmart. The new rockford fosgate 3 sixty is pretty neat but I don't know the price.
May 30, 2010 | Car Audio & Video
Rockford fosgate p 300-1 amp will not turn on
plug your ground, battery, and remote wires only and see if it turns on when you turn your radio on, if not it must have blown. wiggle or move the connection block(where your wires are connected) and see if it tries to turn on. if so, your leads need to be re-soldered since they tend to go cold(they're not making good contact). But again, if that does not help, then your amp is gone.
Mar 18, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Tel mute
The Tel Mute function is controlled by the pink wire in the loom. Make sure it is not connected to anything.
A capacitor inside the unit has also known to cause this problem when it goes bad. This will have to be repaired by a tech. but you can let them know to look for C719 or C711 (I think C711 is printed on the pcb) .
The manual can be downloaded from Rockford website.
Apr 27, 2009 | Rockford Fosgate RFX-9210 CD Player
I have a 2006 Nissan Xterra with a Rockford Fosgate
if is there a warped CD in the tray
pull the unit apart
or a major fail .. easiest fix is
source a used Rockford Fosgate 6 CD player that works
plug that in
ebay / inline or wrecker 2006 Nissan Xterra Rockford Fosgate AM FM Radio 6 Disc CD Player PN...
Mar 21, 2017 | Rockford Fosgate Car Audio & Video
Rockford and fostgate
i dont think different brands ar compatible as such.
Dec 01, 2008 | Rockford Fosgate RFX-8030 CD Changer
PROBLEM
press and hold the down or up button and it will switch to manual tune
Oct 20, 2007 | Rockford Fosgate RFX-9320 CD Player
Rockford fosgate rfx-9200
Aug 16, 2007 | Rockford Fosgate RFX-9200 CD Player
Car Audio & Video Logo
143 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
