Question about RCA F32715 32" TV
Need parts #u701=mt13001t
Need to buy parts for RCA TV F32715 CTC197CW
#U701=MT13001T
#U501=MC44864M
circuit integrators, channel selector
Cannot find these items for sale.
  • 647 Answers
There are a few IC's listed for U701 and U501 - Rca does not go by part # listed on the IC itself - give me a description of the IC's- that is what circuit their used in and what's their purpose and I'll give you the RCA part #
Posted on Oct 03, 2009
RCA tv TR29E26 standby goes dim as soon as I press channel button and an image flashes on screen for two seconds and goes off.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 19, 2016 | RCA Televison & Video
I have tv westinhouse not have channels
CHECK THE CONNECTOR INPUT SELECTOR CHANNEL THAT IS NOT DAMAGED CHECK THE CABLE CONNECTOR COAXIAL. AGAIN MAKE CHANNEL SCAN., BUT GET NO TUNE CHANNEL. SURE THAT OTHER VIDEO INPUTS., HDMI & USB OPERATING NORMALLY, IF THIS IS OK., MUST REPLACE CHANNEL SELECTOR OR LAST CASE NOT FIND REPLACEMENT., REPLACE THE MAIN BOARD., IN SOME CASES THE CHANNEL SELECTOR COMES AS PART OF THE PRINTED CIRCUIT., THEREFORE TO REPLACE THE MAIN BOARD.
Aug 20, 2014 | Westinghouse 46? 1080p Led Tv ld4680 /...
WHAT IS THE PART # FOR A S.M.P.S.U.ON A # F1310ATVD(STARLIGHT)
need to buy parts for RCA TV F32715 CTC197CW #U701=MT13001T #U501=MC44864M circuit integrators, channel selector Cannot find these items for
Nov 26, 2012 | Starlite F1310ATVD 13" TV
I have an RCA kitchen television. It just stopped responding. I get to cable using comcast and they suggested that I call you since they are getting a proper signal. The TV must be on channel 3 in order...
Hi
It seems that your TV's memory IC has damged. If this IC got damged, no fromt panel or remote signals will work. It is a small IC . It can be found very near to channel selector main IC [System control]. It is very cheap to buy. But replacing it is a skilled work. You have to contact any experienced service technician to get it replaced. This IC controls most of the functions in the Tv. OK.
Jul 22, 2011 | RCA Televison & Video
I connect the cable,it doesnt show anything!I try the auto channel search for both cable and antenna,it doesnt find any channel at all!it says-no signal..-rca 20inch sdtv truflat.dual combo with dvd player...
I assume you tried the cable on a working TV to make sure there is a signal on the cable line and that the cable terminal is OK. See if you can control the input selector and set it up for RF or TV reception. If OK, try to tune in channels manually or in auto mode. Do this in programming mode. If you notice any noise on the screen, this means the source selector circuit is OK. If there is no noise, the source selector may not be latched to the RF circuit output. Try to feel the terminal at the back of the TV set. If it feels like it moves when pressure is applied in various directions, chances are the solder connection for the terminal onto the circuit board may be faulty. Resoldering them would be easy for DIY enthusiasts. If it isn't the culprit, try the DVD. If it works fine, then the video circuits must be ok. The trouble could be from the video source selector circuit backwards to the RF block. Usually an IC senses the power condition of the DVD player. If it senses that the player is ON, the IC latches on the signal coming from the DVD player. See if there i a separate power button for the DVD. More later, please post a feedback
Aug 25, 2010 | RCA TruFlat 27F520T 27" TV
How much does it wiegh
The shipping weight is 131 pounds. This includes packaging.
http://www.amazon.com/RCA-F32715-32-TV/dp/B00005AK8A
Mar 04, 2010 | RCA F32715 32" TV
Panasonic surround sound system, cant play dvd/cd anymore, getting 'U701' error
Try one of the lazer cleaners from Wal-mart or Best buy.. Might help
Jun 16, 2009 | Panasonic Audio Players & Recorders
Acer A1916 does not power on
Try checking for a short between pins 2 and 3 on U406. I had the same problem on 3 monitors. I removed this component from 2 of them and replaced it on the 3rd and all three of them work now. I am unsure of this components purpose.
Andrew
Feb 12, 2009 | Acer AL1916B 19" LCD Monitor
Acess service mode rca ctc197cw
hold menu button in. push power button once. push vol up once.
Dec 02, 2008 | RCA F32450 32" TV
Ghost in the channel selector
the problems due to the microprocessor on the remote reciever present inside the tv .i think the remote is normal working. as the only problem with your iinfra red reciever microprocessor.microcontroler circuit. Replace the IC to solve this. Check electrolytic capacitor coupled to the memory block of the micro processor. Contact service if you are not well verse doing all this rectification works. it is off high risk and caution
thank you !
Nov 17, 2007 | RCA F36650 36" TV
RCA F32715 32" TV Logo
109 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
