Question about NEC Computers & Internet
Monitor gos on for 5 sec then turns off after showing a good pic then the green light blinks on & off withno pic
SOURCE: viewsonic problem
I RMA'd this probablem as well. They asked the usual questions -- try it alone, check the connections, are you using VGA or DVI... blah blah. Eventually they could give me an RMA.
They have customer support via phone on Sundays in the US, which is nice. Total time from calling to RMA was about 20 minutes.
Posted on Sep 14, 2008
  • 514 Answers
SOURCE: The light on the power switch turns green when the switch is pressed on, but soon after it turns amber and keeps blinking. Therefore there is no display on the monitor screen. The amber light keeps bl
make sure that all the cables are connected FULLY.
blinking light means that there is no signal.
Posted on Apr 15, 2009
  • 23 Answers
SOURCE: Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Posted on Aug 14, 2009
SOURCE: rapid green blinking green light on monitor and power & no video
try to acces the menu and to reset the display settings.
try another monitor on your computer to be sure that your video board is working, and if it is change the resolution in 1024X768 and try again your dell display
Posted on Oct 27, 2009
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Tv truns on then turns off
if model indicated do the self check it has:
On front of set when green light for power goes out press and hold both the menu and input (source) buttons at the same time for at least 5 seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks a pause and repeat it for a total of 5 times.
If set has been unplugged you must plug it back and try to get set to turn on--unplugging clears the errors.
Let me know what error you find and I will tell you what it means.
Apr 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Monitor gos black turn off then back on video stays on 15 sec then off again
Hello
It could be a bad monitor or videocard ,the only way to test this is by connecting another monitor to that PC or your monitor to another PC.
Good Luck
Feb 13, 2012 | HP Computers & Internet
PDP 5030 blinking red light on monitor
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Jun 07, 2017 | Pioneer PureVision PDP-5030HD 50 in....
Green Power light blinks for about 60 secs, then
YES New lamp needed the model number will be on old one does not take long to change if still got hand book shows how change
Nov 07, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
May 18, 2009 | Sony KV-36FV26 TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
Feb 04, 2009 | Envision EN-7100e 17" Flat Panel LCD...
How do I connect my HBH-608 head set?
just turn on bluetooth in ur mobile and then turn on ur bluetooth headset by holding the power button for atleast 5 sec and if blinking green light show up it means that it is turned on,if it shows blinking red and green then it is ready to get paired with ur mobile phone so u can straight away connect the bluetooth by selecting handsfree and new device and in the list of divices select hbh608 and get it paired.if it shows a blinking green then hold the volume increase and decrease button at the same time for 5 sec and then the light turns blinking red and green and then u can go to handsfree and new device and select HBH608....its easy try doing that...it workss....
Jan 03, 2009 | Sony Ericsson Sony-Ericsson HBH608...
Power light steady green but monitor goes dark after 4 secs of video
The video card in the computer could be going bad too or the driver for the video has corrupted. Try reloading the video drivers in the PC first.
Mar 29, 2017 | NEC MultiSync LCD1770V - Flat panel...
Booting problem
the ram may be faulty try to change the ram with one which is working
May 21, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
377 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
