Question about Acer TravelMate 2312LCi Notebook
Computer kicks off internet connection
I have to go to Local area network connections in Computer Panel and click on Repair in the support tab to get the internet back on the computer.
    President:
  • 2,600 Answers
Try this....
Can connect to local but not Internet?
This is most likely due to a driver issue other than a settings issue. First off, if you are running your computer in selective startup, change it back to normal startup and reboot. If this clears the problem then great, you can go back to selective startup but be careful as to what services you shut down.
The easiest way to check if this is a driver issue is to update the driver for the device. This can be done at the Device Manager found in the control panel, (In XP, the device manager is in the “system” icon and under the hardware tab). Scroll down to the network adapters and click on the + sign. Double click on the adapter and choose to update driver, let it search the internet (windows update) if it wants to, if it finds an updated driver, allow it to install. If it does not find an updated driver, then maybe the driver you have is a recent one but it may be corrupt. If that is the case, then it would be better to right click on the adapter and choose uninstall, this will force windows to reinstall the device the next time it reboots, and again it will ask to search online for a fresh driver, choose yes and let it run. Once the device installs, try to connect to the internet.
Posted on Oct 03, 2009
My wireless laptop cannot detect wireless networks..
Try this,
* Click Start * Click Control Panel * Select Network and Internet Connections * The Network and Internet Connections window will appear: Select the Network Connections icon * The Network Connections window will appear: Double click on Local Area Connection * The Local Area Connection window will appear: Select the General tab and click, or highlight Internet Protocol and press Properties * The TCP/IP Properties window will appear: * Make sure that both the Obtain an IP Address Automatically and Obtain DNS Server Address Automatically are selected, or checked.
If this helpful, please give a testimonial and vote by pressing button four thumbs up icon.
Sincerely Thiyaga
Aug 28, 2011 | Acer Aspire 5315 Notebook
Tip
HOW TO CHANGE IP ADDRESS
To change your network IP address in Windows XP, Vista, or 7:
1. Press the Windows Key and R
2. Type command and press Enter. This loads your DOS prompt
3. Type ipconfig /release then press Enter. This disables your internet connection
4. Go to your desktop, and right-click on something called Network Place or My Network Places (If you're using Windows Vista or 7, look for the Network and Sharing Center through Control Panel)
5. Click Properties. You should now see something called Local Area Connection or something similar
6. Right-click on your connection (titled Local Area Connection if you're using an ethernet cable or Wireless Network Connection if you're on WiFi) and click Properties
7. Under the General tab, double-click on the Internet Protocol (TCP/IP)
8. A new window appears. On its own General tab, click the box beside Use the following IP address
9. Type in ones until you fill the box up (it should read 111.111.111.111)
10. Press Tab. You'll notice the Subnet Mask section automatically fill sup with numbers
11. Click OK
12. Click OK to bring you back to the "Local Area Connection" screen
13. Right-click Local Area Connection and Click on Properties again
14. Again, under the General tab, double-click on the Internet Protocol (TCP/IP)
15. Select Obtain an IP address automatically
16. Click OK
17. Click OK
18. Go back to your DOS prompt, type "ipconfig /renew" and press Enter. This restores your internet connection.
By now, the network should've assigned a new IP address to your computer automatically.
on Jul 22, 2010 | Computers & Internet
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
No connection on internet
Check if the internet Cable At back of the Computer is properly connected.
Repair the Internet connection..
Click Start Then Control panel After that
Click 'Network and Internet Connection' Then 'Click Network Connections',
Double 'Click on Local Area Connection' Hit Support Then Click Repair.
If the Solution Wont work.
Call Your Internet Service Provider (ISP).
>>>>"M.J Trusedell"
Aug 18, 2011 | Computers & Internet
I got a wrt54gh router just less than a year now. it is connected to our desktop being used by my son & grandson in our living room, while i'm using my laptop in my room. it just happened that i...
If you have Windows XP then try this, for Windows 7 and Vista also the procedure is similar. If you have Vista or 7 then tell me I'll post the tutorial for that also.
  1. In Windows XP, click the Start button and select Control Panel.
  2. Click the Network and Internet Connections category.
  3. Note: If you are using Classic View, you will see the control panel icons instead of categories. Double-click the Network Connections icon.
  4. Click the Network Connections control panel icon.
  5. Double-click Local Area Connection, listed under LAN or High-Speed Internet.
  6. When the Local Area Connection Status window is displayed, click the Properties button.
  7. In the Local Area Connection Properties window, do the following:
    • Verify that the Internet Protocol (TCP/IP) box is checked.
    • Note: If your Ethernet adapter is not listed in the Connect using box, you need to install your adapter.
    • Click Internet Protocol (TCP/IP) once to highlight it and then click the Properties button.
  8. In the Internet Protocol (TCP/IP) Properties window, do the following:
    • Click Obtain an IP address automatically.
    • Click Obtain DNS server address automatically.
Apr 11, 2011 | Linksys Wireless-G WRT54G Router
My internet isnt c0onnecting... i just installed vista.. and its saying there is no network hardware installed or configured... i dont know whats wrong plz help ... thanks
  1. Click Start , and type Recovery Manager in the Search field. Click Recovery Manager when it appears in the menu options.
  2. Click Advanced options .
  3. Select Hardware program re-installation and click Next .
  4. On the Welcome window, click Next .
  5. When prompted to recover a hardware driver shipped with the computer, select Yes and click Next .
  6. From the list of drivers, select the proper driver, and click Next .
  7. Allow the PC to re-install the driver, and when prompted to restart the computer, select Finish
  8. For a PC with Vista
    1. Click Start , enter Network and Sharing in the search field, and then select Network and Sharing Center from the list.
    2. Select Manage network connections in the left panel of the Network and Sharing Center window. The Network connections window appears.
    3. If the status of your Local Area Connection is disabled , right-click the Local Area Connection icon and select Enable .
    4. Right-click the Local Area Connection and select Properties .
    5. On the Networking tab, select the IP Protocol (TCP/IP) connection and click Properties .
    6. On the General tab, verify that both the Obtain an IP address automatically , and the Obtain DNS server address automatically options are selected, and then click OK to accept the values.
    7. Restart the computer.
Feb 04, 2010 | Intel D101GGC Motherboard
Cant connect to lan modem
1. check first your lan connections,
click start, go to control panel, click network connections din check your local area connection.
2. right click the local area connection, then try to disable and enable it.
3. if not been solved,
try to look the driver of your ethernet drivers
look at and search your motherboard's brand and model then search it and download for your drivers for your network adapter.
or you may try this,
1. right click my computer
2. click properties
3. clcik hardware tab
4. click device manager,
5. click network adapter
6. right click the name of your network adapter then, click update
Jan 26, 2010 | Gateway 500GR PC Desktop
No internet connection
Internet connection solutions
  1. Restart the computer.
  2. Test the jack.
  3. Test the equipment.
    1. Try a different jack that you know works.
    2. Try a different cable that you know works.
  4. Check your computer settings.
  5. Renew your IP Address
    1. [x] Windows Vista
      1. Look for your Ethernet card:
        1. Right-click on My Computer from the Start Menu or on the desktop.
        2. Left-click on Properties.
        3. Click on Device Manager on the left side under "Tasks".
        4. Expand the Network Adapters and look for any yellow exclamation points. Make sure a card is listed.
        5. If there are exclamation points, or if there is no card listed, you need to reinstall the card.
      2. Set your IP address to configure Automatically (through DHCP):
        1. Go to the Control Panel in your computer (in the Start Menu).
        2. Go to Network & Sharing Center.
        3. Under "Network", go to Local Area Connection and select "View Status". In new window, choose Properties at the bottom.
        4. Scroll down "This connection uses the following items" list to Internet Protocol (TCP/IP).
        5. Select Internet Protocol (TCP/IP) and click Properties.
        6. Change to "Obtain an IP address automatically".
        7. After you have changed this, restart computer.
      3. Check to see if your network connection is on:
        1. Go to the Control Panel in your computer.
        2. Go to Network Connections. If you cannot see Network Connections, go to Network and Internet Connections and then go to Network Connections from there.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, double-click on the X to enable.
    2. [x] Windows XP
        2. Left-click on properties.
        3. Go to the Hardware tab and click on Device Manager
        3. Right-click on Local Area Connection and go to Properties.
        4. Scroll down the "This connection uses the following items" list to Internet Protocol (TCP/IP).
        7. After you have changed this, restart the computer.
        3. If there is a red X through the Local Area Connection, or the Local Area Connection is grayed out, click on Local Area Connection and click "Enable."
    3. [x] Macintosh OS X (10.4 or "Tiger")
      1. Look for Network Cards:
        1. Go to the System Preferences panel from the Dock or Apple Menu.
        2. Open Network icon under Internet and Network.
        3. This shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Go to Show and then click on Built-in Ethernet.
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option.
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Then restart and change it back to DHCP to renew the connection.
      3. Set your IP address to "Configure Automatically using DHCP". Under the Ethernet tab make sure that configure is set to "Automatically". Click OK until you are back to the main System Preferences windows.
      4. Check your privacy setting
        1. Go to Sharing under Internet and Network in System Preferences
        2. Under Services everything should be unchecked.
    4. [x] Macintosh OS X (10.5 or "Leopard")
        3. The left menu shows your current network settings. Green lights for each device means it is connected and red mean there is no connection.
        4. Select Ethernet from the left menu. Go to Advanced.....
        5. Under the TCP/IP tab make sure "Using DHCP" is chosen under the top option, "Configure IPv4".
      2. Renew IP address. Hit "Renew DHCP" or change it to a manual address. Click OK.Then restart and change it back to DHCP to renew the connection.
      3. Click OK until you are back to the main System Preferences window.
    // MAIN FUNCTION: new switchcontent("class name", "[optional_element_type_to_scan_for]") REQUIRED // Call Instance.init() at the very end. REQUIRED var bobexample=new switchcontent("switchgroup1", "div") //Limit scanning of switch contents to just "div" elements bobexample.setStatus('[x] ', ' ') bobexample.setColor('#674a80', '#3b5998') bobexample.setPersist(true) bobexample.collapsePrevious(true) //Only one content open at any given time bobexample.init()
  6. Make sure your computer is clear of all viruses, spyware, and adware.
Oct 03, 2008 | Computers & Internet
Settings for my browser
If you use Internet Explorer: Go to Start, Settings, Control Panel, Internet Options, Connections, and the LAN Settings button. Clear all checked settings in this window. Then, open your browser and select the Tools menu. Under Internet Options, click on the Connection tab and make sure that "Never dial a connection" is selected. If possible, remove all the connection settings. If you use Netscape Navigator: Go to the Edit menu and select Preferences. Go to Advanced, Proxies, and click "Direct Connection to the Internet." Also check for the following. If you are running Windows 95 or 98 or ME: Click on the following tabs and write down the settings you find. Right-click on Network Neighborhood and select Properties. Select "TCP/IP" for your network adapter. Then click Properties. Click the IP Address tab and select "Obtain an IP address automatically." Under wins configuration, click on use DHCP for wins resolution Click the Gateway tab. If there are any "Installed gateways," highlight them and click Remove. Click the DNS tab and select "Disable DNS." Click OK If you are running Windows NT: Write down any settings you see throughout the tabs for future reference. Right-click on Network Neighborhood and select Properties. Click the Protocols tab, highlight TCP/IP, then click on Properties. Click the IP Address tab and select "Obtain an IP address automatically." Remove any gateway settings you see. Click OK. If you are running Windows 2000: Right-click on My Network Places. Click on Properties. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK. Go the the advance tab, click on wins, check the box use NetBios settings from the DHCP server. If you are running Windows XP: Click on My Network Places. Click on view network connections. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. click on the advance tab, make sure the internet connection firewall is not checked, click ok,Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
How can i verify??
Feb 16, 2006 | Belkin (F5D5230-4) Router
Acer TravelMate 2312LCi Notebook Logo
50 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
