Question about Lands Phones
I lost my power supply, where can I get a new one, and or what size (volts) do I need
    President:
  • 570 Answers
If you take the answering machine to a RadioShack, they try the different sized plugs in and also match up the volts/amps for you and make sure it works before you leave so that you don't have to do anything. They cost between $10 and $35 depending on the strength needed.
Hope this helps! :)
Posted on Oct 03, 2009
PHILIPS CORDLESS CD245 TRIO AND other 2 handsets power requirements (Adapters lost)
It should say on the bottom of the base unit. I would expect 5-6 volt 500ma. That would be the size that would charge those batteries.
Oct 16, 2016 | Philips Lands Phones
Whats the voltage maximum on the cobra walkie talkies
Most lithium small radio batteries are 3.6 volts. If AA or AAA batteries, multiply by 1.5 volts. 4 batteries = 1.5 * 4 = 6 volts MAXIMUM. Rechargeable batteries are 1.2 volts. Your charger would be a much higher voltage because it takes power to "push" the charge into a battery. You didn't say, so I am assuming you want to operate the radio with a wall charger. I've done this by soldering the wires to the battery contacts. You need a higher voltage than 3.6 volts, but milliamps is more important. You need enough milli amps to get the radio to transmit. Too much and it frys, literally. So, this is all on you to decide if the risk is worth it. I use a 5-6 volt power supply set on no more than 1 amp (800 ma is my favorite size) 1 amp = 1000 ma. Let us know if this helped!
May 20, 2016 | Cobra FA-CG Micro Talk Walkie Talkies
Hello everyone! I have lost my Koss HD50 power supply and was wondering again, how many volts and how many amps? ex:6V, 500ma Thank you kindly! Erjel
Three C cell size batteries per speaker is what you use if you are on the go.
http://www.shopping.com/Koss-HD-50/the-paradox-decent-small-computer-speakers/1386310/reviews#tabAnchor
Hmmm.
EACH C cell battery produces 1.5 Volts (DC)
3 times 1.5 Volts (DC) = 4.5 Volts
Total of 9 Volts (DC)
500 MilliAmps?
Your main concern is with the Voltage.
The Amperage can vary. It can be more than needed.
Why?
Because Amperage represents Current.
How much Current is available.
(Water hose example;
Voltage is the speed, or velocity of the water coming out. Amperage is how many gallons per minute that comes out of the hose)
However, you better make sure that EACH speaker receives No more than 4.5 Volts (DC)
Since you do not have the special splitter adapter cord that comes with the power brick, you will have ensure that EACH speaker receives no more than 4.5 volts.
This is if you are trying to use a 9 Volt (DC) power supply. (AC adapter)
Please post additional questions in a Comment.
Regards,
joecoolvette
May 30, 2011 | Koss HD 50 Computer Speakers
I lost my power supply adapter/transformer....there is no manual....what size do i need for the adapted/transformer
The last item on this page is the user manual for the Xantrex 300
http://www.xantrex.com/power-products-support/document-downloads/discontinued-products/discontinued-products-backup-power.aspx This is a pdf. Right click, and "save as"
I would suggest it will be almost identical to your 200.
From personal experience, I imagine it uses 12volt lead acid sealed cells, Typically this would use a 13 to 14 volt powersupply probably at 2.5 to 3 amps.
You can also charge the device from your cig lighter socket. See pg 16 of manual.
Jan 16, 2011 | Xantrex Technology XPower Powerpack 200...
Can this Tally Print work with any 7,5v power suply?
The TallyCom works with a 7.5 volt power supply, you would need to ensure the correct size connector is used and also the power supply center pin is of the correct voltage.
Also ensure the power supply is able supply the ampage required by the TallyCom
NOTE the TallyCom+ uses a 5 volt power supply do not use a 7.5 Volt power supply if the print server is the + version
Nov 18, 2010 | Tally (43555) Print Server
I have a pioneer car stereo-12V DC, a sony xplod amplifer(2 chanel)-12V DC and I want to use them in my home, what kind of power supply will I need?
You want to use a 12 Volt power supply. This takes your 110V power and converts it to 12V power. Which size you need completely depends on how powerful your amplifier is. Your stereo needs about 10amps of power and looking at the fuse size on your amp, you need to add thses to the 10 amps for the stereo and this will tell you what kind of power supply you are looking at.
Aug 09, 2010 | Pioneer Car Audio & Video
T23 2647 Think pad AC power adapter lost
No. You must use a power supply that is 16 volts or that is specified to be used with the laptop.
You can find the information about the power consumption (volts and amperage) underneath the laptop. If it says 16 volts then you MUST use a 16 volt power supply.
If you try using a 19 volt power supply you run the risk of damaging the motherboard or blowing the motherboard completely.
Regards.
Mar 18, 2010 | IBM Computers & Internet
I HAVE A PRO -34 SCANNER AND NEED THE CIGARETTE LIGHTER ADAPTER, OLD ONE WAS CAT.# 270-1560 WHAR IS THE NEW ONE I NEED. AND WHERE CAN I GET ONE. HAVE BEEN TO 6 STORES LOCAL, AND NO ONE KNOW'S.
You need a 9-volt automotive power supply, but I couldn't find the plug type that the scanner needs. Radio shack, and probably stores like Wal-Mart carry them. Just take the scanner or old supply with you to check the plug size. You can also use a universal supply, such as this one that I found on eBay:
http://cgi.ebay.com/ebaymotors/Auto-DC-Adapter-3-4-5-6-7-5-9-12-Volts-800-mA_W0QQcmdZViewItemQQhashZitem1e57461d69QQitemZ130313231721QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Nov 20, 2009 | Office Equipment & Supplies
Power supply gigaset 8825
The power supply for the 8825 base is to be 13 volts AC, rated at 850 milliamps or higher. You can go anywhere from 13 up to 15 volts without hurting the unit, and a higher current rating is even better. We actually make them ourselves through bulk purchases of varieties of power supplys. Your next delimma will be the plug size, it is a pretty common size, most universal adapters will have the right size of the outer and inner connections.
Nov 16, 2007 | Siemens Gigaset 8825 Cordless Phone
Lands Phones Logo
83 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
