Question about Bosch 24 in. SHU53 Built-in Dishwasher
Sms68mo2au how to connect electric cord, no seperate cord
    Guru:
  • 351 Answers
The electric connection for most dish washers is a small metal cube in the lower right of the bottom of the machine , near the front. Remove the kick plate to get access under the machine. A screw holds the cover on the power connection cube.. There is a wire there for the power connection. Connect color for color. You should use a connector on your supply cord to protect the connection when the washer is slid in or out.
Posted on May 05, 2010
Trying to replace a 3prong plug with a 4prong plug
Ok, so you currently have a three prong cord on your dryer? Your house has a 4 prong receptacle? Ok so now you've purchased a 4 prong dryer pigtail? Be sure cord is unplugged. Remove cover of junction in back of dryer. You will see three terminals. They should be labeled something like L1,L2,N . ON one terminal you well see a small ground strip This is currently connecting the neutral terminal to ground. On the new cord connect the outside two conductors to L1 +L2 connect the white conductor to the N terminal. Connect the green (ground) conductor to the frame where the copper bonding was. This seperates the neutral conductor from the equipement grounding conductor.
Jul 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I am changing the 4 wire on my 2 yr old maytag dryer to a 3 wire to fit the recptical in my new house. Other then the 2 hots and 1 neutral connection, my dryer also has a white ground wire off to the side,...
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 19, 2010 | Dryers
How to hook up a 4 wire plug to a Maytag clothes dryer model LDE8824ACM with 3 wire connecters.
Feb 09, 2010 | Dryers
Need to replace existing three wire plug with new four wire plug. there are only three terminals to connect to. what do i do?
Based on your description....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
Feb 08, 2010 | Dryers
The electrical cord is seperating from the base of the iron and exposing the cord. The plastic covering is in parts. Can this be repaired?
You can repair this yourself but you will have to take the handle apart to access the power cord inside the handle. Just pull the cord inside and wrap with electrical tape to hold in place. Hope this helps
Jul 31, 2009 | Rowenta Irons
My husband pulled the cord out and was mildly shocked (he is fine) but now the dryer wont spin,is does turn on but when you press start it does not- is there a reset button?
If the cord shocked your hubby, the problem is with the cord! It runs on 220 volts, with half (110v) on two seperate wires. One of your wires is shorted or burnt. Unplug the dryer. Pull the dryer out to where you can see where the electrical cord enters the dryer. From the wall, the cord should pass through a strain relief clamp, into the dryer, and then connect to the terminal strip. Many people eliminate the strain relief clamp, and wish they hadn't later. Anyhoo, open the cover plate that covers the wiring in the back of the dryer, and inspect the wiring and terminals. If a shock occurred, the cord probably needs replacing. Purchase a similar cord (~$15), install it through the strain relief into the hole below the wiring access cover on the back of the dryer, and make the wiring connections. For a three wire cord, the outside wires are the hot leads and connect to the dryer, one to the left, one to the right. The middle lead is the neutral, and connects to the middle terminal. Tighten the strain relief, and replace the wiring access cover.
Hope that this was helpful. Best regards, --W/D-- please feel free to rate this solution! Thanx!
Jul 31, 2009 | Frigidaire FEQ1442ES Electric Dryer
The generator runs fine but will not give us any powere
Hello, Has this generator been setting for awhile or was it in use when the power ever came back on? Have you tried to repolarize it? To do this , Shut off the generator and unplug any cords or wiring from unit. Take a electrical cord that has a plug on one end and seperate the wires on the other end of cord. Strip the ends of the wire back about half an inch on each seperated wire.Plug the Male end of the wire into one of the 110V recepticles. Connect one of the ends of the wire you stripped back to the positive side of a 12 volt battery. Now with the other end of the wire you stripped back touch it to the Negative side of the battery for 1 sec and remove it. Unplug the wire from the recepticle and battery. Fire up the Generator and check the voltage! This repolarizes the unit and fixes most non generating problems from Non use and back feeding! Hope that helped! Rick
Jun 28, 2009 | Coleman Electrical Supplies
Kenmore Model 94812 Electric laundry center
Hello handicapper,
Welcome to fixya.
You said, the above unit is new and has no separate power cord for the washer unit. Does the power come from one side of the 240 volt cord that attaches to the dryer connection?? Please advise,thank you.
Yes you are correct.
The on cord services both washer and dryer in your laundry center!
Do you have it running yet!
You should have no problem it comes with installation instructions.
If you need the user guide you can find it here online!
http://www.managemyhome.com/mmh/lis_pdf/INSTL/L0710024.pdf
If you have any more questions just ask.
Let me know that you are up and running.
Please remember to leave me the best rating.
Thank You Huuum
Oct 09, 2008 | Washing Machines
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
Switching the cord on maytag neptune dryer
dre, sounds like you moved and the dryer electrical outlet is only 3 pronged, This tells me that the dryer will be grounded through the neutral leg. Just hook up the cord and you should be fine. Make sure the white is in the center. Catriver.
Dec 07, 2007 | Maytag Neptune MDE6700A Electric Dryer
Bosch 24 in. SHU53 Built-in Dishwasher Logo
259 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
