Question about Kenmore Dryers
My dryer won't turn on. it's plugged in. power is fine in the room. one of the link trap screws came out but I put it back in. still won't turn on. i can't find a model name or number printed on the machine. i just bought this house and the previous owners did not leave the manual of course. i know its not more than 6 years old.
  • Kenmore Master
  • 7,482 Answers
I know you said you have power in the room, but make sure the breaker to the power outlet for the dryer has power, because most dryers are 220 volt and room power is 120 volt.
If the belt is broken on the dryer, it would also not allow the drum to turn, but the motor may be running.
Check to see if the motor is running. When motors are running with a broken belt they can almost be silent while running.
If your breaker is ok and power is ok at the power outlet, then your problem could be a faulty motor, broken belt, faulty start switch or faulty timer switch.
I hope this helps
Posted on Oct 03, 2009
Dryer won't start
You have to take the back off. After taking the back off, you'll see the lint trap vent. On the bottom where the circular metal sheet is, disconnect all of those screws. Look to see what got stuck in the blower wheel.
Jan 23, 2012 | Dryers
Has power. drum won't spin. Makes a humming noise. Lint trap & hose are clear. Was running fine.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2011 | Whirlpool Dryers
Light inside dryer works fine, but lights for buttons wont turn on. So dryer wont start. It definitely is receiving power, but the buttons up top, on the front display will not even light up (regardless of...
i would double check the power a dryer runs on 220 volts if it is only getting 110 volts it will only run half of the dryer,, that means it could have power to the motor and light but not the control panel or vise versa 75% of the time when i work on a issue like this that is what it turns out to be,, take the cover off of the back of the unit where the plug goes in you will see three screws that the plug is held on with you will need a tester that reads 220 volts put one lead of the tester on the left screw and the othe on the right screw you should read 220 volts,, if not put one lead on the center screw and touch the other lead ont the other screws one at a time until you find which one doesnt read 110 volts,, if it reads the full 220 volts then you will need to check all the wires inside,, if all is ok you will need to replace the main control board
May 03, 2011 | Kenmore Elite HE4 Electric Dryer
I have a Kenmore HE2 dryer that was working just fine. My husband stopped it in the middle of it's cycle to check on the clothes. He cleaned the lint trap and put back. When he closed the door and tried to...
you can unplug it for about 30 minutes, but I would venture to guess that the sensor which is located below the lint trap(if you look down the trap you will see to screws) is dirty and need to be cleaned, clean gently as not to break the sensor. Good Luck Tim
Feb 25, 2011 | Kenmore 85871 Electric Dryer
Clothes not dry but dryer turning. cleaned out
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 09, 2010 | Roper RGX4634KQ Gas Dryer
When I pulled the lint trap out there was much on
if it is a top lint filter take the lint filter out,turn dryer on,put your hand in it and you should feel a stong stuckion,if not remove the back panel and the 2 lint filter screws and check for clog-mike
Feb 22, 2010 | Whirlpool WED5100SQ Front-Load Electric...
KEYS850JQ0-Light works inside dryer when open but won't start even after plug pulled out a bit and put back in. Any answer? Also previously noticed; while dryer is running and I open the door it keeps...
The door switch is bad, the part number is 346704_1_s.jpg PS346704
that is what it looks like. To get to it take the lint trap out and remove the screws around the lint trap door , be very carefull not to loose them down the lint trap shoot, next take a screwdriver and pry the front end of the top of the dryer up, it will just pop up. The switch will be right in front and center inside of the dryer attached by one screw. Make sure the dryer is unpluged before doing this. You can set the top back on by just pressing down on it after replacing the switch, it will lock back in.
Nov 09, 2009 | KitchenAid KEYS850LQ Electric Dryer
How to remove the front panel of whirlpool dryer to change out door switch
FIRST UNPLUG IT!!!!! remove the lint screen remove the screws there, if no screws, still proceed take a flat screw driver on the crack of the lid in front of machine pry on both sides of it will pop up, then it will lift like a car hood, might be able to reach it from there, if not there's two screws (under the hood) then the front will come off, the drum will fall its ok, just have to put in place when you put it back together when in place hold front with knee and put screws back in (under the hood), pop cover back down and put screws back in where lint trap is, clean lint trap and reinsall. fire the puppy up
Sep 10, 2009 | Dryers
Electric dryer won't heat, maybe the heating element but before it stopped heating i cleaned the lint trap and something fell into it and i didn't notice and turned it on and could hear it hiting...
Sounds like you broke the heating element. Go to a local shop and get one. You may have also burnt the timer so after element you may need a new timer as it tells it to put power to it.
Jul 08, 2009 | Whirlpool LER4634J Electric Dryer
Plugged venting causing low heat and poor lint output?
you need to check the dryer vent hole on the back of the dryer,make sure it's not blocked,also check the wall vent for the same thing,most of the time if there is a clogg it holds the moisture in the dryer and it take forever to dry,you can use a shop vac to **** out any clogged lint in dryer and wall ,then if you have a leaf blower put it on the wall side and blow it it all out.let me know how you do-mike
Oct 30, 2008 | Dryers
Dryers Logo
80 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
