Question about Waterway Pump Part Seal Set Ps1000 Cd 319 3100b/Ps 1000
How do you hold the shaft in the motor in order to remove impeller
    President:
  • 1,714 Answers
From the other end put a screw driver in to the cooling fan blade.
Posted on Oct 03, 2009
Pentair 011523 pump shaft seal is leaking. How do you remove the impeller and motor?
Separate the plumbing portion of the pump from the seal plate which is attached to the motor. The bolts will be a 9/16 inch hex head, that are visible facing the motor. Remove those bolts. That will then allow you to pull the motor and the seal plate away from the plumbing portion of the pump. Remove the diffuser which is covering the impeller, and then the impeller will need to be unthreaded off of the motors shaft. The motors shaft, will need to be locked. You can do this by removing the Cap on the backside of the motor and you can use whatever tool required to keep the shaft from spinning. Once you are able to lock the shaft, you can read the impeller... Note* some styles will have a screw in the middle of the impeller securing it to the motors shaft? This screw is Backwards thread, not normal thread. If your pump has this screw, need to remove it first, then you will be able to unthread the impeller off of the motors shaft.
once the impeller is removed, you can then remove the two halves of the shaft seal. Very carefully reinsert the new shaft seal into the proper places, just the way they were prior to you removing them.
Reassemble in backwards order as you disassembled everything.
good luck
Sep 04, 2013 | Pentair 011523 WhisperFlo High Performance...
Need to remove the impeller
Turn off the system at the breaker,
Undo bolts for housing and separate the motor from the pump to access the impeller. Some styles of motors have a screw that is reverse threaded holding the impeller in place, if it has one , remove the screw. Once you have access to the impeller you can use a big pair of channel locks to turn the impeller. Take off the back cover of the motor or remove the plastic or metal cap that is covering the shaft. Use a wrench to hold the back end of the shaft as you unscrew the impeller.
Aug 29, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
How to remove the impeller from a Masport Onga HJ200 pump to access and replace the seal between the pump and the motor.
The impeller is screwed on to the motor shaft; to remove it you need to hold the motor shaft at the fan end so that you can unscrew the impeller - normal right hand thread. Holding the shaft can sometimes be quite difficult so a good suggestion would be to remove the fan cowl along with the fan, this will enable you to secure the shaft with a small pipe wrench or similar. Once you have the impeller removed it will be possible to ascertain what steps need to be taken next - you may need a new shaft sleeve as well as a new mechanical seal assembly.
Good luck,
Mike G
Aug 25, 2010 | Garden
How to seperate pump from motor
Disconnect all power. Remove the six bolts holding the seal plate to the wet end. Remove the two small allen screws to remove the diffuser. Remove the dust cap from the end of the motor and secure the shaft from moving. If installed, remove the Phillips head screw in the center of the impeller by turning clockwise (left hand threads). You can now remove the impeller by turning counter clockwise, note that you may need an impeller wrench to remove it and a specific tool to hold the shaft while you remove the impeller. Once the impeller is off you can remove the four bolts that hold the motor to the seal plate. This process just needs to be reversed to re-install but you will need a new shaft seal (PS-1000).
Jun 30, 2010 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Trying to replace motor cant figure out how to remove impeller,
Might be a screw in middle of impeller with reverse thread. If so, remove. Remove back cover of motor, hold center shaft with wrench and unscrew impeller from shaft.
May 05, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
REMOVE IMPELLER FROM SHAFT A O SMITH PUMP MOTOR HIFLO
The impeller is threaded onto the motor shaft, take the back cover off and use a wrench to hold the motor shaft, then turn the impeller counter clockwise to remove.
Mar 15, 2010 | Plumbing
How do you remove the motor from a Flotec FPS5172, 1-1/2 HP.
The impeller screws on the motor shaft. First replace the through bolts in the motor. These are the long bolts, they will just cause headachs. On the back of the motor their will be a place to hold the shaft from turning, If you hold the shaft the impeller just unscrews. If you look in the center of the impeller it may have a set screw holding it to the shaft. If you have one of these it will be a left hand screw. Then you will need to break the impeller free as the brass that holds the impeller on will stick to the stainless steel of the shaft. Don't let how tight this is fool you when you put this back together it just goes on hand tight. Good luck
Nov 23, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
We are having issues getting the impeller apart on the jacuzzi magnum force pool pump and need some instructions on how to proceed.
I believe the jacuzzi pump impeller has a locking screw directly in the middle of the impeller. You'll have to turn it clockwise to remove it. Then you'll need to remove the cover from the back of the motor using a 1/4" nut driver. Depending on the motor, you should be able to use a 7/16" open end wrench to hold the motor shaft from turning as you turn the impeller counter-clockwise to remove it. Some motors are different, some have a keyed shaft or require a special tool to hold the shaft while the impeller is removed. Hope this helps.
Nov 22, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
May 01, 2009 | Pool & Spa
Pump seals
The impeller is threaded on to the shaft. The trick is to hold the shaft in order to untread the impeller. The surest method is to disassemble the back of the motor, exposing the opposite end of the shaft. There should be a spot to put a wrench in order to hold the shaft immobile. Then, it's simply a matter of unthreading the shaft. A strap wrench does a great job of holding the impeller without damaging it.
Dec 04, 2008 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Waterway Pump Part Seal Set Ps1000 Cd 319 3100b/Ps 1000 Logo
242 people viewed this question
Top Waterway Pool & Spa Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
Ian Kime
Ian Kime
Are you a Waterway Pool and Spa Expert? Answer questions, earn points and help others
