Question about Kenmore Elite Oasis 6808 Electric Dryer
Drum light beeper keeps beeping - Kenmore Elite Oasis 6808 Electric Dryer
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 27, 2010
How do you disconnect a reverse beeping signal on a 2006 Toyota Sequoia?
I have found the beeper wired into the reverse lights and if you just find the beeper and cut off the wire and cap it you should be fine and no more beep.
May 05, 2014 | Toyota Sequoia Cars & Trucks
How to stop door ajar and lights on beeper in vw beetle
Try resetting the computer. Take the negative battery cable off, wait 5-10 minutes then put it back on.
Dec 04, 2012 | 2000 Volkswagen Beetle
Microwave keeps beeping on GE spacesaver JVM1640WB
Does the display say anything?
If it says "F3" then you have a shorted keypad.
Please post a new question with full model number and more detailed symptoms.
Nov 29, 2012 | Microwave Ovens
Beeping noise in 1995 Chrysler LeBaron 3.0 turbo
PUT IN A NEW IGNITION SWITCH. THE KEY BUZZER IS INTERGRAL TO THE IGNITION SWITCH. IT ALARMS WHEN KEY IS LEFT IN THE CAR OR IF IT IS BROKEN IT ALARMS FOR ALL YOUR REASONS.
Oct 11, 2012 | Chrysler LeBaron Cars & Trucks
90 toyota camry keeps beeping when door is closed and car is shut off.
There should be a switch in the door opening usually on the front pillar between the hinges or at the bottom where the door meets the body at the back,that controls the interior light and possibly the beeper, If it has gotten out of adjustment, or is broken for some reason could cause your beeper to keep going. Check to see if your interior light is staying on as well.
Sep 10, 2011 | Toyota Camry Cars & Trucks
3 beeper beeped at 300. The beepers beep @8,10,and 12 minutes respectively. What time will the beep at the same time again.
If the beeper beeped at 300 then it will beep at the Lowest Common Denominator. The LCD for 8, 10, and 12 is 120. So add that 120 to 300 and you end up at 420. The Beepers will next Beep at 420.
Feb 28, 2011 | Computers & Internet
Spin Led stays on and beeper beeps
this spin light that is on is a fault code no:1 which means the electronic motor control has a memory problem solution replace motor control module ... hope this helps..:0)
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
CRV Reminder beeper not beeping
you should start by checking fuses,switch located on door pillar where door hinges are.sounds like a blown fuse or bad beeper,
Oct 05, 2009 | 2004 Honda CR-V
Keeps beeping
What does the beep indicate does it beep when it needs the filter changed?
Jun 07, 2008 | Maytag Chassis Built-In Air Conditioner...
Disabling the beep on a Kenmore microwave
I have Kenmore microwave model 721.61820100.
It has an "Option" button. Press it. The display say "NUMBER"
Then press "1". The display should say "SOUND" and then "OFF".
Press "Start" and that beast turns silent, well not really, but the beeps are goooone.
If for some reason you don't like it this way repeat the sequence and the sound this time will turn "ON".
Jun 05, 2008 | Kenmore 80809 Microwave Oven
Kenmore Elite Oasis 6808 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
