Question about Whirlpool Duet GHW9150P Front Load Washer
It keeps coming up with the f21 code - Whirlpool Duet GHW9150P Front Load Washer
    Scholar:
  • 31 Answers
F21 indicates a long drain. To fix this it is simple.
#1: Remove the 3 torx head screws that hold the front kick panel on. To get these off you may have to have a second person tilt the washer back a little so you can get the screw driver in there. If you don't have a torx 15 bit, you can use a 1/4 inch nut driver.
#2 You will see the pump basically in the middle of the machine on the bottom. (it will have a plastic piece that looks like a lid that screws into the pump) Before you remove that put the machine into "drain and spin cycle". Get out your wet vac and have it ready. (if you don't have a wet vac have several old towels ready to shove around the drain)
#3 SLOWLY start turning the cap counter clockwise. Have your shop vac right beside the cap to **** up the water. **Warning there is a lot of water that will come out this is why you must do it slowly**
#4 Continue to unscrew the cap while the machine is in the drain spin cycle. Once you have gotten the cap out (this may take several minutes if you don't want to make a huge mess with stinky water) you will most likely find a large build up of fabric or lint or pocket change.
It's always a mystery what you'll find in the filter!! Good luck!!
Posted on Oct 03, 2009
  • 5,911 Answers
"F21" is a Long Drain error code. This indicates that you have an obstruction in the drainage system. More than likely you probably have a clog in the drain pump. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Included is a follow-on link that explains how to check the drain pump to clean. You may also have to remove the inlet hose that runs from the bottom of the wash tub to the inlet side of the drain pump. Debris can commonly clog in this area as well causing the drain cycle to fail.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced.
NOTE: The "SUDS" error can commonly occur with the F21 error code as this is usually generated when air is sensed in the drainage system.
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
I got a F21 error, went through and pulled out the drain filter. And tried to start again continued getting F21 error. Bought a new water pump and still getting the F21, also backfilled some water into...
sounds like you have covered all the bases --- the next thing that I would try is to simply unplug the unit from the wall and let is sit for a minute or two and then plug back in. if this does not solve your F21 code, then I would say that the problem is at the sensor or main circuit board.
let me know if you need further help with this issue,
c...
Feb 03, 2011 | Kenmore HE2 Plus Front Load Washer
I keep getting a error code F21 i,ve done all the things the book said to do and i still keep getting the F21 error code.
IT COULD BE YOUR DRAIN FILTER CLOGGED UP, OR YOUR DRAIN LINE.. TO GET TO THE FILTER YOU WILL NEED TO TAKE THREE SCREWS OUT OF THE BOTTOM OF THE WASHER THEN SLID THE PANEL OFF, ( YOU WILL NEED SOMETHING TO CATCH THE WATER WHEN YOU REMOVE THE FILTER,, EVEN THOUGH IT LOOKS LIKE THERE IS NO WATER IN IT ,YOU WILL STILL HAVE SOME COME OUT) REMOVE THE FILTER AND CHECK FOR ANY BLOCKAGE, WITH THE FILTER OFF POUR ALITTLE WATER INTO THE DRUM AND SEE IF IT DRAINS OUT FAST.. IF THE DRAIN FILTER IS NOT BLOCKED AND THE WATER RUNS OUT GOOD THE PROBLEM MIGHT BE IN YOUR PRESSURE SWITCH, THIS IS NOT A PART THAT CAN BE WORKED ON JUST REPLACED
Jan 19, 2011 | Kenmore HE2 Plus Front Load Washer
F21 on the Kenmore HE2 Plus Frontload Washer
there is a removable access panel on the front of the machine under the door. Remove one screw from each side. There you will find the pump that has a strainer basket on it. Remove that and clean the blockage out of there. You will also find attached to the panel, another manual that explains the codes better
Dec 27, 2009 | Kenmore HE2 Plus Front Load Washer
F21 error code on a Kenmore HE2 front load washer
Unscrew the pump, there is probably objects in the pump, I get that error every month or so, I find coins in my pump all the time, if too much stuff gets in there the code F21 or sometimes SD comes up.
Jul 24, 2008 | Washing Machines
Bosch Exxcel Washer F21 error code
got a bosch washing manchine it keeps coming up f21 error and i have no book 2 see wot it is can you help me by tellin me wot it is thanks
Apr 11, 2008 | Bosch Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
