The paper won't feed from the back tray - Office Equipment & Supplies
    Problem Solver:
  • 15 Answers
See if you can locate the paper pick wheels, and even better see if you can get them to turn somehow. use a rag or whatever you can get back there and wipe the rubber wheels down with alcohol to break loose any buildup.Also that rubber can harden up, maybe a rubber rejuvinator would work.
Posted on Oct 03, 2009
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
Canon Inkjet, Not Printing?
Hi Rosa,
There was a paper jam and you cleared the jam, however you missed out to do one other thing. Cleaning the Rollers.
If the Paper Feed Roller is dirty or paper powder is attached to it, paper may not be fed properly.
In this case, clean the Paper Feed Roller. Cleaning will wear out the Paper Feed Roller, so perform this only when necessary.
You need to prepare: three sheets of A4 or Letter-sized plain paper
1.Make sure that the power is turned on, and remove any paper from the Rear Tray.
2.Open the Paper Output Tray gently, and open the Output Tray Extension.
3.Clean the Paper Feed Roller without paper.
(1) Press the g0081065_tcm14-774017.jpg (Maintenance) button repeatedly until b appears.
(2) Press the Black or Color button.
The Paper Feed Roller will rotate as it is cleaned.
4.Clean the Paper Feed Roller with paper.
(1) Make sure that the Paper Feed Roller has stopped rotating, and load three sheets of A4 or Letter-sized plain paper in the Rear Tray.
(2) Make sure that b appears on the LED, then press the Black or Color button.
The machine starts cleaning. The cleaning will be completed after the paper is ejected.
This should fix the issue
Regards,Suhail
Nov 03, 2011 | Canon PIXMA MP495 InkJet Printer
Paper won't feed from tray canon mp760
check in your front panel the button "Feed switch"
If you press the butto, the led change to show where the printer get the paper
If led up, you must place paper on Autosheed feeder
If led down, you must place paper on tray Cassete
If the error continue. check if they are Jam paper .
Is important for people who share their knowledge, know your comments. If the answer is helpful, rate my answers
Sep 27, 2011 | Canon PIXMA MP760 All-In-One InkJet...
Sharp AR-205 misfeeds at transport area from both paper trays and bypass tray both. Tested using different paper in all trays and still won't feed in at the transport area. The paper just pleats up...
it means the drum is not moving check it, insert it properly. or therre is a broken gear somewhere or the motor that makes the drum to rotate is not working properly. The registration sensor not working or not postioned properly.
Aug 01, 2011 | Sharp Office Equipment & Supplies
Paper won't feed from both tray and manual feed tray...motor starts, attempts to grab paper, but doesn't
THERE IS TWO REASONS. PICKUP SENSOR PROBLEM OR IN THE FIXING UNIT HEATER SECTION PROBLEM. SOMETIMES HEATING ELEMENT BURNED. CHECK THE BOTH ITEMS .
Jun 18, 2011 | HP Office Equipment & Supplies
We have an IR3320N that will only feed from the bypass tray - anyone run into that symptom? It was feeding from the feed trays this am.
What happens when you try to feed from one of the trays? With paper in the trays look at the display, does it show that the correct paper is loaded in the tray? Get a flash light and pull the trays out and look back into the machine and see if any paper is jammed up in the back. Also make sure all the guides are up to the paper in the trays and give it a go.
May 15, 2010 | Office Equipment & Supplies
Paper doesn't feed from inside on XD 100 work center (10 years old, lightly used). Despite a full paper drawer, I get the "out of paper" error message.  I can copy by feeding through the back.
On this machine, the feed rollers might be worn down.
Not seeing the machine and by the description. there can also be other possible problem areas, deep in the machine itself.
Does the paper feed partially out?
If it does not, are there paper black scuff marks where the rollers were trying to feed the paper.
Can you hear the solenoids feed the paper?
If the paper does feed and seems crooked, it is possible the paper tray springs need to be stretched out just a little to push the paper tray plate more on the feed rollers.
Make sure the tray is completely up in the latched position so the feed wheels will touch the paper stack itself.
If you have a two paper tray, make sure you tell the machine what size paper you have for each tray.
Run paper in each tray.
Good luck.
Jan 15, 2010 | Xerox Office Equipment & Supplies
Printer can't feed paper from tray
You may need to clean the rubber feed roller with a damp towel, water only, or if parts are broken or missing, a new paper tray, around $20.00
Jul 20, 2009 | Brother HL-5240 Laser Printer
57 people viewed this question
jasbo
jasbo
