Question about Lexmark X1270 All-In-One InkJet Printer
My lexmark 1200 printer has a problem everytime i print its not on is proper color place and format.i already all the possible thing to do but still evry time i print looks like that and in the monitor always say the cartridge is not on proper place pleaaese solve my problem coz i it spending to ,uch ink for useless and i have too much paper work to be done
  • pol777com May 11, 2010
    thanks anyways i solved already
SOURCE: Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Posted on Apr 13, 2007
  • 2072 Answers
SOURCE: Lexmark X1185 won't Print Color
On your printer, there is a clean print head adjustment,it is in your menus on the printer itself, It should also be on your print driver in properties. I would try running that up to 5 times before proceding to anything else.
Check and be sure the cartridge expiration date is not exceded. The liquid ink cartridges have an expiration dates. Even though the cartridge is new, Do not rule out a bad or for some reason dryed out cartridge or blocked port at the bottom. If it is indeed brand new and you have the receipt, I honetsly would suspect the cartridge itself.
Ok now, we tried the print head cleaning, and a second cartridge.
Next, I would remove the cartridge, turn the printer off and lightly, very lightly dampn a dusfree cloth with some alcohol, and where the cartridge is located, clean those contacts. reinsert the cartridge and see what happens.
Lastly, you can unplug the printer, remove the cartridges, and place a paper towel under the area where the cardtidge latches in, and dribble in a soapy cleaner, like fantastic, because those inks will dry out in the ports and not allow the ink to flow properly, If you do that, wipe all the excess cleaner up and leave the printer off for an hour or two to allow any remaining liquid to evaporate. Don't use a lot, but trickle it in until you see the ink start to wash out and all the ink is removed.
Take your time, and go from easiest to more difficult. I think that is the process I presented.
Posted on Feb 22, 2008
Ajkill
  • 2035 Answers
SOURCE: Lexmark x2500
Try cleaning the copper plates and install back again if the same message pops up try single cartridge if the error exits with 2 cartridges ,replace the cartridge as lexmark cart has 1 year warranty..
Posted on Mar 25, 2008
SOURCE: Lexmark x 1270 & x1290 printer won't print black after using re-filled cartridges.
hmmm...paperman..that's unusual to say the least..
Posted on Aug 19, 2008
  • 3 Answers
SOURCE: Reset Lexmark 36 Black cartridge?
I have just found out that the no. 36 & 37 cartridges are in the Lexmark return program where you can get money off new cartridges by returning the old ones. That's probably why they have some sort of fuse in them so they can't be refilled. You can however buy the more expensive no. 36A & 37A cartridges which are apparently refillable. I haven't tried this out yet but I shall be buying these next. Here is a link explaining it:
http://www.printerfillingstation.com/Ink_Refills/Lexmark/33L.htm
Posted on Nov 03, 2009
LEXMARK PROSPECT PRO 205. HAS A CURRENT SOLUTION FINALLY BEEN FOUND FOR "PRINTER CANNOT COMMUNICATE WITH COMPUTER". LEXMARK CANNOT OR WILL NOT FIX THIS PROBLEM.
Chuck, I certainly sympathize with "tech support" that isn't, and with you on printers that don't get new drivers when new versions of Windows com out.
I'd be happy to enter a dialog with you to try to help you.
Have you tried another computer, hopefully running something different?
What connection are you trying to use? Does the printer have any alternative connection available? (say, USB or network)
When you first plug it into the computer, does the computer sense it's there and look for drivers, or does it ignore you?
Jun 16, 2015 | Lexmark Pro 205 Inkjet Multifunction...
Put in new color cartridge and it won't print color
Hello, the new color cartridge might not be seated properly or just needs cleaning. Here are some tips on what to do to remedy the problem. Remove the cartridge from the printer. Double-check if protective seal is already removed. Take a warm, damp paper towel. Set the ink cartridge on the paper towel like how it is placed in the printer - nozzles facing down. Drag the cartridge lightly across the paper towel in one direction (left to right) until the bottom of the cartridge looks clean. Reinstall and properly secure the cartridge in its place. Hope this helps.
Mar 16, 2010 | Lexmark X125 All-In-One InkJet Printer
Vista Printer problems - Printer not printing Test page or docs
You may have to change the communication format called the "Spool format."
Please follow the steps given below to change the spool data format:
1. Click on "Start," "Control Panel," "Hardware and Sound" and "Printers."
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark 1200 series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Please try printing again.
If this does not help the situation, please describe any differences it does make.
May 14, 2009 | Lexmark X1270 All-In-One InkJet Printer
Printed pictures comes out red
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Lexmark Optra Color 1200 Led Printer
T630 cannot print color
just a wild guess. it may not be capable of printing in color.
check if you indeed have color cartridges installed.
it says B/W - Black and White.
http://www.dooyoo.co.uk/laser-printer/lexmark-t630/
escription: Model ID 0010G0110 / Lexmark T630 - Printer - B/W - laser - Legal, A4, A4 Long - 1200 dpi x 1200 dpi - up to 35.1 ppm - capacity: 350 sheets - parallel, USB
Apr 28, 2008 | Lexmark T642 Laser Printer
Lexmark all-in-one 1200 series
black intcartirage(color 17) wont print but color prints perfectly
Mar 02, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark 1200 series
How is the printer connected? USB, network, LDP cable?
Regards,
Chester
Jan 11, 2008 | Lexmark OptraImage Color 1200r Laser...
Won't print
Turn off printer open door, move printhead with the cartridges, should slide, if not the printhead is being held in place by something. turn unit back and see if it goes back in place.
Nov 19, 2007 | Lexmark X1270 All-In-One InkJet Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Lexmark X1270 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
