Question about West Bend 84716 6-Quart
Display on digital reading
When I plug in my cooker and push the on button it displays E01 and will not turn on.
    Problem Solver:
  • 9 Answers
The site for West Bend is www.westbend.com you can read the FAQ to see if you problem is there or you can e-mail them with your problem.
Posted on Dec 23, 2007
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Nov 19, 2012 | CorningWare SC60 Slow Cooker
West Bend Slow Cooker error code: "E01". - holding "cook" button while plugging/unplugging did not fix the problem.
if you put something frozen or cold in it and let set for awhile without turning on then you must take it out let unit get room temp. then start it . E01 error means the unit is too cold to start.
Dec 22, 2010 | West Bend 84496 6-Quart Slow Cooker
Slow cooker will only stay on warm. How do I put
This slow cooker has 3 settings LOW, HIGH, & WARM
When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
Feb 11, 2010 | CorningWare SC60 Slow Cooker
E01 code shows on screen. How do I erase this code if possible
Hold cook button in while plugging-in powercord . You might have to quickly hit the select button. If if doen't work the first time keep trying.
Jan 09, 2010 | West Bend 84396 6-Quart Slow Cooker
How do I start the cooker on low?
The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
Dec 18, 2009 | CorningWare SC60 Slow Cooker
Need a manual for the corningware sc60
The manual basically says... This slow cooker has 3 settings LOW, HIGH, and WARM. W hen you plug the slow cooker in the display shows "0". When you press the "COOK TIME" button, the display should go from 0 to 1 to 2 to 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the HIGH setting. If 7,8,9,or 10 hours are selected, the slow cooker will operate on the LOW setting. To start the cooking cycle, press the "ON/OFF" button. To interrupt the cooking cycle at any tim, press the "ON?OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the WARM setting. If the "ON/OFF" button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
If the "COOK TIME" button does not change the display numbers, unplug the slow cooker. Hold down both buttons and plug the slow cooker in and keep them pressed down for a count of 10. Release the buttons and the slow cooker should work now.
Nov 28, 2009 | CorningWare SC60 Slow Cooker
When I plug in my 84596 west bend it gives me eo1 with a beep
The E01 error message happened to me this morning. I unplugged the crock pot, held the "cook" button and plugged it back in while holding in the "cook" button. It seemed to reset itself. It is working fine now.
Jan 01, 2009 | West Bend 84596 6-Quart Slow Cooker
When I turn it on I get E01
  1. The thermostat may temporarily lose calibration due to temperature changes resulting in an E01 error message on the display. Repeat the following steps to reset the unit.
  2. 1. Unplug the unit from the wall socket for approximately 10 seconds.
  3. 2. Plug the unit back into the wall socket.
  4. 3. Press the POWER button once. Within one second, press the COOK button once. The unit should now be rese
Dec 19, 2007 | West Bend 84496 6-Quart Slow Cooker
WEST BEND SLOW COOKER
Dec 03, 2007 | West Bend 84496 6-Quart Slow Cooker
Displays E 01
Talked to the nice lady at West Bend. Apparently, the problem comes up when the unit is "cold"... whatever that means. She said to plug it in, wait a second, then push the power button, then "cook" immediately. No pause. Don't hold either button. I tried it, it worked on mine.
Apparently, this a feature for some reason.
May 17, 2007 | West Bend 85146 6-Quart
West Bend 84716 6-Quart Logo
186 people viewed this question
Top West Bend Crock Pots & Slow Cookers Experts
Steve
tsalagi152
Sloop Johnb
Are you a West Bend Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
