Question about Olympus FE-340 Digital Camera
The lens keep popping out and the screen remains black. I cannot see pictures
When I switch it on, it keeps saying "Change Batteries". Can only view previous pics and get to the menu. Cannot take pictures
hi, use alkaline, lithium batteries or high capacity nimh batteries
this should we have tried and it works , hope it works for you also
Jul 04, 2016 | Canon Powershot Sx150 Is 14.1 Mp black...
Canon s21s
Think that you mean the S2 IS? If so, Canon has not yet to offered an advisory repair of that particular problem (although many people think they should as this seems to be quite a common problem for the S2). There are however some simple things that you can try to revive your camera from the likely "stuck shutter" problem that you're experiencing. See this blog article.
Sep 27, 2009 | Canon PowerShot A75 Digital Camera
Whenever i want to take a picture the screen reamins black
A stuck shutter is a common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 08, 2009 | Nikon COOLPIX L18 Digital Camera
Screen is black
Eagle 23: Press the "Disp" button and your LCD screen will turn on right away.
nazmil_mj: Can you take pictures or are they totally black as well? If you can only take black pictures then your LCD screen is fine and your CCD is bad or your aperture is stuck. Either of these means you need your lens replaced.
Don't bother asking a store for help (though you can if you like) they will tell you it's not fixable or will just send it to Canon and charge you $175 for the repair.
We are an affordable digital camera repair business, we can replace your lens for about $75!
Thomas
Owner- Darntoothysam com
Mar 28, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Problem with lens
It is possible you have the display turned off... Some cameras allow you to do this to save battery.
Feb 22, 2008 | Nikon COOLPIX S5 Digital Camera
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Problem with lens
This suggests a loose connector -sent it back to manufacturer for fixing at a huge price -
Or keep squeezing - I am sure 'She' prefers to be squeezed and so .would you ;-)
Sep 06, 2007 | Fuji FinePix Z2 Digital Camera
Olympus FE-340 Digital Camera Logo
42 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
