Question about NetGear RangeMax WPN824 Router
Cant hook into the network with a secondary wireless computer
  • Banumathi M
    Banumathi M May 11, 2010
    did try to scan and connect in your secondary wireless computer?Is it a cable modem?If so we have to do a mac spoof and also check your browser.waiting for your reply
  • 1,272 Answers
Follow the steps below to configure settings:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Check if WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key) is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the key that has been checked.
This is the code required for connecting the wireless computer to the router's wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new Password and click apply. You will then have to use the same Password for all the wireless devices connecting to the network.
Perform the below steps if your wireless computer has windows XP:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' astab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
If the computer has windows Vista then perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side
menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Oct 03, 2009
Cant hook up my ps3 to my netgear wgr614 n150
need to get ps3 component cable that can hook directly to the router,if it is a wireless router goto ps3 setup menu,then turn on network discovery on ps3,then will ask for password from router fill password in,it will hook up.
Dec 21, 2012 | NetGear WGR614 Wireless Router
Cannot connect to wireless internet
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Please follow this steps carefully
Turn on your internal wireless card?
If your wireless card is built in to your computer, there may be a switch on computer that turns the card off and on. When new from the store, these switches are often in the "off" position. They can also accidentally get switched off during use. Find the switch (often near a symbol that looks like a microphone or radio tower emitting radio signals), and turn it on. The card should now find wireless networks in the area and connect.
Find the scrldcolville network?
If your wireless device is properly installed, your computer should automatically start scanning for networks in the area and will inform you that there are wireless networks present. If not, you can scan for networks in the area manually.
*To bring up the Wireless Network Connections menu, go to the Start Menu (in the lower left-hand corner of your screen, choose "Settings," then chose "Network Connections," and finally, choose "Wireless Network Connection." Clicking on this option in the menu should bring up a window. In the upper left hand corner of the window under the heading of "Network Tasks" there should be an option that says "Refresh Network List." Click on this option to search for wireless connections. Choose scrldcolville, hit the "Connect" button in the lower right hand corner and enter the passkey to connect.
Enter the passkey correctly?
If the passkey is entered incorrectly, the computer will appear to connect to the internet, but will not actually connect. If you think you may have entered the passkey incorrectly, disconnect from the scrldcolville network (see steps above in #5) and then reconnect. Often, as you manually reconnect to the network, the computer will remember the passkey and a small window will pop up, showing the password as a line of dots. Re-enter the passkey correctly before connecting.
(#6, cont.): Sometimes, your computer will not allow you the option of re-entering the passkey when you reconnect to the network. If this happens, bring up the Wireless Network Connections menu. Click on the "Change advanced settings" option under the "Related Tasks" heading. Another window saying "Wireless Network Connection Properties" should pop up. Click on the "Wireless Networks" tab at the top of the window. Under the "Preferred Networks" heading, there is a box that lists all wireless connections your computer has ever used. Click on the scrldcolville network to select it. Now hit the "Remove" button just below the box, then hit the "Ok" button. This will make your computer forget the scrldcolville network and the bad passkey. Bring up the Wireless Network Connections menu again and connect to scrldcolville .Be sure to enter the passkey correctly.
Allow your computer to obtain an IP address automatically?
Be sure that your computer is set to obtain IP addresses automatically and that it does not have one assigned manually. To do this, bring up the Wireless Networks Connections menu .Click on the "Properties" button. Here, you will see a list under the heading "This connection uses the following items." Scroll down the list until you see an item named "Internet Protocol (TCP/IP)." Select this item and hit the "Properties" button just below the list. This will bring up a new window. In order to connect with the library's wireless device, you must have the option "Obtain an IP Address Automatically" selected (ditto for the DNS server address). If you are set with a manual IP address, you can click the button to obtain your IP address automatically (ditto for the DNS server address.) Be aware that this changes how your computer interacts with other networks. If you need a static IP address on other networks, you may have to reset your IP address again later. However, your computer cannot connect to the library's wireless network unless it obtains its IP address automatically from the library's wireless device.
Make the Windows wireless configuration your default configuration?
In many computers, Windows acts as the default wireless network configuration program. However, if you have an external wireless card, or if your computer has a secondary program enabling it to connect to the wireless network, you may discover Windows will not recognize your wireless connection program and visa versa. Sometimes, if you have a non-Windows program that runs your wireless card (for example, a Linksys driver for an external Linksys wireless card), the non-Windows program will connect to the wireless device, but Windows will not recognize that this secondary program has connected. You will need to allow Windows to control the wireless configuration in order for your computer to fully recognize the wireless connection. On way to solve this problem is to tell the secondary program to "stand down," as it were.
On some computers, an icon for your secondary wireless program will appear in the lower right-hand corner of the taskbar on your desktop. You can click on this icon to open the program options. Certain programs will give you the option to switch to Windows as the default manager of your wireless connection. This will allow you to use the Windows Wireless Network Connections menu to make changes to your wireless connection.
May 04, 2010 | ASUS Eee PC 900HD Netbook
My adapter dosent work the light is red and cant find network to hook live up to
Try to uninstall the drivers from the computer. Plug in the device now into the computer, check the lights. If it gets rectified, download the appropriate drivers from internet and install or re-install the same drivers/
If same, try on a different USB port
If same, try on a different computer
If still the same, get it replaced!
Jan 08, 2010 | Microsoft Wireless Network Adapter Xbox...
Computer wont recognize cable hookup
You will have to start the configuration from the wired network rather than the wireless network. Connect the computer directly to the router. I am assuming you might be trying to configure the router from the wireless network. Then use the installation CD to configure the router
Nov 29, 2009 | Computers & Internet
Cannot find wireless network on Secondary computer
Try this, unplug the power from your modem, wait 25 seconds and plug it back in. Unplug the power cord from your router and wait 10 seconds.. plug it back in. Wait for the Wan/Ready/Internet light on your modem to stop flashing or go to its default position. Reboot your 2ndary computer. Try the internet again. If this does not help please post again and we will dig deeper! Good Luck!
Aug 30, 2009 | Computers & Internet
Second computer cant connet through the router..
You must reconfigure the wireless settings on the wireless computer. Go to Network and Sharing Center > Manage Wireless Networks. Now you must delete all the prefered wireless network profile there. If they are all deleted, click on ADD > Click Add A Network in range of this computer > Select the signal from your router and connect. If it asks you for a network key, you should know that, otherwise, contact your router provider to determine what your network key is. That should solve it.
May 06, 2009 | Computers & Internet
Wrong ip address
On the computer with the "private IP" - which Btw, means it cannot obtain a valid IP from your network - Assign manually an IP of: 192.168.1.22 With a Subnet Mask of: 255.255.255.0 and a Default Gateway of: 192.168.1.1 and a Primary & Secondary DNS Server of: 208.67.222.222, & 208.67.220.220 respectively. This should work for you.
gurutim
Mar 21, 2009 | Microsoft Broadband Networking MN-740...
Making a network
please answer all the question of lucentrip... for us to know how to handle such problem...
thanx
Jul 18, 2008 | Computers & Internet
Can't connect to the internet wirelessly
Well, to avoid confusion, I'd start by doing a factory reset. Insert the straightened end of a paperclip into the reset hole and power up the device to do this. From there, the device should begin broadcasting the default wireless network with the name (SSID) of "Motorola." The DHCP server should also be enabled and if your computer is configured to receive an automatically assigned IP address your wireless network interface should pick up an IP. The security for the "Motorola" network is disabled by default.
Basic troubleshooting from there would be to try to see if you can connect your wireless computer to another wireless network that is know to be working well. Either buy and return another wireless access point or router from a retailer or head to a Starbucks or other establishment that offers free wireless. If the wireless computer is hooking up nicely with the secondary wireless network, you can refocus on the SBG900 as the likely source of the problem.
If after attempting the aforementioned procedures you find that the wireless computer continues to fail to connect to the SBG900 you might have to consider that you have a faulty device. At that point I would consider consulting the manufacturer's documentation.
Apr 05, 2008 | Arris SURFboard SBG900 802.11g/b...
NetGear RangeMax WPN824 Router Logo
73 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
