Question about Toshiba 32A50 32" TV
How do i repair my toshiba 32" model 32DF45. it shows a white line across the screen
  • 647 Answers
In this case I think the vertical o/p IC is a AN5521?
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Oct 03, 2009
There are white thin horizontal lines across the top 2" of Toshiba 27DF47 TV. Can this be repaired and how much would this repair cost?
Check and replace all the electrolytic capacitors at its vertical output section circuit. There will be five or 6 of them. Replace all.
Mar 18, 2013 | Toshiba 27DF47 27" TV
32 INCH ZENITH PICTURE IN PICTURE ABOUT 15 YEARS OLD.PICTURE DISAPPEARED AND ONLY HAVE A THIN WHITE LINE RUNNING ACROSS THE SCREEN.THE SOUND STILL WORKS FINE. IS IT WORTHWHILE GETTING IT REPAIRED ??
When CRT TV's show only a white/bright line horizonatlly It is a failure of the flyback Transformer. Not all that costly to repair. Your old TV will probably still be working when all the latest plasmas and rear projections have been laid to rest. Fancy junk TV's dont get any better programs than those old reliable ones
Please rate my help++++Thanks for using FRIXYA
Aug 04, 2010 | Televison & Video
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
May 01, 2010 | Toshiba 32A33 32" TV
Same white lines on top of screen
you still go the warrenty on it
Jun 04, 2009 | Toshiba 32D46 32" TV
White line across screen
A white line across the screen is usually caused by a damaged/burnt out pixel(s) consult technical support for help, but you set is probably damaged beyond repair. I hope you have the reciept, my brother had a similar prob.
Apr 25, 2009 | Philips 32PF5531D 32 in. LCD Television
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
32A50
Vertical Output Capacitor
Take it to the shop, not very expensive.
Very heavy tv.
In home repair (armed robbery).
Nov 14, 2007 | Toshiba 32A50 32" TV
ILO 32"' TV as white lins across top
my ilo-2600 has lines across the top of the screen.
Nov 02, 2007 | iLO 2600 Television
Toshiba 32A50 32" TV Logo
201 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
