Question about Hayward H400idl2 400,000 Btu Low Nox Heater Natural Gas
Code is lo and 60 - Hayward H400idl2 400,000 Btu Low Nox Heater Natural Gas
  • 990 Answers
LO just tells you your temp is low. 60 tells you you have a gas valve or a ignition problem.
First check all your gas valves to be sure they are on. The one at the tanks or house, the one before the heater and the main gas valve inside the heater. If this does not help you should maybe get a pro to look at it since checking the ign module or the main gas valve involves spectialty tools and a very spefic knowledge. Good luck.
Posted on Dec 26, 2009
How to adjust a carburetor on a chainsaw
Depressing the throttle slightly we listen to the engine. If the engine hesitates to accelerate, the LO screw should be opened 1/8 of a turn. If we open the screw too much, the engine will not accelerate smoothly and start shaking (too rich of a mixture). In this case we should close the LO screw slightly. We repeat this procedure until the engine reacts smoothly when adding power. Meanwhile, a readjustment of the idle speed may be needed.
After the LO mixture has been adjusted, we proceed with the HI screw adjustment. After securing the paramotor, we open the throttle to full power. We turn the HI screw to the left or right until the maximum RPM is reached. From this position just a slight turn to the right should cause a significant RPM drop. This means the lean side of the mixture has been achieved. Immediately we OPEN the screw to the left to prevent the engine from overheating!
Let us repeat once again this critical step:
At full power we tune for maximum RPM, then we close the HI screw more, until a drop in RPMs is noticed. When the drop in RPMs occurs we open the HI screw again until we reach maximum RPMs once again, and then we open the screw more until we have a drop of 20 to 60 RPMs. In this position the carburetor will be perfectly tuned slightly on the rich (safe) side.
Next, we should close the throttle and recheck the idle and the LO screw adjustment. If the carburetor was tuned properly, the idle will return to the normal setting described above.
To put it in a nutshell, if the engine idles and accelerates smoothly, does not smoke heavily and achieves 20- 60 RPM below maximum RPM, the carburetor is tuned correctly.
Dec 07, 2015 | Garden
Model 3200. How should 3 adjustment screws be set(T,low and high for carb)?
Nov 22, 2015 | McCulloch Garden
I have a becker grand prix 7990 and it has a code lock on the radio. I cant enter the lock code, which I have. how do I reset the radio so I can enter the code
debes dejar la radio encendida sin tocarle durante 60 minutos, y despues ya te dejara introducir el codigo de nuevo, dandote 3 oportunidades, si lo pones mal, tendras que repetir la maniobra
Jun 08, 2011 | Becker Grand Prix 7990 CD Player
I have a Ford Ranger. After putting truck in 4W drive (low), it has stayed there. How do I get it out of gear?
what was the reason you shifted into 4 lo ? Alot of times the electrical connections under truck get wet or moisture in the plugs which causes electrical malfunctions which stop the operations of transfercase shifts. max speed is 25 in the 4 lo position. You didn't happen to try to do 60 did you?
Feb 08, 2011 | Ford Ranger Cars & Trucks
AC blows only hot even when therm is set at 60
try this key on engine off on the climate control panel press off and warmer buttons at same time until all displays are lit if systems have any codes they will be shown at this time.to clear bcm codes press and hold the off and lo buttons until F .0.0 is displyed turn key off wait 10 seconds start car see if a/c works
Aug 14, 2010 | 1992 Cadillac DeVille
We purchased the Vkidz Digital Camera Kit by Sakar International about a month ago. My son opened it, but we just now got around to putting batteries in it. The problem is that he lost the directions. I do...
Power Off: oF
Self Timer: St
Continuous Shot Mode (video): d8
3 shot Mode-C5 (or maybe its CS?)
Delete All-CA
Delete last photo: CL
Photo Resolution: HI/LO and
Compression: Hd/ Ld
The last two items above have to do with the amount of photos that can be captured at the relative resolution and compression settings before needing to download them to your computer. Here is a list of settings with the approximate number of photos each setting will give you:
HI--Ld=20 photos
HI--Hd=60
Lo--Ld=81
Lo--Hd=about 243 photos
Jul 08, 2010 | Sakar Kidz Cam Digital Camera
No enciende solo para traspasar informacion
Hola, este es traducida por Google Translate cliente.
Si actualiza el reproductor de medios digitales y sólo alcanzó el 60% en la actualización, el software (programa) piezas II y tiene que actualizar de nuevo.
Si no, puede tratar de explicar en otras palabras, de nuevo aquí.
Buena dias
lfete da DK
Mar 17, 2010 | Philips GoGear ViBE Digital Media Player
Tail light are not working
fuses under hood
POWER DISTRIBUTION BOX Location Name Amp Circuits Protected A Trailer Tow 50 Fuse 32/Fuse 26/Electric Brake B Fan (Hi) 60 Cooling Fan (CCRM) C Start 60 Starter Solenoid/Fuse 30/Fuse 36/Fuse 2 D Ignition 60 Fuse 6/Fuse 12/
Fuse 8/Fuse 18/Fuse 14/
Fuse 24/Fuse 20/Fuse 21/Fuse 27/Fuse 33 E Rear
Blower/
RAS 60 Rear Heater Blower Motor
Rear Air Suspension F Seat 60 Power Seats G — — Not Used H Fan-Lo 40 Engine Cooling Fans J Power Accessory 60 Fuse 13/Fuse 25/
Fuse 1/Fuse 31/Fuse 37/
Fuse 40/Fuse 7/Fuse 19 K Light 60 Headlamps/Fuse 10/
Fuse 11/Fuse 3/Fuse 9/
Fuse 23/Fuse 29/Fuse 35/Fuse 41/Fuse 17 L ABS 60 ABS Control/Pump Motor Module M Heated
Backlight 60 Heated Backlite/Fuse 16/Fuse 28/Fuse 22 N Fuel 20 PCM/Fuel Pump/CCRM P — — Not Used R PCM 15 PCM Memory S PCM 30 AX4S/Cylinder Identification Sensor/EDIS Module/PCM Power/EGR Control/HEGO's/IAC/
Injectors/MAFS/VMV T Alt./Reg. 15 Generator U Air Bag 10 Air Bag (Dedicated) V Trans. Light 10 Transmission Indicator Light W Fan 10 PCM Fan Monitor X Diode — Hood Lamp Diode Y Relay — RH Trailer Turn/Stop/Hazard Lamps Z Relay — Powertrain Control Module AA Relay — Windshield Wiper Speed BB Relay — LH Trailer Turn/Stop/Hazard Lamps CC Relay — Windshield Washer Pump Motor DD Relay — Windshield Wiper Dynamic Brake/Run
The fuses are color-coded by amp rating.
Fuse Value Amps Color Code 4 Pink 5 Tan 7.5 Brown 10 Red 15 Light Blue 20 Yellow 25 Natural 30 Light Green 40 Orange 50 Red 60 Blue
Mar 14, 2009 | 1997 Ford Windstar
Temperature control threshold too high
I have a solution. Let me buy it!! So you can replace it with something that works. I am looking for used
Holmes Heater ModelHFH5506 only and will pay top dollars.
Thanks,
Nov 22, 2008 | Holmes Products Holmes HFH5506-CN Heater...
Hayward H400idl2 400,000 Btu Low Nox Heater Natural Gas Logo
160 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
