JBL MCDC100 6-Disc CD Changer
Problem for JBL MCDC100 6-Disc CD Changer
2007 Toyota Camry Hybrid CD changer jammed, one
By harry_molwit on Oct 03, 2009
2007 Toyota Camry Hybrid CD changer jammed, one month out of warranty, dealer says $2500 to replace..., will not eject or load CDs
Comments:
Oct 04, 2009
- Pulled it out, one disk sitting on top loose, pulled it out, reinstalled device, sees no CDs in the device, but I know there are 3 in there, bah, would have pulled them all but it was starting to look tricky. Nippon Denso Thing Harry
Oct 04, 2009
- The detailed instructions here are for a different model Changer I think, but you inspired me to try anyway, I will get back to it another day.
Best Solution
posted on Oct 03, 2009
Helpful)
smarthome2
Rank: Guru
Rating: 88%, 338 votes
Take it to any local car audio shop, find out the make of the changer and chances are good that it can be fixed quickly and at a minimal cost or replaced with an aftermarket unit that will work perfectly with the factory radio for under 600 installed easily. Hope this helps
Comments:
Oct 03, 2009
- If you plan on doing the repair yourself, it's not that difficult, just remember to be patient and remember what you take apart, and where it goes. First thing to do is pull the changer from the vehicle and take off the top. It's usually only 4 to 6 screws. Be careful when you remove the top as there may be small rubber bushings on either side at the middle for transport support which have springs on them. Once the top is off, you will probably see immediately what has happened to cause it to jam. The most common is two discs in one slot of the cartridge, if you gently pull the disc back out toward the tray then plug it back in, chances are good it will cycle and free up your disc. Now, eject your cartridge and inspect it for bends or warps, if it is warped or bent, replace it. If not, use some compressed air and dust out the inside GENTLY hold the can 12 to 13 inches from the boards and dust it out. Then, use a "Laser Lens Cleaner" and run it for two or three cycles. Re load your cartridge and test. If all is well, load and unload the cartridge a few times then re assemble the unit, and re install the top. Your good to go. Hope this helps.
Oct 04, 2009
- If you get stumped on any part, post a comment and I will help you further
Was this helpful?
Yes
No
3 people thought this was helpful
Asker's Testimonial
" I think I will attempt a fix myself first. " - harry_molwit
Popular Solutions for JBL MCDC100 6-Disc CD Changer
Questions and Unsolved Problems for JBL MCDC100 6-Disc CD Changer
Do you recommend JBL MCDC100 6-Disc CD Changer?
Answer
Answer
i have a mercedes clk 320 with a 6 cd player. the casette will not eject or play
Answer
2000 camry single cd player has cd stuck inside --won't play or eject
Answer
07 toyota avalon 6 disc changer wouldnt eject until i shut the car off,it continously said wait,... (More)
Answer
error 3 on a Avalon jbl stereo CD player , it takes the CD in and spits it out before the code is... (More)
Answer
stereo doesnt show anything it has power and it lights up but doesnt show anything on the screen
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For JBL MCDC100 6-Disc CD Changer:
Top Car CD Changer Experts
Rank: Guru Guru
Solutions: 14902
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car CD Changer Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
