Question about Kenmore Vacuums
How to open 116.23512301 vacuum canister AC section to wire in replacement 4370608 cable assy. This assembly contains the receptacle that powers the hose. I found the two screws below the bag cover, but can't figure out how to release the end near the retractor lever.
SOURCE: kenmore progressive canister Sweeper
I figured it out ..by pushing the lever down and pry a screw driver into three different spots on the top, to release the rewind bar. Looks like three little j hooks hold it down. It took a flashlight and night time for me to see it.
Posted on Mar 20, 2008
reddevil6
  • 1673 Answers
SOURCE: can't figure out how to replace the bag
Open the hood, bag #20-50557 , the cardboard part goes in the bag holder, will only fit in one direction, then close the hood.
Posted on Jun 22, 2008
SOURCE: model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Model 116 hose clog?
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
advacak
  • 125 Answers
SOURCE: kenmore 116 bagged canister vacuum
something is jamming the brush roller, or the bearings are seised
Posted on Dec 03, 2008
SOURCE: Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Posted on Mar 27, 2009
How do i put the wand back together on a rainbow e-series ?
The wire schematics in the handle assembly has four total wires. Two from the hose and two from the Receptacle Nozzle. Take one wire from the hose and one wire from the receptacle and connect together. Take the second wire from the hose and connect to the Switch Handle PN2E PN2. Take the second wire from the receptacle and connect to the other switch terminal. If you need more details, you can download the schematics at Rainbow Vacuum Schematics or you can call us at 800-523-0510.
RainVac
www.rainvac.com
May 30, 2014 | Rainbow E series Canister Wet/Dry Vacuum
Brush won't spin on my shark navigator.
Maybe not the same issue, but my roller brush would only work intermittently. I had to take apart the main housing and clean the two contacts (female side) that connect to the lower brush assembly. Now it works like new.
Oct 30, 2011 | Shark Navigator Bagless Upright Vacuum
No electrical continuity on one lead in hose. Cause is probably in the wiper assy. How do I disassemble hose ends to check electrical connections without breaking or cutting into plastic parts?
We have here the user manual. The page 8-9 you will see the instruction for replace the power nozzle which shows how to desmandle the vacuum and you will find the power cord connetion point. A big advice use your camera to take picture every step you make and especialy before remove the wires since in any case you will forget anything when you will try to assemble it back they will bevery helpfull.
Aug 06, 2011 | Hoover S3670 Bagged Canister Vacuum
Vacuum will not come on even though power switch is on.
Rainbows draw a lot of power. It may have tripped the circuit breaker for the receptacle you have it plugged into. first make sure the receptacle is ok, especially if it is plugged into a ground fault receptacle. . Next, unplug the vacuum, take off the tank and see if you can spin the impeller by hand. If you can spin it, the motor is free. If plugged into a good receptacle and the power cord is not cut or broken and still does not run then the motor is bad. it could be the brushes in the motor(which can be replaced), or the armature is shorted out, meaning you need to replace the motor.
Jan 17, 2011 | Rainbow E series Canister Wet/Dry Vacuum
No power
The most common cause of this problem would be breakage of the wires in the power cord at the point of entry to the vacuum cleaner body. With the power connected you may be able to prove this by flexing the cord at this point, particularly by pushing the cord toward the body of the vacuum cleaner. If you get any signs of life from the vacuum cleaner you can know that this is the issue (not a foolproof test, but one that can be performed safely, provided that there is no visible damage to the lead).
A qualified repairer will ensure that the vacuum cleaner is not plugged in to the power, open the vacuum cleaner casing, note the wiring connections, disconnect the wiring and and strip the external sheath of the cable back to a point beyond the breakage, cutting off the damaged section of wiring and reconnecting the wires.
See also: http://www.vision6.com.au/em/message/email/view.php?id=638671&u=19329
Mar 10, 2010 | Numatic Henry Bagged Canister Vacuum
On the DC07, the entire cyclone assembly must be removed to empty the dust, debris, etc. collected when vacuuming. On the top of the cyclone is a "trigger" that you lift with your finger to release the...
Beofre you go to the extent of buying a replacement canister, you can remove the top and using a straightened coat hanger type thing open that bottom lid. Then maybe you can clean the rim and possibly add some silicone spry to loosen things up. Here's how to get inside In this order: 1) Remove the canister 2) remove the three star screws at the top of the canister. It'll take a bit of pressure to pull the top up, there's a rubber seal. When you pull it up there will be a rod running down into the canister, leave it be, just pull up the top high enough to clear out any debris. 3) Use a straightened coat hanger and with a flashlight to guide you, reach down with it and push it into that hole down at the bottom center of the canister. That will pop the lid open. Clean the canister & lid rims, maybe add some silicone. At this point you might as well clean the canister too. OPTIONAL-> ***leave the bottom lid open*** and follow the rest of these steps 4) Put the top back on aligning the screws, when you lower it make sure the bottom of the rod engages with the hole at the bottom center of the canister, this is why you left the bottom lid open. Put the three star screws back in. 4) Turn the canister upside down, lid open, and keeping in mind this is thin plastic, gently tug upwards on the four fins that surround the bottom rubber seal. This part is held in by friction, so work your way around the four fins gently pulling until you work the ring they're connected to free. This will give you access to the inside of the canister. 5) remove the round perforated section by tugging upwards on it, set it aside with the fin part. 6) Take the canister to a laundry tub or large sink and holding it bottom up fill it with hot/warm water. Grasping the center section shake it vigorously and turn it upside down while shaking and a bunch of sh*t will come out. Repeat several times. 7) Dry thoroughly, you might use a hairdryer held to the center tube, but only if you can switch off the heat and use air only. Make sure its 200% dry, water will kill your machine 8) clean and replace the round perforated section 9) replace the fin section, I'd suggest pulling the round rubber part off of the fin part and setting it in place on the canister first, then follow with the plastic fin part. If you don't do it this way the rubber won't seat properly and the bottom lid won't close. 10) Close the lid, replace the canister, and staaaaaart suckin like it's brand new.
Jan 10, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson DC05 has been playing up for a while. The motorhead would start fine with green light on and after a few minutes would stop and light would go green. then the power would go on and off - seemed to...
as the wires that control the motorhead run all the way down the hose it is a break in the wires you will need to buy the hose assy sorry its not thesort of thing you strip down and repair
Oct 05, 2009 | Dyson DC05 Bagless Canister Cyclonic...
Bottom of dirt container doesn't stay closed
The catch/latch that is on the bottom of the bin button release has likely broken.
If you take out the canister (as when you are dumping the bin), and flip it upside down and then squeeze the bin release button, you will see that it moves a rod inside the cyclone assembly.  At the end of this rod is a plastic (plastic.. redundant, as the entire Dyson is practically plastic) latch that catches onto the bin's lid and locks it in place.  A broken latch means it doesn't lock the lid in.
What you need is a replacement latch.  Note that the "Bin Release Button + Rod assembly" that are sometimes sold on ebay do *not* contain the latch at the end of the rod.  Also the bottom bin assembly does not contain the required parts.
The cyclone assembly should have the full bin release rod + latch, so if you can't find the latch, then a new cyclone assembly would work also (but will cost more, obviously).
Oct 09, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Agitator brush not working
I went ahead and ordered a switch and wire harness from Sears Parts online(using repair parts list that came with vacuum cleaner) which cost me about $45.00 including shipping. After receiving the parts I first tried replacing the switch and no difference. Then I changed the wire harness that contains the receptacle where the plug from the extension wand plugs in. Sure enough, that solved the problem! Apparently the plug receptacle was worn out causing the short. It took some effort to get the Handle Assembly apart and then back together; however, I did it and broke nothing! I am so stoked as I know I probably saved at least $100.00 by doing this myself!! And if I were to send the switch back, my cost would only be about $30.00!
It is amazing what a person can do when using the parts list that came with the appliance and the internet to order parts!!!!
Sep 25, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Hoover s3755 bagless windtunnel canister
Very likely it's the cord at the nozzle neck. These cords flex when you vacuum and they often break internally where the cord goes into the neck. Turn the vacuum on and wiggle the cord at the powerhead and see if the powerhead comes on and off. If this happens, then you will have to replace the cord.
On some of the early models, the receptacle in the hose, where it plugs into the top of the wands, will break away from the plastic pins it sits in, and the receptacle will slide back into the handle, which means that it will not plug into the powerhead connection when you connect the hose. You can check this by looking at the end of the hose and observing if the receptacle is sitting flush with the opening it sits in. If it is pushed back, it will not make a complete connection with the powerhead cord that is sitting at the top of the wands.
Jan 18, 2008 | Hoover S3755 WindTunnel Bagless Canister...
Vacuums Logo
134 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
