Question about Dell V305w All-In-One R840635AU InkJet Printer
My Grandson pulled out the cartridge carrier guide.(looks like a long piece of Teflon with a hole on each end. It has an arrow on one end and two sets of numbers at the other. top set 1-01 bottom set 1pm325223.) I just need to know where to reattach it.
How to change string?
If you look at the bottom of the string holder (flipping the machine over) there should be either two tabs on the side across from each other that you press and pull, OR a twist and pull. There are several pieces, the inner piece that the string comes on has a hole that the string goes into to hold the string in place (needle nose pliers--press into hole). Then there is an arrow on the string holder, just wind the string in the direction of the arrow (does not have to be perfect) until you get enough on the holder. Now, hold the string so that the spool does not unravel--feed the end through the hole(s) and replace parts as they came off of the trimmer.
I hope this helps.
Feb 09, 2016 | Garden
Brother mfc-7340 tooner life end
1) Pull out the cartridge and look on the right side of the it. You will see a small hole that has a glass like window in side (round window).
2) Turn off MFC-7420
3) Cover the hole on cartridge with a duct or a piece of paper. Basically block.
4) Replace the cartride back in the printer and turn on the printer.
5) The message should be gone and you should be able to use the copier functionality.
It worked perfectly.
May 30, 2011 | Office Equipment & Supplies
Hi - E5 - Part popped out
Turn off and unplug the printer and slide the cartridge carriage over by hand. You could remove the cartridges. Then after reconnecting the cable, slide carrier back by hand and reconnect the power.
Jul 17, 2010 | Canon PIXMA MP160 All-In-One Printer
How to install ink
Here's a link to the Lexmark website to guide you on how to install/replace the cartridges on your Lexmark printer. http://bit.ly/cevMS4. The printer shown may not look exactly like your printer, however, the steps are the same. But, there are cases that the cartridge carrier doesn't move to the center when you lift the scanner unit. If that happens, unplug the printer from the power source. With the scanner unit lifted, hold the solid white tape you see inside the printer. The other end is connected to the ink cartridge carrier. Slowly drag the carrier to the center to remove the cartridges and install the new ones. Close the covers. Close the scanner unit. Plug printer back to power source. Let it print the alignment page to align the cartridges. Hope this helps.
Apr 27, 2010 | Lexmark X6650 4-In-One Wireless InkJet...
How do I spool new line onto this unit? It has a dual feed. Craftsman Weedwacker 17"/25cc
look on the bottom of the spool and see if there is an arrow point stamped on the outside of the spool, then check if there is an arrow point stamped on the inside of the spool. If so line up the two arrow points and cut two pieces of line about 3ft long. Insert one line into the hole where line comes out and push it until it comes out a little hole on the bottom of the spool. Pull some out and there will be a very little hole (the size of the line) beside the bigger hole insert the end of the line into the smaller hole and then pull it tight. Do the same for the other side. Then twist the spool (like you did to align the arrow points) stop when you have enough line out to reach the line cutter.
Jul 27, 2009 | Craftsman 25cc Gas Line Trimmer
Blinking orange arrow to three green boxes
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | HP Deskjet 6940 InkJet Printer
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Carrier Jam
THis solution I copied from another post. It worked for me as well
First you need to open the printer. Unplug from power. Then lift the scanning device, you can partially remove it when pushing the "hooks" close to where the lid is connected (careful with the cable connections). Then remove three screws in the cover of the bottom part and with some fiddling around you can remove the cover. Again be careful with the cable connections. Of course don't do it if you are worried about warranty or breaking the printer.
The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging.
Success
Jul 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
Carrier jam Lexmark 4300
I had this same problem, I found a long skinny thin plastic strip had fallen off & caused the problem for me. The plastic strip has slits at each side to attach to the inside back of printer, on the left side is a down ward facing arrow, the plastic strip feeds through the back middle of the cartridge carrier and then the slits are to be inserted to the metal tab like pieces on the back sides inside the printer on the right side (facing printer) it will look like a small rectangular hole with a longer metal tab like piece sticking out & on the left is a smaller squared like hole with a flat smaller metal like tab which will line up if the plastic strip is feed through the back of the cartridge carrier properly. This should allow the cartridge carrier to glide properly & work as it should, with no more banging! Sorry my tech. terminology isn't good, I am not Knowelegable with this sort of thing, just sharing my experience :) HTH!
Jan 14, 2008 | Lexmark P4350 All-In-One InkJet Printer
Dell V305w All-In-One R840635AU InkJet Printer Logo
100 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
