Question about iRobot Roomba 560 Robotic Vacuum
My roombas side spinning brush won't spin what do i do and I have already replaced it with a new brush
  • 5 Answers
SOURCE: Brushes not spinning....
My status light came on, the vac beeped twice and stopped. I noticed my brushes weren't spinning. I took an eyeglass screwdriver and took off the center screw that holds on the brushes. I cleaned the shaft that the brushes spin on. replaced brushes and it works great! I just did this now and it is still running. my status light problem is fixed my roomba is 4 years old and I am on my 2nd battery. Seems to have fixed the problem. FYI it was wrapped with hair, dirt and it was greasy.
Posted on Jun 18, 2008
  • 61 Answers
SOURCE: side brush spins but bottom brushes do not.
Try the troubleshooting found <a href="http://homesupport.irobot.com/cgi-bin/irobot_homesupport.cfg/php/enduser/std_adp.php?p_faqid=740&p_created=1219768911&p_sid=GEKRRrzj&p_accessibility=&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NDcsNDcmcF9wcm9kcz03ODgmcF9jYXRzPTAmcF9wdj0xLjc4OCZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX25sJnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9YnJ1c2g*&p_li=&p_topview=1&prod_lvl1=788&prod_lvl2=&prod_lvl3=&prod_lvl4=&prod_lvl5=&prod_lvl6=">here.</a> If that doesn't work, call customer support for a new cleaning head module. 1-877-855-8593
Posted on Jun 03, 2009
  • 61 Answers
SOURCE: irobot roomba 570 brush not spinning
Unscrew and remove the side brush. There is probably a wad of hair and dirt underneath it that's keeping it from spinning. When it's clean, *snap* the brush back on, then screw it into place. If it still doesn't turn, you'll need a new module. Call support: 877-855-8593. Good luck.
Posted on Jul 06, 2009
blkadder
  • 7 Answers
SOURCE: irobot roomba brush only spins on hardwood/tile.
With the unit turned over, when you spin the brushes by hand, are both turning together? If not, there is probably problems in the brush deck gears.
If you cannot get the unit fixed under warranty, check with the people on www.robotreviews.com. There are many people there who are willing to help out.
There is even one guy on there who fixes them up pretty cheap.
Posted on Oct 01, 2009
SOURCE: Brush won't spin on my Hoover Mach 5
Snorr, I just had to thank you. You saved me alot of time, money, and frustration!!!
Posted on Mar 13, 2010
Why isn't the side brush spinning anymore?
It sounds like you need to get a new brush motor. They are modular and easy to replace.
May 05, 2014 | Roomba 780 Robotic Vacuum
Roomba 540 brushes are clean, properly installed... but not spinning. machine is telling me to "remove and clean roomba's brushes."
I think I can guess what the problem is - exactly the problem I made with my roomba when it was new: I didn't realise that the bearing came off the end. Is the end of your brush assembly yellow? If so, it pulls off. I'm going to take a flier and guess that you didn't know that, and your bearing is jammed up with hair. This is what the bearings look like:
Make sure they spin freely!
Feb 22, 2011 | iRobot Roomba 540 Vacuum
Side brush? Main brush? both? How did you find that they are not spinning? To properly test, place the front wheel on the table edge and hold the wheels up in the machine (dont hold the tires) , Then start the clean mode.
If it doesnt spin then you need to open the roomba and remove the motor to see if it is just binded up with lint. If the motor spins with your fingers then test the motor with a power supply to see if it is possibly burnt out. If it works on a power supply then your issue is on the main board and it needs replacing.
Jul 09, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
The side brush on my Roomba will not spin. I just got it April 16th 2010
unscrew the brush see if hair ect. is wrapped around.if not may need a new motor
May 20, 2010 | Roomba Robotic Floor Bagless Vacuum
Irobot roomba 570 brush not spinning
Jul 02, 2009 | iRobot Roomba 570 Robotic Vacuum
Side brush spins but bottom brushes do not.
Jun 03, 2009 | iRobot Roomba 560 Robotic Vacuum
No suction on Roomba 560
Larger debris is usually the responsibility of the brushes. Remove the bin and run the Roomba-- are the brushes actually turning? If not, call customer support for a new cleaning head module. If so, remove the grill from the back of the bin. Make sure that the little fan inside is clean, then reinstall the bin on the Roomba and run it. If that little fan doesn't spin, your Roomba has lost vacuum suction and you need a new bin.
Jun 02, 2009 | iRobot Roomba 560 Robotic Vacuum
Roomba 530
The horizontal spinning side brush is a known failure item in those units. Chances are the side brush motor has gone bad. Check first to make sure that the motor isn't just bound up with hair or something.
Fortunately, it's easy to replace and relatively inexpensive.. See this video link on iRobot's site: http://www.irobot.com/hrd_right_rail/roomba_rr/roomba_fam/RoombaFam_rr_howitworks.html
Click on the bottom link in that video to see how to remove the bottom plate and remove that side brush motor with just 2-3 screws. New motors are available from iRobot for $15 or from places like www.RoboticVacParts.com for ~ $10 links here:
irobot:
http://store.irobot.com/product/index.jsp?productId=2822991&cp=2804606.3358508&ab=CMS_AccSuper_Roomba500_102308&parentPage=family
www.roboticvacparts.com
http://cgi.ebay.com/NEW-Roomba-500-Series-Side-Brush-Motor-510-530-550-560_W0QQitemZ270399677877QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef513a5b5&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Jan 19, 2009 | iRobot Roomba 530 Robotic Vacuum
May 29, 2008 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot Roomba 560 Robotic Vacuum Logo
276 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
