Question about Panasonic CT-36SX31 36" TV
My set wont turn on either manually or with the remote
  • 647 Answers
Common Fault:
In this case it's likely just a fuse - main fuse in power supply (6.3A 250V)
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour
Posted on Oct 03, 2009
How can i turn on my panasonic quintrix television when it wont work manually and i have lost the remote
If the set was powered OFF with remote control; last time, it won't power ON without pressing the Power button on the remote control. It is clear that you should have a remote control to power it back ON.
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Aug 17, 2014 | Televison & Video
Tv power lock is on and it wont turn off
http://static.highspeedbackbone.net/pdf/AOC_L24H898_Manual.pdf
Try the above link to download the manual.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
Mar 24, 2014 | AOC L24H898 24 in. LCD TV
Hello, I have a TOSHIBA 36" Model # 36A43 and it will not turn on.. the past few weeks i have been experiencing problems with the remote.. like not turning off the TV or the volume. Once in a while it
The manual power button ought to still turn the set on and off even if the remote is bad or not working.
I suspect you have two problems but there is a tiny chance only one as the front buttons and the remote both go to the same place in the set but here the front buttons have priority.
Dec 04, 2012 | Toshiba 36A43 36" TV
Just opened up a panasonic TC-L32C3 from its box, pluged it in and the remote (with brand new batteries) wont turn it on. I am able to turn it on manually and went through the initial on-screen set up...
Yes,the tv manual controls board infered signal light from the LED diode,to the tv have problems.Take the tv back where u bought it and exchangce it for another new tv.
May 21, 2011 | Televison & Video
I need to know how to switch the tape speed from sp to the long play setting without a remote. the universal remote i have wont give me the option. it records only 2 hours on a 6 hour tape instead of 6...
Normally this setting is found on the remote if there is no parallel settings on the panel of the set.
So if youhave lost the remote controller the universal remote must be changed to one which can select the speed settings. Normally the default settings is on the SP mode while the LP mode needs to be selected.
The other option is to identify the trigger of the main processor and use a manual switch to turn on the LP mode. Check for the manual of the set and look for the LP output pin of the processor.
Here the SP mode output also must be taken into consideration so that you can use a manual 4pole two way switch to activate the SP-LP mode.
Otherwise you may need to get the original remote control from the OE maker.
Jan 03, 2011 | Televison & Video
I have a conia YKR-F/06 air con & my remote wont work, can u turn it on from the unit itself?
Some units having manual button in unit itself. But you can't change temp setting or mode setting by that. It's advisable to get new remote and operate this. Thanks.
Dec 31, 2010 | Heating & Cooling
My Dish Network Remote will not allow me to...
go to page 19 of your manual (for the E-Z remote) or here "http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/EZ_Remote_Manual.pdf"
(if you don't have the manual)
or to here "http://www.dishnetwork.com/support/documents/receivers/default.aspx" if you have a different remote.
basically, turn your TV on, then you press the antenna button for about 5 seconds until the TV button lights, then use the channel up/down buttons to find the code (the TV will turn off when you find it) hit the TV button again to turn it back on, then hit mute to set the code! good luck!
Feb 17, 2009 | DISH Network IR Remote Control
Programming my rca universal remote for basic cable the stations wont turn
I can only suggest that you Double check you have the connections correctly set ie. coax ariel to ,(dvd /digi box reciever ect...)
Also check again (& i know this is state the obvious)
your tv manual. IF you havent a manual do a google search for your tv (make & model) & search for a manual.
Ive have had a simmular experience when programming channels to a Vid-Recorder & when i finished the channels dissapeared.
I realised I didnt have the video set to the correct channel with the tv usually channel 9 or the highest channel on the tv.
So i waisted a good half hour for nothing.
Dec 09, 2007 | RCA Universal Remote Control
TV won't turn on
If the TV wont go on with the manual button on the front panel, then you have an issue with the tv set. Try a differant wall recepticle. Or unplugging it overnight. If it wont go on with the button on the front of the set after this is tryed, then its time to go to the repair shop, as the set has a power supply problem or a problem in the HI voltage/sweep circuit. Good Luck
Jun 17, 2006 | Sony FD Trinitron WEGA KV-27FS320 27" TV
Panasonic CT-36SX31 36" TV Logo
141 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
