There is a fan in the freezer, in the evap area. If fan is not working (check by opening door, holding in on door switch(s) and wait a few min. and see if it come on) then either fan is shorted or ice buildup is blocking fan blade.
This refrig has a problem at times with defrost heater, check this by seeing if there is frost buildup on rear inside wall of freezer. I would suspect that this is your problem. If frost is building up on rear wall then no air will circulate within freezer or frig.
Greetings,
This freezer coil is likely froze over. this is because its stopped its automatic defrost. The thing to do is remove freezer panal and see if evaporator is froze over. if so, derost it..this will give you temp service. there is a fan midway in freezer..its possible its not running as well and this is the problem. see if fans coming on while you have it apart.
