Question about HP Pavilion dv5-1251nr Notebook
My laptop's screen is not working properly. Sometimes it stops working for a second, it stays grey, like a bad TV conection. I don't know what to do. It's a HP pavilion dv5-1251nr. Usualy it happens for less then a second, but it is starting to happen more often, and the last time it did, it lasted almost 5 seconds... I though it stop working for good.
  • 56 Answers
Try hooking it to LCD or external monitor if working then,buy a new LCD with removal instructions on Ebay.
www.ebay.com
If the external doesn't work buy a motherboard on ebay
Posted on Oct 12, 2009
The tv was giving as a gift in 2012. So I believe that I put the right model in. I was watching the tv and went to change the channel, when I noticed that the box with the channel number looked differ
Your symptoms point to the main board [the board with all the input connections], no simple fix, you must replace the board. Less likely the keypad is bad, just unplug the keypad and see if channel display stops popping up.
Oct 21, 2014 | LG 32LD450 32 In. LCD HDTV
Random White screen On PB LCD 22inch
When the screen glows grey/white, it means that the T-CON board is bad or it is not getting the 5vdc from the logic board. or loose conection on the T-CON board which is part of the LCD panel assembly.
Does it look like this when it goes out? Checkto see if the 5vdc goes away when it goes out, the 5vdc is supplied through the switched transistor on the logic board..
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Jul 02, 2010 | Soyo 19" LCD Flat Panel Monitor
Black screen
If the light stays on for longer than about 20 seconds, try moving the lid back and forth, try positioning it in every possible way. If you get an image, even for a second, you need a new LCD cable. If nothing happens, try to get your hands on an external monitor. Plug that bad boy in, if you get the image, you need either a new LCD cable or a new LCD screen. If still nothing happens, then you probably need a new motherboard.
Before you go buying a new MB/LCD/LCD cable, which can be rather costly, open up the back and make sure the RAM is seated properly, sometimes something can jar RAM sticks loose.
P.S. DON'T FORGET TO VOTE
Apr 15, 2009 | Acer Aspire 5050-3371 Notebook
My hp laptop will not boot up
Check the power supply for power. Replace if necessary. Also check the motherboard for proper operation. If no fans come on or only come on for a few seconds then you have a bad motherboard
Feb 14, 2009 | Computers & Internet
No signal when connecting PC to TV
This happens to almost every laptop I know. Here are several solutions:
1. You need to manually enable video on tv by pressing two buttons on your laptop keyboard. The first is "Fn" (at the left bottom). The second depends on your laptop manufacturer. Look at the function keys. F1....F12 for the LCD/CRT or the corresponding sign. Press and hold Fn and press second button. Sometimes you need to press second button several times. This means you need to cycle through all available options to enable Laptop's screen and TV screen at the same time (clone).
2. Intel Extreme Graphics video cards sometimes doesn't support a procedure described above. You need to find intel video card options manager running at the sys-tray (right bottom of your screen near the clock). Right click on it. Select Graphic Options -> Output to -> Laptop + ... clone (or something similar)
Note that not all video cards are capable of showing the movie on media player at the same time. You need to choose Laptop or TV
Feb 07, 2009 | Vizio L32 32 in. LCD HDTV
My computer turns on sometimes the quickly goes blank. Other times, the On light comes on but the screen stays black and nothing seems to be moving inside.
try to desconnect or unplug your hard drive, if you see a black screen with a bunch of white letters, you hard drive is crashed, if not try to conect a second monitor (external) tru you vga connector, if work fine you have a lcd problem===>>>reemplace asap.
Dec 02, 2008 | Compaq Presario 700 470024-192 Notebook
Finepixz20 digital camera
That is actually the exact same thing I am experiencing but mine has grey lines on the display window. I was able to take photos to a grey screen connect it to my comp...low and behold my pics showed....I am furious....need some answers as I will never hear the end of it from my daughter.
Grrrrr
weelassy
Oct 20, 2008 | Fuji FinePix Z10fd Digital Camera
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Sanyo Flat Screen (DS27910) "Grey" Screen
dont know for sure but i think that the tube is going bad. Have one in my shop doing almost the same thing.Taped on the tube and it does strange things. My tube tester wont test this kind of tube that is in these sets.Not much help but it is a start.
Sep 17, 2006 | Sanyo DS27910 27" TV
HP Pavilion dv5-1251nr Notebook Logo
189 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
