Question about Kenmore Washing Machines
We have a Kenmore front loading washer, model 417. We are getting a door open error code even with the door closed. Any suggestions?
    Scholar:
  • 31 Answers
This could be one of two things. The actual door lock assembly there is something malfunctioning with the part that the striker goes into or that the control pannel is not registering that the door lock is actually closed. One is a $60 fix (the door lock) and the other is approx ($250). Unfortunatly because they are both electronic parts you can't just buy the cheap one put it in and if it doesn't work return it. Most stores have a no return policy on electronics/electrical parts.
Posted on Oct 03, 2009
My Kenmore front load washer will not fill--it sounds like it is draining instead. The last load washed did not spin correctly and the clothes were very wet when cycle completed.
Washer Not Filling:
  • Door Not Closed and Locked
    • Front load washers won't fill if the door is not closed and locked. Listen for the door locking when starting a cycle, then pull on the door to make sure the door is closed and locked.
  • Delayed Start Feature
    • Some washers have a delay prior to filling, where the electronic control is checking the dispenser function. This is Normal.
  • Flashing Lights or Error Code on Display
    • When there is a filling issue, the washer may shut off and display one of the following codes: LF, LE, nF, IE, FH, E10 or F20.
    • If the washer is displaying one of the above error codes, then do the hard reset procedure listed below.
If the appliance is not accepting input from the control panel, follow the steps below to reset the control:
  1. Unplug or turn the circuit breaker off for 30 seconds.
  2. Plug the power cord into the wall outlet or turn the breaker back on and wait 30 seconds.
  3. Press the Pause / Cancel / Stop button twice to clear the display.
  4. Start a short cycle, to check operation of the appliance, by selecting a cycle and pressing and holding the start button until the appliance starts.
Oct 15, 2012 | Kenmore Washing Machines
Front door would'nt open on my kenmore tumble action washer model #417
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 21, 2010 | Kenmore Elite 45986 Front Load Washer
I'm getting an F26 code on a Kenmore Elite he5t front load washer
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
We are getting an error code ddo on our wahser?
The DDO error is telling you that the detergent door is open. This error occurs when the detergent door has not latched properly when the unit is started.
There is a sensor that is dependant on a magnet, that is attached to the door, to trip it and send the proper door closed signal to the control oard. If this magnet comes off, or loose the signal will not be sent to the control board, and the error code will be displayed.
Now for the bad news. The magnet is in such a position that a considerable amount of labor is required to replace it.
Unless you are mechanicly inclined and handy with a box of tools I do not recommend that you attempt this repair. It is very involved and is not a DIY repair. It is best to let a tech handle this repair. An approximate price range for this repair is $175.00 to $275.00, or more depending on where you live.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Jul 27, 2009 | Kenmore 43142 Front Load Washer
Door opens on the wrong side
Usually not. If you can you will need a door kit from sears. But in most cases the manufacture does not want to mess with the doors seal, so they dont offer a change.
Jan 24, 2009 | Kenmore 44072 Front Load Washer
My kenmore front loader model 417 will not start
You have to replace the door lock(switch its all one unit) This will fix it.
Nov 16, 2008 | Kenmore 44102 Front Load Washer
F26 Error - Door Switch?
when you hear clicked can you open the door?its should be locked...
Oct 12, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Washer's tub will not move
I don't know what the E5E error code refers to but I can think of at least one possible reason for no motor action, even if motor itself is ok and board has been replaced. The relay itself could be faulty with no power from the output side, even if it clicks on. Less likely but still possible would be a faulty overload protector at the motor.
Feb 16, 2008 | Kenmore 43042 Front Load Washer
Washing Machines Logo
82 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
