Question about HP PhotoSmart 7550 InkJet Printer
How can I change the resolution to 600 dpi or better, if possible?
3 Suggested Answers
pagebor
  • 2785 Answers
SOURCE: computer life
plz reinstall the driver if the problem is not solved then scan your pc for viruses by disabling the system restore
Posted on May 24, 2008
  • 142 Answers
SOURCE: Hi I need to know
go to the printer properties, go to advanced, then go to printing defaults then choose the DPI as u wish.
Posted on Aug 25, 2011
Tip
LPI, PPI,DPI conversions
Here is a conversion chart for DPI (Dots per inch) to LPI (Lines per inch) or PPI (Pixels per inch)
180 DPI................31 lines/inch or 68 PPI
360 DPI................63 lines/inch or 138 PPI
720 DPI................127 lines/inch or 280 PPI
1440 DPI..............255 lines/inch or 561 PPI
2880 DPI..................510 lines/inch or 1122 PPI
If you plan to enlarge your image, it is better to enlarge it when you're scanning rather than in your application. Each time you modify
an image, you lose some quality. Keep in mind when you enlarge a small photo, such as a 35 mm slide or wallet-size photo, you'll need
to scan at a high enough resolution to retain your image quality, but not so high that your file size is too large to be efficient. You must
manually adjust the resolution (dpi) to maintain the same image quality when you resize your image. For example, if you have a 300
dpi 2 x 2-inch image that you want to enlarge to 4 x 4 (a factor of 200%), increase the Scale setting to 200% or change the resolution to 600 dpi.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Which laser printer is best for screen/butter prints for extra dark black print outs ?
Dear You can choose any printer having printing resolution more than 600 DPI. For screen printing the jobbers prefer for resolution from 300 DPI to 600 DPI.
Thanks.
Jan 14, 2015 | Laser Office Equipment & Supplies
I scan alot and am told that the itmes I scan are not very legiable. Also it is squealing a little.
You can start with better quality originals. You can increase the resolution to 400 dpi, 600 dpi. The file sizes will be bigger and would require more time processing.
Jan 09, 2014 | Visioneer 9450 Flatbed Scanner
Halftones on Oce Variolink 2822C all in one copier
Unfortunately for you, as color copiers have gotten better, so have the dpi, and there is no low resolution. Have you tried changing the resolution of your original file in an image program like adobe.
Jan 29, 2010 | Office Equipment & Supplies
How print 300x300 dpi image in CANON 2900B??????
Resolution
True 600 x 600 dpi
AIR (Automatic Image Refinement) 2400 x 600 dpi equivalent
Sep 13, 2009 | Canon LASER SHOT LBP-2900 Printer
300 dpi in canon 2900B
I cannot understand how will print picture 300x300 dpi in CANON 2900B. There is solution but not working.....
How do I adjust the darkness of the printing, it is currently set at 2 out of 4 darkness?
You will need to follow below process.
Print quality settings always affects on print resolution and toner usage.
to change print quality setting:
1. go to Start/settings/control panel/printers
2. then go to printer's properties.
3. go to paper/quality TAB. and select the setting that you want to use. you will get following options.
a) 1200 dpi: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
b) 1200 dpi effective output quality: This setting uses ProRes 1200 to provide fine-line detail at 1200 x 1200 dpi.
c) 600 dpi: This setting provides 600 x 600 dpi output with Resolution Enhancement technology (REt) for improved text. (this is what you may need to get)
d) Economode: this settings use less toner of your printer. This is useful for mostly draft printings. You can turn this button on freely of other printing-quality settings.
Select the needed settings. Test a print.
And if it is perfect you wont be charge to give recommendation...lol
Aug 12, 2009 | Samsung SRP 350 Thermal Printer
Canon ir C3200 Print Resolution
Print out a Fiery config page ....there may be something in the fiery settings on the actual Fiery box, you'd have to reboot and run setup when it prompts you.
Jul 12, 2009 | Canon Office Equipment & Supplies
Need to get scanned photos to between 300 and 600 dpi
What I saw first off is that although the resolution indicates 96 DPI, the file size itself between the 2 examples are drastically different. You are putting raster images into MS Word for publication work, and that is a NO NO. Word was not created for any kind of high resolution printing. It's a glorified text editor that people seem to think is an option for printing. YOU WILL NEVER GET 300 or 600 DPI images out of Word. Ever.
To create your project for printing, you need to use software more suited for the task. InDesign and Quark are examples, but they are very expensive. In my opinion, Publisher would be better for this kind of project and I hate myself for saying that.
Talk to your Printer, find out his specifications for Applications and Linescreen for Printing. The minimum requirement is 280 DPI, but if the image is placed at 100%, 600 DPI is overkill.
Oh, and try to never scan a scan... you are looking for trouble... a little thing called a Moiré pattern comes into play, and it will make you images print NASTY!
I could go on about your post all day long, but if there is anything else I didn't explain, please post again.
Jan 21, 2009 | MGI Software PhotoSuite SE V4.0
HP PhotoSmart 7550 InkJet Printer Logo
12 people viewed this question
Seeker5211
Seeker5211
