Hoover Floormate H3000 Upright Wet/Dry Vacuum
Problem for Hoover Floormate H3000 Upright Wet/Dry Vacuum
My son dropped the Hoover Floormate hard floor
By njarvis44 on Oct 03, 2009
My son dropped the Hoover Floormate hard floor cleaner and a black piece with a spring came out. I dont know where it goes, and now the handle wont stay up.
Solution #1
posted on Oct 14, 2009
Not Rated)
joedoe702
Rank: Apprentice
Rating: 0%, 0 votes
I agree that it is the wheel assembly that's broken. However, my wheel assembly broke in a different place, so I bought a replacement part for $20 or so. I have never figured out how to swap it out...
After a few attempts, I believe it will require some major dismantling and not just a simple part-swap.
Was this helpful?
Yes
No
Solution #2
posted on Oct 11, 2009
Not Rated)
elextek
Rank: Guru  Vacuums  Expert
Rating: 87%, 125 votes
From your description you have an issue with the pedal release in the base. this model is the original series, and I would not put too much money in the repair. not an easy cover to remove. check the base wheel assembly. the black pivot points break on these when dropped. If it is broke the part itself cost about $18. Cosider the overall performance and other repair items to determine worthwhile repair.
Was this helpful?
Yes
No
Popular Solutions for Hoover Floormate H3000 Upright
Questions and Unsolved Problems for Hoover Floormate H3000 Upright
Do you recommend Hoover Floormate H3000 Upright Wet/Dry Vacuum?
Answer
Answer
I need to clean out the blocked hose on my wet/dry floor mate, please help
Answer
Hoover floormate Gets little to no suction when set to both Dry and Wet Pick up.
Answer
When you push the solution button nothing comes out, only puts out water just a little if you pump... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuum Experts
Top Vacuum Repairmen
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
