Picture only shows in black & white when playing DVD
I was watching a dvd in colour. I accidentally sat on the dvd remote which I'm guessing pressed a sequence of buttons. This changed the picture to black & white. I went through the dvd user manual but couldn't find any setting which toggles between colour/black & white. I would like to get the dvd to play in colour again.
It is not the TV which is causing this as normal tv plays fine in colour. The tv is also connected to a VCR which is also playing fine in colour.
Note: when the dvd player is switched on, a "Philips" screen comes on. This is in colour. It is only when the dvd is played that the colour is lost. I have tried several dvds - all in black & white.
I tried switching between PAL and NTSC, dvd still plays in black and white.
If you can assist, that would be great. Thanks.
  • 15 more comments
  • JennR Dec 28, 2007
    I have a Denon DVD-1710 that is only showing in black and white. The remote number is RC-982. I tried to look up the factory specs, but can't find a solution...Any ideas?
  • fishbonee Jan 06, 2008
    Hi my sony DVP-NS51p display on my TV in black and white pictures. i done all there is to be done on my knowledge but to no avail.
    pls help me out.
  • debbieamber Jan 09, 2008
    I have a spongeg bob emerson dvd model number sb329 and i was tring to program my daughter leap frog that runs thru the dvd and now the dvd only plays black and white i tried to use the remote the restore factory setting but no luck please help
  • scaddenp Jan 15, 2008
    Same player, but only with one DVD. Others are playing fine. Played with DVD/NTSC settings to no avail.
  • Winetta Mar 29, 2008
    I was watching a movie when I started seeing it in black and white. I thought it was the dvd so I changed it only to find that every one of them was playing in black and white. Please help me reset my dvd to play color again. I have a AD-N820N. Thanks.
  • mmega Apr 09, 2008
    my sony dvd player dvp-ns57p also shown the same problem. it stops working in color and plays and display only in black and while now. still scratching my head even after I talked to the sony tech support and reading the web site and reading the manual to no avail.
  • rezaru Apr 28, 2008
    I have a pioneer DVD player. Some of the DVDs and CDs it shows in colour and also the PIONEER logo is in color. But for some other CDs and DVDs it shows in black and white and also the logo appears then in black and white. Any suggestions please?
  • afreen Apr 29, 2008
    i have sony dvp-k82p and i'm facing the same problem of my screen showing black and white
  • Anonymous May 20, 2008
    ma dvd-zor only shows teh black and white and it's makin me go CRAZY!!!
  • Anonymous Aug 04, 2008
    my dvd picture shows in black and white from turning on the dvd player. the tv colour is ok. i have checked all leads . im at a loss what to try next. i also checked manual. but there isnt any solution for this prolem.
  • hollrrr Aug 10, 2008
    My dvd's only play in black and white. The vcr plays in color. What could be wrong?
  • riyasup Sep 26, 2008
    i have a sony mini hi-fi mhc-gnz88d few cds were playing blck n white,i changed theire colour type to ntsc they stated playing in colour,but later all dvds,vcds r playing in black n white even those which were previously in colour..i tried master reset also still no solution..all cds are in black n!!!!
  • Anonymous Nov 10, 2008
    I have the same problem.
    My unit id Pioneer EV21
  • frustr8ed1 Mar 08, 2009
    Hi Shuttle83, I, like so many others have this situation, where everything functions properly, with the exception of loss of colour from the played disc. I have a JVC XV-S302SL player, and the problem occured after too many incorrect inputs on the remote from a visitor. All connections have been checked and rechecked, all equipment is in proper operating condition,and the only problem is an inability to access and correct back to the original factory default settings. Hate to throw down another challenge, but if you are indeed The Wiz, can you show us all how to rectify this problem, or is a new unit the only way out?
  • cmuraida Apr 08, 2009
    Our DVD plays only in black in white after we moved and reinstalled our TV, VCR, DVD, satellite receiver and tuner. The TV and VCR both play in color.
  • Anonymous Apr 13, 2009
    I have a sharp dvd combi player DV-NC65 which has worked perfectly until just recently. It will only play in black and white and I think maybe a button has been pressed on one of the remote controls accidentally. We have tried pressing them all but to no avail!
    The television works okay in colour, and the manual was no help at all, neither was the troubleshooting guide. Can you help?
  • Anonymous Mar 20, 2014
    I have a digihome tv with a built in DVD player an the screen has no fine black and white have tried all settings and everything seems fine can anyone help me please
Same problem with an older JVC player. One end of the S-video cable was loose. Pushed in in tight and everything ok again. Cheap fix if it works for you.
Posted on Jan 26, 2010
Turn the switch at the back from s-video to video
Posted on Jul 29, 2010
  • pep223
    pep223 Jan 31, 2013
    no such switch on mine
  • 1,139 Answers
Hello merdith,
If you provide the brand of the DVD and remote, I would be able to look up the specs and then tell you how to reset your factory default settings.
Also, if you want to look up this information, what you are looking for is information on resetting the factory defaults of your DVD player. Check the manufacture's website for the documentation, or google the brand of DVD player and look for the users manual as the search item.
I hope this helps,
Posted on Dec 22, 2007
  • nanasoadwa
    nanasoadwa Feb 01, 2013
    the brand of the remote is sony KM - 608
Sharp DVNC65H plays tapes in colour bout DVDs in monochrome. Solution for me was to set the TV to s-video.
Posted on Nov 08, 2010
    New Friend:
Yeah this happened on my jvc tv but it's a built in dvd player
Posted on Apr 03, 2015
  • Ethan Ashworth
    Ethan Ashworth Apr 03, 2015
I had the same issue. Just disconneted the S-VEDIO and now using the vedio connected and color start showing again
Posted on Apr 30, 2008
If connected using a scart lead the S-VIDEO function may have been switched resulting in B&W picture. Could try selecting this.
Posted on Jan 18, 2008
My daughter sat on her JVC tv/DVD combo LTdd42J remote and now her DVD's only play in black and white, when watching the TV the colour is fine. I have tried looking in the settings but cannot fin
Cable damage is the first thing to check. If the cable is external this is an easy check by trying a new one. Otherwise it is probably internal cable damage or damage to the video output plug.
Feb 18, 2013 | JVC XV-S302 DVD Player
My daughter has been playing with the remote control on her Technika tv/DVD combo and now it will only play dvd's in black and white can anyone please help x
Hi, First check that the colour is set to about half way and that you can actually adjust it. Then check the colour system when playing a dvd, set it to PAL or NTSC or whatever the DVD recommends or in the menu. Is it still black n white when you watch just the Television programs?
Sep 21, 2012 | Televison & Video
Koss dvd player kd305a plays black and white.
Check the av channel on the tv,the av is normaly av2,if it say`s any different then press the av button on the tv r/c until it plays in colour
Oct 15, 2009 | Televison & Video
Tv works great, dvd is new , cant figure out the right hook up , dvd has 3 cables white yellow red
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go.
If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
May 28, 2009 | Televison & Video
Cant get color picture when playing DVD's
I too had the same problem. On the Vzio there are AV plug ins on the left side (not the back, but the left side). Use these jacks when connecting to the DVD player and choose the AV button on the TV remote. Viola!
May 27, 2009 | Sony Televison & Video
Portable DVD showing blue screen
i have the same dvd player the pink 1 i lent on a button and it went into black and white i have tried everything and can't seem to get it back into colour again, ive tried pressing all the buttons and nothing seems to work or come up with any black and white/ colour options :(
Mar 04, 2008 | Televison & Video
Black and white picture
turn off you dvd player... them click on "setup" button on your remote control! them click right botton to appear "tv sys" them click "enter"... choose your tv system, PAL or NTSC.
Jan 15, 2008 | Pioneer DV-360-S DVD Player
My DVD playes only shows in black and white
Grab the manual and the remote, my guess here is you have accidentally changed regional setting, depending on where you live.
Some remote controls have a button, it's simply a matter of identifying the said button and pressing it again to change your regional setting back to it's original.
Jan 12, 2008 | Classic Electronics Classic DVD42S...
FUNAI drvr-b778
Use a head cleaner to clean the heads on the vcr.
Jan 09, 2008 | Funai PY90VG DVD Player/VCR
Televison & Video Logo
25,932 people viewed this question
Top Televison & Video Experts
