Question about Dryers
The dryer is not heating
I have a sinpson maxidry 1200s clothes dryer.the dryer is not heating.
The dryer is running will I have pulled it down and cleaned it out but I dont now where the heating element is. Can anyone please tell me so I change it.
  • Dryers Master
  • 7,482 Answers
Look for the air tube that runs from the blower to the drum.
The heating element is normally located inside of it.
I hope this helps
Posted on Oct 03, 2009
How to wire Simpson 1200S dryer motor
Check with Simpson directly to obtain the diagram.
Jun 10, 2014 | Dryers
Rattle vibration
Dryers do what they are designed to do, Dry things. In the process everything inside the drying cylinder makes dust and airborne particulates called Lint. The Biggest bane for dryers is Lint accumulation. Clean the Lint filter screen. If it detaches from the dryer housing with screws remove them. Clean out what you see if you have a wet vacuum with a small hose carefully push this down into the opening and vacuum it ou. Another thing pull your dryer out from the wall disconnect the power and remove the vent hose. Vacuum inside the opening in the back of the dryer. You would be surprised how much lint accummulates here. Lastly check your vent hose for lint accumulation or blockage. If you find it blocked, disconnect the hose from the vent going outside and clean it all out with a vacuum . Put it all back together and run a load of clothes if you dont see a marked improvement in circulation and drying time, then either the blower fan is n't working properly or you have a burned out thermostat. If you have heat flowing turn it up to max heat and see how hot it really gets if on opening the dryer you feel extreme heat then it is either working right or the thermostat is not shutting off at the high limit. the Thermostat is a piece of Bimetallic metal that is extremely sensitive to certain temperatures. When they reach the preset heat limit they shut off allowing the heating elements not to burn out. A good investment is to keep dryer maintenance at regular intervals. They sell dryer cleaning brushes and Vacuum hose attachments for getting into the deep crevasses and nether regions of your dryer. Good luck and happy drying
Apr 06, 2014 | Roper Dryers
Air no longer venting out back of dryer
sounds like the fan not working.
Apr 06, 2013 | Dryers
I have a simpson maxidry 1200s and it appears that a piece has dropped off inside where the door hinge attaches to. (The door is perfect - Its the part inside the main body of the machine that the part...
i believe this is the part, if not you will/can find it at this site. Good Luck Tim:
http://www.repairclinic.com/Frigidaire-Dryer-Latch-Parts
Mar 02, 2011 | Dryers
Simpson Maxidry 1200 S Clothes Dryer. Dryer spins, Blower working, but heater doesn't work. I've got the element out & it checks ok. What next please?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 20, 2010 | Dryers
Hi, My Simpson maxidry 456 dryer, heats up and appears to work, gets hot and cuts out. It is steaming the clothes but does not dry them. Would this be a fan problem, How can i fix it? Ta!
9 out of 10 times this is going to be a restriction in your vent line. Check where it goes outdoors and see if there is a steady flow of warm air. If not, take the vent off of the wall behind the dryer and either have a handyman snake it clear to the outside or take a leaf blower and blow it clear. A good way to test for a restriction before doing all of this is to run a cycle with the vent disconnected from the back of the dryer. The steam is a result of the hot wet air from the clothes having nowhere to go. Good luck =)
Jul 28, 2010 | GE Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Simpson Maxidry 1200 S Cloths Dryer. Our dryer whilst spiining and heating is not adequately drying clothes. When I took it down to check test it appears that the belt to the central lint fan may have been...
Yes - the vent exhausts humid air, and draws IN fresh dry air. So the humid air is staying trapped in your unit.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 08, 2009 | Washing Machines
My simpson 1200s heavy duty clothes dryer is just not drying the clothes. It isn't heating up much and the clothes are still damp. Can you advise please
check venting fo cloggs or kinks make sure you can see through the filter dryer sheets put a film on them and need to be washed once in a while
Jun 28, 2009 | Maytag 7.0 Cu. Ft. Electric Dryer
Dryers Logo
128 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
