Question about Bosch Integra® 800 SHX57C0xUC Built-in Dishwasher
Dishwasher does not drain and I have cycled it a couple of times to make sure. No line plugged and I've cleaned the filter.
After determining the pump was working in the unit I checked for a posible drain problem. I disconected the unit's drain hose from the drain vent in the sink and stuck it in a pan and then ran the unit again. It drained just fine. I then removed the drain vent at the sink and found it to be plugged. I cleaned it and all is working again.
Posted on Oct 03, 2009
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
Jun 03, 2017 | GE Nautilus 24" Built-in Dishwasher
Water not draining completely.
Clean the drain filters: click on filters
Jan 24, 2013 | Kenmore Dishwashers
Steam coming out of dishwasher
Sounds like the drain hose is partially plugged restricting the water to completely pump out.
Mar 28, 2017 | Dishwashers
Why do dishes stink when they come out of dishwasher?
try running the dish washer on the heated cycle and use a quality wash detergent not ordinary washing up liquid
Apr 14, 2017 | Maytag Dishwasher
Dishwasher never cleans, glasses gritty dirty -- Bosch terrible s
you obviously need to check and make sure that you've cleaned your filter system. it needs to be cleaned every couple of months. and also make sure that your washing fans, the ones that spray water, aren't clogged. they need to be washed out and de-clogged regularly as well... i had this same problem.. but it worked fine once i cleaned the system.
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher not draining, not getting dishes clean. detergent still present in its space, filters at the bottom appear clean and hose to drain appears unclogged Nautalis GE 24"
sometimes this drain motors get stuck..you have to turm them a couple times with your hand, make sure you shut off power....also sounds like you have problem with cycling...i wish a can take a look on it....turn you drain pump...and try to start again see what is goning to happend....please let me know you results totalcarefl@yahoo.com
Aug 25, 2009 | GE Nautilus 24" Built-in Dishwasher
Whirlpool quiet iv runs for 10 minutes on 72 minutes and 42 minut
make sure the drain line is clear ....when the dishwasher is going through the drain cycle there should be water running down your sink drain .....if you don't hear it or see it then your drain line is pluged ....un plug it and you should be fine
Jul 24, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water leaking from dishwasher lg model lds5811ww
The drain line is clean. Have you checked to make sure the the rest of the drain is clear all the way down to the main drain?. Also check the pump to make sure that it is working properly, it might be pumping water in, but it may not be wanting to pump the water out
Feb 11, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Water won't drain
Hi fixitfran,
I'm Harvey the Master Plumber.
Your problem is: You have pulled the dishwasher out and checked hose. No kink in line. You have taken cleaned out dishwasher and no clog. You poored water into dishwasher and it drains from the bottom not throught drain hose. You have checked the drain hose on the bottom of the dishwasher and to no avail....you don't know what is causing this issue....can I help you out with this? LG-14AW3 Dishwasher does not drain properly and then powers itself off mid cycle. Filters are clean and there are no kinks in the drain hose. How do you fix this and will it be very expensive.
Have you recently replaced the garbage disposal? Sometimes the installer forgets to remove the knockout plug. All of the disposal manufacturers plug the d/w connection in case it is installed where there is no d/w. If there is a d/w, the plug must be removed.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Dishwashers
Intake drain light flashing
1. Unscrew air gap which is on the counter-top next to sink.
2. Unscrew drain clamp under the sink which s connected to the air gap.
3. Use a wire hanger to push down debris clogging the drain.
4. Screw clamp and air gap back in place.
5. The dishwasher should work. Routinely clean out air gap every half year.
Jul 30, 2008 | Miele Dishwashers
Bosch Integra® 800 SHX57C0xUC Built-in Dishwasher Logo
111 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
