Question about HP Photosmart R937 Digital Camera
My camera is completely froze and won't do anything photosmart touchscreen r937
3 Suggested Answers
leethedeuce
  • 4472 Answers
SOURCE: HP PHOTOSMART R937
If you have only had it for 6 months, I would recommend sending it in to HP to be serviced.
Thanks,
Lee
Posted on Jul 21, 2008
BillB-SA
  • 2761 Answers
SOURCE: hp photosmart R927. No power, no operation, no LCD, battery good.
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please take a moment to post a rating for me. "Very Helpful" would be appreciated.
Posted on Nov 28, 2009
How do i fix a Hp Hewlett Packard photosmart r937 digital camera?
Not sure on the camera model but cameras usually don't take 12v so I would comparability of charge voltage would be the problem. Cameras take 3v to 6v usually. Check the specs of your camera that will tell you what it needs. Hope this helps.
Feb 23, 2015 | HP Hewlett Packard Photosmart R937 Digital...
Wrong colors on screen
There is a problem that needs to be looked at by camera tech.
Jan 17, 2013 | HP Photosmart R937 Digital Camera
How do I find the hp r937 software
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
Feb 22, 2012 | HP Photosmart R937 Digital Camera
My touch screen is not working correctly can it be repaired
in settings menu you will find a test to set the touch screen. Every device with touch screen have this test. After you will run this test, every thing goes back to normal. This test it should look like a white screen with small cross. You should push in the center of that cross.
May 31, 2010 | HP Photosmart R937 Digital Camera
Hp photosmart R927. No power, no operation, no LCD, battery good.
Nov 28, 2009 | HP Photosmart R927 Digital Camera
Hello i have the hp r937 and i had dropped it and the door to the battery will not close now i think a part on the actual camera broke of not on the door is there a way to fix this?
Did you find someone that fix it?. I dropped mine today and there was a small plastic piece that helps to close the door, it broke, now the door won't close.
Nov 22, 2009 | HP Photosmart R937 Digital Camera
I lost all my pictures. do not know why .my memory stick is still
i suppose if you have connected your camera to a system which is either virus affected or you might have deleted them accidentally. but dont worry you can retrieve the deleted photos from your memory card, for which there are softwares. you can google search for them and install them in your system.www.p-dd.mobi/ ....... the above said website contains the softwares. it is an example.
Aug 15, 2009 | HP Photosmart R937 Digital Camera
HP PHOTOSMART R937
Thanks,
Lee
Jul 21, 2008 | HP Cameras
HP Photosmart R937 Digital Camera Logo
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
