Question about Zanussi FJ1254W Front Load Washer
Zanussi FJ1254W fault
My washing machine is making a funny whirring sound but not all the time, have you any idea of what it could be before I attack it please?
  • DoggyB Dec 23, 2007
    It appears to be load related, if my wife fills it up(She thinks it a tardis)it makes the noise, if its filled to normal levels it's ok. Could it be the brushes(if it has any?).
  • 833 Answers
Could be almost anything....first guess...did someone lose a coin or other item?
Posted on Dec 22, 2007
I have a Zanussi fj1254 w. It was making a high pitched squeel when it was spinning. No when I turn it on water goes in but the drum does not turn. It turns freely when rotated by hand. i have checked the...
Possible that the drive output to the drum is not there and so there is no voltage when the cycle come to the spin mode.
Check for fault in the drive, capacitor to the motor.
Jan 21, 2013 | Zanussi FJ1254W Front Load Washer
I have a Zanussi 1200 fj 1254 when I turn on the machine and it starts to fill with water...water starts to pour out of the fluff filter mechanism never mind how tight we try to do it up ... any ideas ??
I suspect there is either limescale in the thread of the filter plug OR behind the filter itself and this is stopping the plug from being screwed home completely. Remove the plug, pull out the filter, clean filter compartment all round, especially at the back AND ensure the plug thread is completely free of limescale ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 09, 2011 | Zanussi FJ1254W Front Load Washer
When on a spin a very loud rumberling noise. Even taken off the belt and it still makes this noise. Can u help
sounds as if your water pump is going bad or is bad. will it still pump water out all the way?
Jan 10, 2011 | Zanussi FJ1254W Front Load Washer
I dont know were to place the bleach at in this machines
There should be three compartments in the dispenser, you would normally put the bleach in to the
main compartment of the dispenser where you put the normal wash powder
This is the largest of the 3 compartments,and is usually in the middle, but sometimes on the right, but it is the largest of the 3,
Dec 01, 2010 | Zanussi FJ1254W Front Load Washer
Grey sludge on my washing
Hi, I had the same problem.
The waste is blocked, check the drain pipe from the machine and also where it drains out to. (thick sludge)
I ended up unclipping the pipe from the drain motor (Bottom rear) and passing a garden hose throught it to flush it out.
Jan 07, 2009 | Zanussi FJ1254W Front Load Washer
Zanussi zwf1237w washing machine
Won't spin at full speed. It just goes around slowly.
Jan 14, 2008 | Zanussi FJ1254W Front Load Washer
Zanussi fj1254w washing machine
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 04, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi FJ1254W Front Load Washer Logo
129 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
