Question about Garden
When cutting grass mower motor will bog down and die
Uh, yea. Governor rod? Really dude? Sure, split the case to the motor which will take all day and you will never be able to re-assemble the motor.
Quite frankly, your grass is too long and your mower is under severe load stress. First, raise your wheels as high as they will go. Every mower has wheel adjustments. Second, be sure your catch chute is clear (this is the where the bag connects that catches the grass. If your mulcher is attached, remove it attached your bag to catch the clippings. This will reduce the load on the blades. Third, make sure the yard is not wet when you are mowing it. We grass makes it three times heavier and will kill your mower. Do all 3, and I bet your problem is solved.
Posted on Jul 24, 2012
  • 881 Answers
THE engine has done a lot of work and the compression is down ,,,,starts ok but hasent got the go in it to cut the grass so either rebuild engine or get a new one.
But first check the govenor rod that runs from the carby yo the flywheel as it might be uncliped.
Posted on Oct 03, 2009
John deere instructions
Your mower doesn't have enough power to handle very thick grass at high speed. You need to go slower across the lawn. That's easy to do if this is a push mower (just don't walk so fast) or if it's a self-propelled model with a speed control. But if it's a single-speed model you'll have to mow the lawn in fits and starts: squeeze the lever to move it forward; release it when you hear it bogging down; wait for the motor to reach full speed; squeeze the lever to move it forward again; repeat. Also, is the grass very high? If so, try setting the cutting height higher on the first pass, then lower it for a second pass. Finally, make sure the blade is sharp.
Aug 06, 2014 | Briggs & Stratton 190cc 875 Series OHV...
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Husqvarna too slow when mowing
Some self-propelled mowers include a speed control, but sometimes it may seem that no matter how you adjust it, the mower just creeps along at a snail's pace. Most likely this isn't a mechanical malfunction, but an adjustment is probably needed.
Very tall or thick grass can bog down a self-propelled mower, but adjusting the height of the blade may allow it to roll through and cut the grass at normal speeds. If the blade is low, the amount of cutting required may slow down the movement of the entire mower. The frame of the mower may also stick in the high grass. Raise the blade little by little until the mower rolls at the appropriate speed. Going up hills may cause a similar response.
It's possible the drive belt on the mower can slip. Inspect this part to see if it is loose or cracked, and replace the belt to restore power.
May 08, 2012 | Garden
I have a craftsman gt 5000 model 917.276220 runs fine but when mowing deck is engaged it wants to die when under a load or cutting tall grass, it will stay running but when i start to cut it bogs down?
not possitive, but sounds like 1 of the bearings on the mower deck is starting to seaze up.I would start with that. Remove the deck and belts and check all the pullys and bearings for free movement.
Mar 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Scotts mower kohler command 25 motor bogs when mowing
Hi..my name is Keith..and it sounds like you have a binding somewhere on your mowing deck..i would check all the spindles .. pulleys and blades..and check the deck belt..it could have jumped a belt guard and it running on the outside of it..but just remember it has pulley brakes to slow the pulleys down when you shut it off..so..engage the deck without the engine running and check for the binding..i hope this has helped..if not..please write me back
Jul 14, 2009 | Garden
Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Jun 30, 2009 | Ariens Garden
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Engine bogs big puffs of white smoke from front
the engine will bog because the cutting blades are either cutting to much grass or the blades are touching the ground making it hard to keep rpm's then it will smoke a bit
Jun 05, 2009 | Garden
Motor has low torque
common complains for electric & cordless mower is that they are not ment for cutting on wet or dump grasses or long tall grasses they will bog down. for this type of unit blade should be extremely sharp. also clean the under the deck so you can better air flow for the blade. if your switch & rectifier are new & in right connection then have you armature check for short circuit..
Jul 27, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
272 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
