Question about Kenmore Dryers
Kenmore 70 series. Had trouble with melted plug at connection box. Replaced plug and now it runs but no heat.
  • Kenmore Master
  • 7,482 Answers
Your problem could be a faulty heating coil or thermostats.
Remove the back of the dryer and locate the air tube where the blower goes to the drum.
The heating coil and thermostats are normally located inside of it.
I hope this helps
Posted on Oct 03, 2009
I have a 70 series. It runs but will not
most likely a fuse ,remove the back and you will see the heater box to your right,it is the smaller fuse on the box,most people replace both,you can get it at your local appliance parts store it is called a thermal kit,the model number is inside the dryer door-mike
Feb 06, 2010 | Kenmore 64742 Electric Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
No heat
If the unit is running but you are gettin no heat at all, you're heating element needs to be replaced.
Hope this helps...
Sep 14, 2009 | Kenmore 60172 Electric Commercial Dryer
I have a Kenmore 70 series dryer. It will run for
check if the negative is connected on the back of the dryer ,make sure its tight,if not then the heater coil will need to be changed for sure.if my info was of any help to you then please leave a comment ,thankyou.
Sep 02, 2009 | Dryers
Kenmore dryer shuts off after five minutes
The vent box inside the dryer still has lint in it. You need to reach way inside to get at it. Turn power off.
Jul 22, 2009 | Dryers
Kenmore series 70 electric dryer will not heat up, but will rotate.
remove the back cover and check the heater box fuse and the heating element,do you have a meter?
May 10, 2009 | Dryers
Kenmore 70 series electric dryer runs but won't heat up?
Hi!!! If the unit is electric your heating element needs to be replaced if its gas then replace the coil boosters located on top of the gas valve..Good luck..
Jan 04, 2009 | Kenmore 73952 Gas Dryer
Kenmore 70 Series Dryer heats for 5 minutes then trips breaker.
Thanks for the question Your problem is with your breaker its weak and wont hold you reset it it works againfor a while Happens a lot When this happens again touch the breaker you will feel its hot also check the connections at dryer and at box where you plug your dryerin see if the prongs of the cord are lost its copper color . thanks for the question the appliance docs
Aug 24, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series Dryer Won't Heat
won't heat. fuse good,breaker good,heating element test ok. How do I check the thermostate, and timer.
Apr 29, 2008 | Kenmore 63942 Dryer
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Dryers Logo
29 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
