Question about Nikon COOLPIX L18 Digital Camera
Camera screen lined with white streaks and screen shakes.
When on, the screen on my camera is streaked with white lines and shakes. You can barely see the subject on your screen and sometimes nothing at all because the screen is so white. I do get the Error message on my screen sometimes. I love the camera and the pictures it takes. I just got it in December 2008 for Christmas. I do not have the receipt either, since I got it for a gift. Any adivce or my problems with my camera?
  • 608 Answers
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 18, 2010
  • Kaufman605 Dec 19, 2010
    Sorry about that wrong answer.
    Here is how you can fix it. I have a link for you.
    http://www.fixya.com/support/r7306268-re...
    Hope this helps and thanks for using fixya.
    Kaufman605
Nikon coolpix s710 pictures have a streak
I think your picture has a bright light source in the frame. In digital cameras this phenomenon is common that in some angle these streaks of lines are produced with very bright light sources. be careful not to include bright light source while taking pics. But if u have these streaks and line in all the frames, then better check your camera with the service centre.
Aug 22, 2014 | Nikon COOLPIX Cameras
White streaks on Cyan color
This to me seems like the developer tank problem. Call for service
Jan 07, 2018 | Xerox Phaser 7760/YDX Laser Printer
Lines visible when camera turned on
hello,what particular lines are you referring to? are you sure you have not pointed camera at direct sun light and got stray light or bounced of highly reflective material that's caused your lens to create flare,or is it the viewfinder that's had streaks of light leak in?
Oct 12, 2013 | Nikon COOLPIX L810
How do I repair a streaky lcd screen?
It depends. are the streaks from the picture, or are they on on the inside or out side of the screen of the outer screen. if its out side use vinegar and newspaper, if its inside like *** smoke (brown stains in streaks) you might be able to take the front off if your lucky! and clean it. They make it hard so you can't do this so you have to buy a new one. They can make them to last a life time now, but how would they make a profit then. top tip buy with your credit card and do not buy extended warenty,(in shop) your card covers this and you can get it for 50% less on line after. pluss you have loads of time to take it back, refund garentied with the new laws. I think 14 days, not sure?
Jan 25, 2012 | Cameras
Yellow black and white lines streaking across the screen
tyr to factory reset device on advance settings
with out the memory card
Apr 29, 2010 | Casio Exilim EXZ75 Digital Camera
White horizontal streaks
This sounds like some kind of lens flair. Make sure there are no bright light sources at about 45 degrees to the lens and it should correct this problem. If it is not that then there may be a problem with the CCD, the part that receives the exposure. Without knowing if this is a point and shoot or digital SLR this is the best answer I can give.
Oct 05, 2009 | Cameras
I'm getting extreme streaking on my photos, lines covering the whole picture
lines could indicate a bad ccd maybe damaged thru dropping it overcharging or just it may be time to replace the camera good luck!
Sep 01, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Colorful streaks/spots on my camera screen.
probably a bad connection to the lcd display. warranty fix.
Jun 19, 2009 | Canon PowerShot SD1100 IS Digital Camera
Horizontal gray lines in display screen and on TV
if u see them on lcd and final output also have these grey streaks then ur problem might be this u can call canon for free repairs but first try to clean ur camera head with head cleaning cassette and see if it helps otherwise call them see link
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
pls rate me fixya for help
Apr 07, 2009 | Canon Cameras
White line down the middle of all pictures IXUS 970IS
if ur pics also have streaks and lines then it is the BAD CCD problem
just call canon in ur region and they will repair it free of charge even if u are out of warranty and not on list dont worry see this
Pls rate me FIXYA if i deserve it here
Apr 07, 2009 | Canon IXUS 970 IS Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
246 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
