Question about Lands Phones
The keypad is locked and I can't unlock it to use the phone. The pound button has a key on it but when you push it, it wants a number and nothing I try seems to work. Model #28225FE2 DECT 6.0
  • 4102 Answers
SOURCE: keypad not working
you will need to take the case off the phone and check behind the buttons where the pads touch the circuit board these sometimes get greasy or dusty causing it to not create a conection between button and the circuit board clean the circuit board with dry dust free cloth look for signs of grease or water damage if this is clean or after cleaning put phone back together and try buttons if they still dont work you could try replacing the keys that you press as sometimes after alot of use these fail to connect with the board properly causing buttons not to work if you replace these and still dont work then it could be a warped board this happens if you have sat on phone or had it in pocket and let on something causing pressure on the case and this will warp the board their is no cure for this the only thing to do is buy new phone as a new board will cost as much as the phone hopefully this is not the case it might just need your keypad replacing try my first two sollutions first if this dont change anything then i would take it to repair shop and see if they think it is a warped board hope this is some help to you
Posted on Nov 17, 2007
SOURCE: whirlpool Duet
Press the "End of Cycle Signal" button, the last button on the bottom right, for 5-10 seconds. That should resolve the problem.
Uppi
Posted on Feb 03, 2008
  • 3 Answers
SOURCE: Locking the Keypad of my Uniden Cordless Phone
Try holding down the * (star button) bottom left of numeric keypad.
Wait unit you hear the beep.
Repeat same to lock.
Posted on Feb 14, 2008
SOURCE: Phone locked, please help!
Press the * key then the OK key within 3 seconds.
User manual at http://www.telephones4u.co.uk/userguides/CWD4901SE.pdf
Hope this is of help.
Posted on Apr 28, 2008
SOURCE: microwave keypad is locked
Touch and hold START more
than 4 seconds. "L" will
disappear and you hear two
beeps. At this time the oven is
ready.
Posted on Aug 23, 2008
Kaypad lock won't go away.
If you are not able to unlock you mobile with the unlock key press. Try this trick
Just dial the emergency number when the phone keypad is locked.
Dial 911 or 911 it will start dialing. Then you can cancel the call and you will find your keypad unlocked.
Don't forget to give feedback
Aug 30, 2009 | Kyocera Strobe K612B Cellular Phone
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
Need instructions for a Brinks security box with keypad and key
Push button in the back, enter 4 to 6 code and push the pound key.
To check combo push star, enter your code, push pound. Safe will beep three times and turn your key.
Jan 30, 2009 | Check Point Network Adapter
How to lock and unlock keypad Motorola VE240
To Lock your phone
Hold down the # symbol on your phone until it says: "Phone Keypad is now Locked"
To Unlock your phone
The screen should now read in the bottom right hand corner "Unlock". press the corresponding key. It then asks "Unlock Keypad?" "Yes" or "No". Select Yes and press Menu button (also the play/pause button).
Hope this helps you all!
Jan 02, 2009 | Cell Phones
Envy 2 dials phone numbers accidentally- need to set key guard
On the front keypad, press the ok button until you have the option to select contact list. Scroll down that list until you see keyguard settings. Press ok to enter keyguard settings and then go to option 2 - unlock options. Select two step unlock. This will force the user to press "ok" and then "clr" in order to dial out. This has resolved the problem for me...Good luck.
Dec 03, 2008 | LG enV VX9900 Cellular Phone
G600 keypad not working
Take your phone to your local market & ask any market phone repair vendor to fit a new keepad membrane, if this doesn't work it's trobably irriparable damage either caused by water or the fumes of some kind of solvent for example super glue.
Nov 12, 2008 | Samsung SGH-G600 Cellular Phone
Nokia 2630 locking
When a phone is left in standby it is programmed to lock itself, usually to unlock it your push your main navigational button then the star (*) key to unlock the phone. Hope this helps
Nov 08, 2008 | Nokia 1600 Cellular Phone
Pound Key
Open a notepad and then press all the key on keypad and check which one is giving a pound key. This is required because if the key cover is changed in that case the pound will work when pressed a different key.
Also clean the keypad or else get a new one.
Thanks
Oct 31, 2008 | Toshiba EKT6520SD Phone
Phone turns on fine but nothing happens pushing buttons except power.
If your phone has a keypad lock option, make sure that the keypad is not locked. Refer to the user manual to know how to unlock the keypad.
It is also possible that the keypad is defective and needs to be replaced.
Jerry G.
Jul 12, 2008 | Motorola Mobility i560 Cellular Phone
Lands Phones Logo
126 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
