Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
I cannot access hard drive. comp. says there is a problem
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
SPECIAL NOTES
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
Posted on Oct 24, 2009
No operating system found
The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB...
Remove the hard drive and reseat (reconnect). Check BIOS. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Oct 13, 2012 | Computers & Internet
External Hard Drive stopped working
u might have to format it in safe mode or buy a new one, if you try it on some one elses comp. and it works it ur comp. but it is most of the time a software issue
May 08, 2010 | Toshiba 120GB USB 2.0 Portable External...
Pendrive has stopped working its a Cuzer 16GB
try restartng the comp . if it do not work ,try using the pen drive on another comp.
Mar 24, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a smartdisk firelite hmo80hc samsung- and i can't map it to a drive. I can see it in the device manager but cannot access my files
Try control panel / admin tools / comp management / in left pane select disk management / .......now if you can see the drive there (right click it) you should be able to map it using change drive letter and paths... good luck hope this works
Nov 01, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Need to transfer files from fried comp to new comp
take out the hard drive of ur previous laptop.
purchase an external usb case for laptop hard drive and attach it to ur new laptop.
dont forget to vote.
Sep 16, 2009 | Computers & Internet
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
HD installed with XP in Giga MB,not booting up in the originalP3
it is impossible or else you reload the hd on the motherboard
Jan 21, 2009 | Computers & Internet
Hard drive registers on the comp as working properly, but does not register on the my computer ( therefore i cannot access it
If this is a new hard drive u installed, right click My Computer, press Manage then under Disk Management partition then format drive.
Nov 10, 2008 | Computers & Internet
Data recovery from corrupt external hard drive
Well, in your case you should format the external drive and then try some so-called data recovery software.
First of ALL - Connect your hard drive to your personal computer. And install this software Wondershare Data Recovery on the computer in order to perform data recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem!
Dec 07, 2007 | Computers & Internet
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
199 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
terminalcon
Jerry Umali
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
