Question about Kitchen Ranges
Front burner slow in lighting on jenn-air stove top. All other burners light quickly. Could it be the ignighter? Can I switch out ignighters with a back burner that we seldom use?
  • 334 Answers
Yes, it most likely is the ignitor. Chances are it simply needs to be cleaned (ignitor, burner etc.)
If cleaning it does not solve the problem, I reccomend replacing it with a new one.
A malfunction of that type causes gas buildup and can result in excessive ignition when it finally does light. As they get worse, they litterally create mini explosions and can become fire hazzards.
For that reason I reccomend that you do not use that ignitor on any burner with such a malfunction.
You should be able to find a new ignition assembly at your local appliance parts warehouse, or by calling the manufacturer.
Posted on Oct 03, 2009
Bradford White gas power vent water heater; just replaced power vent motor and fan assembly because a bearing went out. Now the new fan motor runs constantly without igniting. Is there a switch that...
Some how you have disconnected the sensor that tells the main burner that the fan is on. Its trying to light but cant. On some models there is a air pressure switch that reads the pressure inside the vent pipe itself. It will have a small hose on it and if that has cracked or was not replaced it wont light. This is how its supposed to work--- vent fan comes on,sensor confirms fan is on,hot surface ignighter starts to glow red,and main burner is opened,another sensor confirms that main burner is lit,then hot surface ignighter turns off. Hope this helps.
Jan 11, 2013 | Water Heaters
One burner has no spark for ignition..
Yes this is arcing, and should be replaced. If it is still atatched, you may be able to move it away from an area that it is arcing onto, and give it a try. Wery often it is just items in close proximity that causes the issue.
Jun 29, 2008 | GE Profile JGP636 Gas Cooktop
Elec-ignighter on gas stove top not working
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 20, 2011 | Microwave Ovens
Whenever i light the gas top wolf range, the ignighters on other burners keep firing
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module.
I hope this helps you to repair the problem with you stove,
Gene
Aug 11, 2011 | Wolf Range fs-0-27-ft36 Gas Kitchen Range
Model CVGX2423W ignighter sparks at all four bunners if only trying to light one
Every time you try to light just one burner the ignighter will try to light them all. The reason why is that they are all wired to the same switch under the cook top. There is nothing to be worried about. That is the way the factory made the cook top.
May 01, 2010 | Jenn-Air Cooktops
Viking gas stove operators manual....I was working on my stove ...it was not lighting up....the stove......and I noticed that there was 2 burners...and when I replaced one of the ignighters and tryed the...
The way it works is the igniter gets voltage signal from the control and will start to glow. The gas valve for the burner and the igniter are wired on the same circuit. When the igniter starts to glow it takes all the voltage from the circuit. As the igniter increases in temp the resistence changes and the voltage starts to travel to the gas valve. Once the gas valve registers 3 to 4 volts it will open allowing gas to the burner for ignition. The igniter needs to reach approx 2200 degrees for this to happen. So it could be the igniter or the gas valve. The igniter should test approx 500 to 700 ohms with a ohm meter. The gas valve could also be sticking. If the igniter is glowing bright and you tap the gas valve with a wrench and it comes on then the gas valve is sticking and needs replacement(as long as the igniter tests good)...Hope that helps.
Oct 11, 2009 | Viking Ovens
Jenn-Air 36 Gas Cooktop
try to use macth in the burner u said,if ok the flame,the problem is the igniter wire,nid to replace,but if u use the macth then the flame is malfunction again i think the sensor is the problem,nid the tecnician coz is hard to repair,sometime after repair the sensor it problem again in next day
tnx gerbee
Jul 02, 2009 | Jenn-Air 36 in. CCGP2720P Gas Cooktop
Control panel out
it very well could be have you pushed clock like your going to set it
Feb 15, 2008 | GE JGBP28 Gas Kitchen Range
Stove top burners
It is not the cartridge. It is the ignition switch (sometimes called a cooktop switch) I found mine on ebay. In particular it is a faulty rear switch. Save your money on the cartridge.
Feb 10, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
133 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
