Question about Music
I'm installing emg pickups into a guitar but i cannot get the solder to stick to the outside of the potentiometers
    Novelist:
  • 133 Answers
Use some fine sandpaper to clean a spot where you want to solder before you do the soldering.
Maybe you will have to use some soldering flux or paste or other like stearine, colophony (rosin) to make the solder stick, but usually if you clean it well with sandpaper and alcohol before soldering, the flux in the soldering wire should make the solder stick well enough, but that varies depending on the material used for the cover of the potentiometer.
regards
Triarcuate
Posted on Oct 03, 2009
How do i wiring an active pickup and a passive pickup in same guitar
Not hard - just wire up one pickup and leave the other one alone. The active pickup will have wires that say "output + and - " - just use those to connect to the same place you would attach a passive pickup. Also, an active pickup will need space for a battery (9v). I weould consult EMG pickup installation for diagrams. You will also probably need to replace the guitar jack with a TRS, where the ring is a "killswitch" for the battery when the guitar is disconnected.
Try this diagram set: http://www.emgpickups.com/skin/frontend/emg-2013/default/pdfs/2-tw-2v-1t-only.pdf
Feb 14, 2015 | Music
Guitar pickup at bridge (EMG 81) is not working
several things....First I would check your battery. second, check wiring to your switch to make sure the wiring hasnt come apart from the solder joints. From there I would test your switch itself to make sure it is still good.I have had switches go bad and only have one pickup work before.
Aug 21, 2013 | Jackson Rrtmg Randy Rhoads Pro Electric...
I have install resently an emg spc pontentiometer in my guitar but i get a fanny noise in the middle position of the volume pot. i also use passive single coil pickups.do you have any idea why i have this...
EMG's use 5k pots if you bought the ones for the actives, unless your single coils are active you can't use it. 250k or 500k is standard.
Sep 12, 2017 | EMG Music
My s5470 does not sustain well at all.also,the bridge pickup sounds ok but lacks ''attack'' in upper register.great guitar otherwise.i use a peavy 5150 60watt amp.
I personally use Seymour Duncan Humbucker pickups, and have never been disappointed. You might want to take your guitar up to a music shop and try it on different amps to see if your amp is your problem, or if it is your guitar's pickups or wiring. You could also try adjusting the height of the pickups until the sound you are looking for is achieved. I have also had guitar cables make a big difference in the sound. Make sure you have a good set of cables, and you may want to adjust the EQ settings of your amp to make up what the guitar lacks.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Apr 15, 2011 | Ibanez S5470 Prestige Electric Guitar
Can i fit EMG 81 and 85 into my Washburn PS600 without much hassle or soldering? They currently have Egnator humbucker pickups installed as stock.
EMGs have quick-connect wires now so that part shouldn't be much trouble. You will however have to carve out a cavity for a 9v battery and wire it to the pickups (you might be able to put it under the pickguard as well) . If you are worried about this I suggest you have it done professionally.
Mar 09, 2011 | Washburn PS600 Paul Stanley Electric...
Static noise.
These are active pickups, check and make sure the battery is still good. If that's not it, there's probably a wire loose inside. Take it to your local guitar tech and he'll be able to tell you exactly which one.
Feb 23, 2011 | EMG 60 Guitar Pickup
Not so much a problem but need to no about the pickup situation with the battery and ****
Your guitar has active pickups. Active pickups require a 9-volt battery to operate effectively. They are louder and have more "punch" than passive pickups. If your not into swapping 9 volts fairly often then you can swap out you pickups for some passive ones. If your going to be storing your guitar for a while you will want to remove the battery to prevent unnecessary drain and oxidation of the battery.
Dec 12, 2010 | Jackson Wrmg Warrior with Emg
Music Logo
83 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
