John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
Posted on Oct 02, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I add transmission fluid on 2010? - John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Anonymous
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on Oct 27, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
62
Questions
0
Helped
27467
Points
158
Find the transmission it either goes on the top or the bottom, find a plug, and then remove it and put 90 wght oil and you'll be fine
Hello, I have a 2010 lexus RX350 how do I locate the transmission fluid dipstick to check the fluid level and also steering fluid reservoir?
There isn't one.
Our research indicates that your vehicle does not have a transmission fluid dipstick. These types of transmissions are designed to be maintenance free. In order to check the transmission fluid, your vehicle likely has check valve on the bottom of the transmission on the bottom of your car.
Transmission Fluid Level Check Lexus RX350 (2010-2015 ...
Steering Fluid
https://www.google.com/search?q=2010+lexus+RX350+steering+fluid+reservoir
and finally, your 647 page Owners Manual
Owner's Manuals ' Get to Know Your Lexus ' Lexus Canada
https://www.lexus.ca > lexus > manuals
Owner's Manuals are available online for the majority of vehicles manufactured in 2008 or later. If you don't find the manual you are looking for or you have ...
2010 Lexus RX350 - Owner's Manual - PDF (647 Pages)
https://carmanuals2.com > lexus > rx350-2010-owner-s...
2010 Lexus RX350 - Owner's Manual (647 pages). Posted on 5 Feb, 2016 by Gefitz. Model: 2010 Lexus RX350. File size: 6.1 MB. Other 2010 Lexus RX350 ...
Were is the transmission pull stick located and were do I add fluid and what type? On my 2010 Equinox LTZ
No trans dip sticks on late model vehicles. Have to check by removing a plug on the transmission
1helpful
2answers
Carnival. Where is transmission fluid filler?
Adam; check your 2016 KIA Carnival owners manual, anything I found says it should be like link below.
PRESS THE HELPFUL BUTTON
Add Transmission Fluid 2006 2014 Kia Sedona 2010 Kia Sedona LX 3 8L V6
Where do you add the transmission fluid for a 2010 chrysler town & country on the engine is it where it says dealer only
The automatic transmission dip stick and filler tube have been removed from many later model auto transmissions now so you cannot check fluid levels yourself or add fluid easily to these units.
I assume you have the V6 engine and if you check the engine bay you will find no transmission dip stick and filler tube there. In these cases you have to add fluid by pumping fluid in after removing a filler plug on the case of the transmission from under the vehicle and it needs to be perfectly level when this is done.. There is a specific procedure for this which varies from unit to unit because you need to ensure the transmission is not over filled.
Unless you know what you are doing and use the correct filling procedure this is not a do it yourself task and it is best done with the car perfectly level up on a workshop lift/hoist.
1helpful
2010 Epic. Where is transmission dipstick?
How to check your Transmission Fluid Level - YouTube
? 1:12
https://www.youtube.com/watch?v=zqwbRNQLfSI
Oct 14, 2010 - Uploaded by Robert Callahan
How to check for the proper transmission fluid level. ... Uploaded on Oct 14, 2010. How to check for the proper transmission fluid level ... Then, turn the car off and locate your transmission fluiddipstick. Different cars have ...Missing: epic's
sv6 no transmission dipstick??? :S - Just Commodores
forums.justcommodores.com.au/...holden.../127200-sv6-no-transmission...
Feb 5, 2010 - 5 posts - ‎2 authors
... ive had my sv6 for about 4-5 months now, and i never realised it doesnt have adipstick to check transmission fluid wtf?? my 89' vn has one. ... Just Commodores -Holden Commodore Discussion Forum ... 05-02-2010, 12:07 PM #1 ... As mentioned the 5L40 box in the SV6 & Calais is a sealed unit, so no trans dipstick.
Auto transmission oil DIPSTICK
Dec 23, 2011
Checking 6 Speed Transmission Fluid - Just Commodores
Jun 9, 2011
Too much tranni fluid in my Transmission - Just ...
Mar 25, 2011
4hdd 4L60E - death rattle?
Nov 23, 2008
More results from forums.justcommodores.com.au
Missing: epic's
2010 F150 power steering fluid leaking from the cooler/AC condensor. Is there a recall on this? Very common problem
If the A/C is OK, just add an aftermarket transmission cooler for the power steering. Saves lots of money.
I have a 2010 Hyundai Tucson, where is the stick located to check the transmission fluid. I see where to add the transmission fluid, but what I don't see is (not even sure if I am looking for the correct...
Some of those motors don't have a dipstick.It can, and should, be checked at the level/fill plug underneath.Just another way to get you to take it to the shop at 100.00 dollars a hour..lol
How to check transmission fluid 2010 lexus rx350 fwd
to check transmission fluid in a 2011 lexus rx 350 fwd there is no dipstick, but the transmission is not sealed as the dealer will tell you, thats a gimic for you to bring youre car to a dealership!
simply remove the drain plug from the transmission on the main bottom, the fluid will not come out, there's another fluid retaining plug above that!
next the fluid add hole is on the side of the transmission behind the driver side wheel towards top of transmission!
you simply add fluid whether you pump it in or snake a rubber hose off of a funnel, when the fluid is full it will come by the bypass plug and leak out the drain hole, at this point that's the correct amount of fluid!
simply re install the drain plug and the fluid add plug and you're done!
cost me $100 at a transmission shop to find this out yesterday
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
