Installed new ink.printer will only ptint file://c;/usersdonappdatalocal emplowvxoi202rhtm at the bottom of the page.
bhaigi
  • 21 Answers
SOURCE: I have installed a lexmark
plese reinstall the driver and chek power cable and data cable
i hope its working otherwise imhere
Posted on Apr 24, 2008
  • 21 Answers
SOURCE: Newly Installed 7680
probably you did nothing wring, I seen a few of these cartridges leak - HP should replace the machine if the damage was caused by original cartridges.
Posted on May 12, 2008
rajak2009
  • 527 Answers
SOURCE: printer seems to be out of ink. installed new ink
Sir,
check these 2 links and go through the sites....
link 1
link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on May 09, 2009
don_farr
  • 1011 Answers
SOURCE: printing blank pages
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Dec 09, 2009
Testimonial: "thanks for the tips, it is manufacturer ink so i'll just give them a call thank you"
  • 39 Answers
SOURCE: printer saying wrong ink cartridge
see canon mp150 solved error e5.
Posted on Jun 23, 2010
Cant find instructions to print off how to use in English
Using a printer even basic printer is extremely easy to do. There are many different models of printers out there. You have your very basic to your all-in-one printer. The printer with everything on it works pretty much just like the regular printer you just have a lot more buttons to push.
Make sure that your printer is hooked up properly before using it. If this is a brand new printer then it will go through a check and print out a test page for you. A lot of different times you can just turn it on, you will hear the ink moving around. Something might come up on the computer telling you that the printer is on and working properly.
Open the page you want to print. If you are on the Internet and want to print something from there. All you have to do is go up to file, then down to page set up. This will give you more printing options to choose from. When you are done setting up the page you can verify you have the right printer hooked up by clicking on "Printer" at the bottom. Once everything looks good click on "OK" and now your page should print out.
Open up a ".doc" file if that is where your page is that you need to print. When you are ready to print go up to "File" and "Print Setup". Again you can choose how you want your page to look, and check and make sure the right printer is installed. If your page is set up the way you like it you can just click on the printer icon on the tool bar or go to "File" then "Print."
Using a printer a lot over time will start to wear down your ink supply. Some models of printers let you know when your ink supply is getting low. If you have an older printer you will just have to go by what the printed page looks like. If it is very worn and faded then it is time to install a new ink cartridge.Go to this site www.knox.edu.com and www.openprinting.org
Oct 27, 2012 | Office Equipment & Supplies
How do I replace empty ink cartridges?
Detail instructions can be found at the following site,
http://files.support.epson.com/htmldocs/rx680_/rx680_00ug/wwhelp/wwhimpl/common/html/wwhelp.htm?context=Epson&file=sprx680.1.123.html#1082936
After arriving at the page, click on " Remove and Install Cartridges " link at the bottom of the page.
Shortly after clicking you will be taken to the Instructions page, everything you need to know to
replace the ink will be carefully explained to you.
Feb 25, 2011 | Epson Stylus RX680 Color All-in-One InkJet...
I have lost instruction leaflet and do not know how to operate printer
1. Using a printer even basic printer is extremely easy to do. There are many different models of printers out there. You have your very basic to your all-in-one printer. The printer with everything on it works pretty much just like the regular printer you just have a lot more buttons to push.
2. Make sure that your printer is hooked up properly before using it. If this is a brand new printer then it will go through a check and print out a test page for you. A lot of different times you can just turn it on, you will hear the ink moving around. Something might come up on the computer telling you that the printer is on and working properly.
3. Open the page you want to print. If you are on the Internet and want to print something from there. All you have to do is go up to file, then down to page set up. This will give you more printing options to choose from. When you are done setting up the page you can verify you have the right printer hooked up by clicking on "Printer" at the bottom. Once everything looks good click on "OK" and now your page should print out.
4. Open up a ".doc" file if that is where your page is that you need to print. When you are ready to print go up to "File" and "Print Setup". Again you can choose how you want your page to look, and check and make sure the right printer is installed. If your page is set up the way you like it you can just click on the printer icon on the tool bar or go to "File" then "Print."
5. Using a printer a lot over time will start to wear down your ink supply. Some models of printers let you know when your ink supply is getting low. If you have an older printer you will just have to go by what the printed page looks like. If it is very worn and faded then it is time to install a new ink cartridge.
Printer Help
Nov 11, 2010 | Office Equipment & Supplies
New catridges but now not ptinting. Makes same
double check and make sure that the chips part of the ink is not covers and that the plastic cap is off too. Is the printer saying it has ink in it now or still saying it is empty?
Jan 10, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Bottom of line missing
First try and go to page setup under file and set your bottom and top margins to .25. is every bottom half line faded? If so then yes you might need a new ink cartridge.
Aug 12, 2009 | HP Deskjet 6980 InkJet Photo Printer
Printing but blank pages coming out .
Take the ink cartridge out of the printer. On the bottom of the cartridge, there's a copper/gold surface with bumps and holes. Take a napkin or peice of paper and rub it on this surface. This serves two purposes - if there's any dried ink or blockage, it will help clean it, and it's a test to see if there's any ink left in the cartridge. On a normal ink cartridge, rubbing paper on the bottom would cause some ink to smear onto the paper. If nothing wet comes out, the ink cartridge is dried out or empty. You'll need to replace it.
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Cannon pixma ip 3000 ink jet printer
Go here: http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Select the drop downs for Printer, Pixma iP Series, ip3000
On the next page, select the Drivers & Downlaods tab. Use the drop down box to select your OS (operating system).
In the Drivers box, click on the red link. On the new page, if the file name ends in "exe", there should be a checkbox near the bottom to select Automatic Installation Option. Check that and hit the I Agree button.
Hope that works for you.
Oct 20, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
12 people viewed this question
jasbo
jasbo
