Question about Miele CVA615 Espresso Machine
My brewunit is blocked
Message reads brewunit is blocked. The unit will not come out nor will it run.
    Problem Solver:
  • 9 Answers
Coffee fines and mineral scale build up in the brew unit filters and also in the creme valve. The pressure to pump water through the unit fails and the flowmeter tells the electronics that no water has flowed, it in turn stops all processes and displays "brew unit blocked" message. If you're handy, call Miele tech support. The'll walk you through how to remove the drainage cup screw off the left rear of the brew unit, get the brew unit out and return the gearing to home position. It's a 50/50 chance the gears will return or you will need a service tech to pull your coffee unit out and re-sync the gears to the electronics. That's of course if they didn't break.
This blockage is is prevented only by using the cleaning tablets and descaling tablets. Both need to be used as outlined in the instruction manual.
Posted on Oct 19, 2009
How do I unblock brew unit from Saeco Magic Comfort Plus?
unscrew where is the arrow and take off the brew unit(the block).
Sep 14, 2014 | Saeco Magic Comfort Plus Espresso Machine
Brew unit stuck
Hi molly girl.
You can try to clean your Brewunit. Most of the times when that message appears, it means the brewunit is dirty
You can have more info in the manual if you dont have it:
http://www.miele.co.uk/Resources/OperatingInstructions/CVA%20620.pdf
Jan 11, 2008 | Miele CVA615 Espresso Machine
No matter what I do the Gaggia Titanium espresso machine reads brewunit missing;. This is what I did: I removed the brewunit of the machine to clean it, and reset the N to the correct position on the front...
HI
If the brew unit is in the wrong position when inserted you can knock the lever off the microswitch in the back. If the lever is knocked off you will never get the brw unit miss message to go away. You will have to take the machine apart and replace the lever on the microswitch. Sorry
We made a modification to the brew unit that would prevent this from happening. We modified all the brew units on the compact machines before sending them out so we would never get them back for this reason.
Apr 26, 2011 | Gaggia Titanium Espresso Machine
Display message - brewunit block - can not undo to start the machine Miele CVA 620 Build-in Automatic coffee machine
YOu must turn the machine off...hold both the small coffee and hot water button...tunr the machine on to light...let go of the buttons..then hold in the large coffee button for a few secinds andletgo ..if that doesn't work hold in the medium coffee button for a few seconds and letgo..that shouldreset the brew unit.
good luck
Jan 13, 2010 | Miele CVA615 Espresso Machine
Gaggia Titanium, "Brewunit Blocked"
Check the shower screen in the unit it is possible that it is blocked with coffee oils.
Aug 03, 2009 | Saeco Incanto Classic Espresso Machine
Saeco vienna saying brewunit blocked !
Hi There is a test mode for the Digital and we can see if you have a bad power board. Turn the machine off in back. Push and hold the small coffee button and the menu button (top left) at the same time and while you are holding the buttons turn the machine on. Release the buttons and you should have numbers in the display. If you can push the bottom left button and the machine makes a sound like the motor is moving, turn it off and then back on. If you don't get the message now you should really clean and lube your brew unit.
Jun 05, 2009 | Saeco Vienna SuperAutomatica Coffee...
Hi I have a gaggia titanium coffee machine it has comme up with an error message the the brewunit is blocked i have decalcified machine but no joy can you help
Remove brew unit, If you have the key that came with the machine use it to remove the shower screens and check for blockage.
Mar 29, 2009 | Gaggia Titanium Espresso Machine
Brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
www.cerinicoffee.com
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
BrewUnit Blocked Error
The brew unit sensor may have become disconnected from the main circuit board. If you are very brave, you can UNPLUG THE UNIT, remove the top panel and check that all the wires running into the circuit board are connected.
Otherwise, the sensor may have failed and this will require service.
Mar 15, 2008 | Miele CVA615 Espresso Machine
Brewunit block
kristijordan,
I had this error message on my machine and was able to take care of it by lubricating the brew unit with silicone. I small tube of silicone grease should have come with your machine. If not I found silicone grease at Aco Hardware (not in a tube) and applied it using a toothpick. Machine has been working great since.
Winesnob
Sep 10, 2007 | Miele CVA615 Espresso Machine
Miele CVA615 Espresso Machine Logo
1,116 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
