Question about GE Washing Machines
My washer doesn't agitate or spin, it just drains and fills up
    Scholar:
  • 31 Answers
That sounds like your lid switch. The lid switch on most models of top load washers will be bypassed on fill and drain. As a safety the lid must be closed for agitate and spin.
The lids switch is a pretty easy part to replace and is inexpensive.
Posted on Oct 03, 2009
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
My washer fills, agitates but will not drain
Does your washer spin? If yes, and it doesn't drain it most likely a failed/plugged pump.
If it doesn't spin it could be a belt or timer issue..
Sep 15, 2011 | Maytag MAV2755AWW Dependable Clean Top...
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Will not agitate or spin. Have replaced the belt (was worn) but still wont. Fills fine. When I first put the new belt on I ran it empty (stopped it when it started agitating, moved it to sping, stopped...
Thanks for choosing FixYa and welcome. If you have a washer that has a weak agitation or no agitation at all, here are some possible solutions. You need to check your belts. Most washers have one or two belts. Check your lid switch. If a lid switch is bad, it can cause the washer to not work properly. Sometimes, they will not work at all. Make sure you check your drive motor. The drive motor controls the spinning, draining, and agitation. Most washers have the reverse motor, meaning the shaft rotates in both directions, clockwise and counterclockwise. It is possible to lose one direction and not the other. Some washers have a clutch that controls the agitation. If it is bad or worn, it may prevent the agitator to work. Most of these washers come from General Electric. You could have a bad motor coupler. They are located on the side of the motor drive inside the washer. It is also possible that you have a bad transmission. Check the agitator itself. You could have a bad spline or two. The splin accompanies the shaft and allows the movement of the agitator. If you rule out all the parts above, you may have an electrical issue or an issue with the control board. It is very important to test each part and make sure it is getting power. If a part is not working and not getting any power, the power loss may be the reason that it doesn't work. You can test the current in the wires with a voltage meter. Thank you very much for reading this tip and thank you for using Fixya. As for the spinning, you need to check the lid switch. It may be bad. It may be your motor drive since it doesn't do both. Have you had draining problems?
Feb 23, 2011 | Maytag HAV3460AWW Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
212 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
