Question about Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
Need fuel cap - Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
    Problem Solver:
  • 17 Answers
MY CAR ONLY STARTS WHEN THE FUEL CAP LIGHT POPS UP BRIEFLY
The fuel cap has nothing to do with the starting issue, but the fuel pump may.
May 26, 2016 | 2006 Ford Crown Victoria
What is code PO496 and PO455 for a 2007 Pontiac Grand Prix mean
P0496 is not alisted code.
P0455 - Evaporative Emission Control System Leak Detected Gross Leak (fuel vapors)
Symptoms - Engine Light ON (or Service Engine Soon Warning Light)
- Possible a noticeable fuel odor caused by the release of fuel vapors Possible causes - Missing or loose fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- EVAP canister or fuel tank leaks
- EVAP system hose leaking
- Fuel tank leaking
Jan 24, 2012 | 2007 Pontiac Grand Prix GXP Sedan
I need to know whatpo455 code means
P0455 NISSAN - EVAPorative Emissions Control System Gross Leak Detected. Possible causes - Missing or loose fuel cap (most common)
- Fuel tank leaking (not common)
Nov 01, 2011 | 2001 Nissan Pathfinder
I have a sign says "check fuel cap " what is that mean ,should i take to the dealer
remove fuel cap and reinstall it, tighten for 3 clicks your PCM recognized a small leak in your fuel system usually caused by a loose fuel cap. If the problem persists replace the fuel cap
Jan 01, 2011 | Honda Odyssey Cars & Trucks
My check gas caplight on ,i tight my gas cap
Sound like the seal on the gas cap has failed. You will need to replace the cap.
Dec 26, 2010 | 2005 Ford Focus
I need "step by step" instructions on how to replace the fuel filter on my 2001 Dodge Ram 3500 pickup. Thanks !
Here you go if it is a diesel:
A. FUEL FILTER REPLACEMENT:
The fuel filter is located inside of the fuel filter housing
1. Unscrew and remove fuel filter cap at top of fuel filter housing. To unscrew, attach tool to 6-sided hex center of cap. Do not loosen cap at outer edge. The fuel filter cap is designed to remove filter while pulling up on cap.
2. Remove O-ring from cap and discard.
3. The filter is retained to cap with little fingers. Carefully pry a couple of them off from old filter.
B. FUEL FILTER REPLACEMENT:
1. Thoroughly clean inside of filter housing, cap, etc. with clean diesel fuel
2. Fill filter housing (canister) with clean diesel fuel. NOTE: If you do not do this, you will have to manually bleed air out of system later. No fun.
3. Snap new fuel filter to bottom of cap.
4. Install new O-ring
5. Apply lihgt film of clean diesel oil to cap O-ring
6. Load filter/cap into housing.
7. Tighten cap to 25 ft. lbs. torque. Do NOT over-tighten.
Sep 03, 2010 | 2001 Dodge Ram 3500 Truck
FUEL CAP LIGHT ON
Hi:
The check fuel cap light is tripped when your cap has been loose or off, and the engine is running. Often you need to have the light reset by a code scanner. If you have checked the cap and it is secure, if you reset the code and it comes back, you possibly need a new gas cap.
Nov 25, 2009 | 2006 Honda Accord
How to release fuel pressure to replace fuel filter on a buick rendevouz 2004
if you open up the hood and find your fuel rail you should see a little cap just like what is on your tire valve stems. take the cap off and push the little valve in the center agian just like the valve stem on your tire. be vary carefull as fuel will spray out of this. that is how to depressurize the fuel system
Jul 29, 2009 | Buick Rendezvous Cars & Trucks
My poulan chain saw will not start 42cc 14"bar.
K, I just looked at their site for another reason but they indicate that you need to make sure of the fuel, the on/off switch and also the spark plug (which I have personally seen) and dirty or clogged fuel lines. If you need to view the manual for the troubleshooting you can go to Poulanpro.com or call 1-800-554-6723. Good luck and let me know if you need more help
Feb 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
133 people viewed this question
Top Reddy Measuring Tools & Sensors Experts
jdthefixer
Matt Olenzek
Matt Olenzek
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
