Have a Gateway Laptop bought a new ac power adapter and it is not charging my laptop. The old adapter was working intermitently. dont know if I need a new battery or if something else could be wrong.
I had this problem. It cost over $100 to fix it. It just broke again (a year after being fixed) You can twist the plug in various positions to get a charge. This sometimes takes awhile to figure out, and you will only be able to do that for a couple months before it completely craps out. I read somewhere that the part is $2 and if you buy it and get a computer friend to help, it's a lot cheaper. It's not the adapter, its the female part on the computer. I kept buying chargers, I think I have like 8 now? No difference. good luck.
Posted on Nov 26, 2009
  • 186 Answers
Might be the solder on the jack connecting it to the motherboard . Take it into your local computer shop and have them re solder it unless it is under warranty the i would call Gateway
Posted on Oct 02, 2009
I purchased a new adapter and my laptop will still not charge and work.
Try taking out the battery and leaving the adapter in without the battery. If that laptop powers on then try to put the battery back. It is most likely an issue with the motherboard.
Feb 24, 2011 | Gateway MX6124 Laptop AC Power Adapter...
Gateway wont power up the batt has been failing ,if pluged in the charging light comes on for a while then goes out if you try to start it tries then shuts down. could a bad batt cause this
If your battery is more than 2 years old, then it is a distinct possibility. Every battery type has a certain number of charge cycles (drain->recharge->drain) or time period. Lithium batteries run about 2 to 3 (tops) years. NiMH run about 10,000 charge cycles (or it could be 50,000 cycles if you know what to do). But if you're NOT using the original Gateway charger, then plug it into your laptop and see if it works. The 3rd party charger may have burned out the internal power components over time. In the worst case, you'll have to replace either the motherboard (hope you still have the product key!) or the motherboard's power connector, inside the laptop. At best, you might have to continue using the original power adapter. It will probably turn out to be a worn down battery, which needs replacing.
Feb 19, 2011 | Amstron Gateway P170X Laptop AC Power...
I bought new universal adapter for asus laptop and it charges batery just when laptop is turned off
Problem description: The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause: 1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution: 1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Reference: http://www.chargerbuy.com/blog/battery-charges-only-when-laptop-turned-off/
ASUS laptop AC Adapter
Jan 25, 2011 | Computers & Internet
Describe your Gateway M675 Laptop w/ Pentium4 Gateway M675 won't maintain a charge after charging and the display flicks from ac/dc until the battery is completely empty. Do I need a new battery or power...
Sounds like you need a new power adapter.The M675 needs the correct voltage constantly to work correctly.I'm using one right now and it does the same thing with the wrong adapter or a weak adapter(low voltage).M675 is a great laptop but with the 3.0ghz its got to get the power it needs especially when its under a heavy load.
Oct 26, 2010 | Gateway M675 Laptop
Gateway lt21 netbook not charging
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Sep 13, 2010 | Gateway Computers & Internet
Gateway laptop will not charge battery.
I have a new gateway laptop with windows 7 and today it said plugged in not charging 8%. I tried everything and nothing worked so I turned it off and unplugged it and took the battery out and put it back in and it started charging...hopefully this works.
Jan 09, 2010 | Gateway M675 Notebook
Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Feb 05, 2009 | Gateway Computers & Internet
Toshiba M115 S3094 Battery Probelm
Your battery not able to hold a charge is a bad battery.
Love your precise description & diagnoses. Wish others would describe their troubles as well as you!
Have a great day!
Mar 14, 2008 | HP Pavilion dv6000z Notebook
My laptop battery won't charge
possible when the old AC adapter blew it took part of the power management circuit with it, This is the circuit that detects and charges the battery, I'm not sure whether this a seperate replaceable daughter card or whether it is part of the main motherboard. you will need to investigate this (or send it for a service)
Oct 09, 2007 | Dell Inspiron B130 Notebook
Computers & Internet Logo
166 people viewed this question
David Payne
David Payne
