Question about HP Office Equipment & Supplies
Not able to print. Says that the printer is offline. Have checked the line connection everything is connected.
  • Stephen Wilkins
    Stephen Wilkins May 11, 2010
    try opening the context menu (right click) and selecting 'use printer online'
    Scholar:
  • 53 Answers
please perform the steps below if you are using Windows XP Operating System:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Posted on Oct 03, 2009
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Printer offline checked all connections this happened yeaterday
Hi
How about completely disconnecting it from power and from the PC.
Restart the PC.
Leave it for a few hours and then connect it again.
Feb 27, 2012 | HP Photosmart C5180 All-In-One InkJet...
How do i get my hp1200 printer to print, is on a off line mode
Hi Joy,
Disconnect the printer completely from the PC.Unplug its power cable too.
Reboot your PC.
Connect everything again from scratch but use a different USB port to connect to the PC.Make sure everything is well connected.Try printing now.Cant print?
Under printers and faxes,check whether 'work offline' is checked by right clicking on the printers icon and 'Uncheck.Still cant print?
Uninstall the printer driver on your PC,reboot the PC and install software again.If you don't have the installation disks,install from this Hp Support site making sure you select the driver that corresponds with your Operating System[Windows 7,Vista,Windows XP etc]
Hope this helps.Thanks!
Please rate this answer.
Dec 02, 2011 | Office Equipment & Supplies
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
Aug 07, 2011 | HP Deskjet 6980 InkJet Photo Printer
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still...
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Dec 31, 2010 | HP Deskjet F335 All-In-One InkJet Printer
When I try to print with my HP D4260 printer, it will not print solid colors - everything has banded lines. Can I fix this?
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Deskjet D4260 Printer
My hp g60-549dx notebook connected to hp photosmart 6380
* Hows the unit connected to the computer?(USB cale or Network cable or wireless)
Please get back to us with the above information.
:) Dr Tony
Apr 08, 2010 | HP Photosmart C6180 All-In-One InkJet...
My printer is connected, nut doesnt seem to work
Check whether the printer is in offline. Double click the printer icon in the bottom right of the screen (near time). Or double click your printer in the printers and faxes. Your printer job menu will open. Select printer and check whether use printer offline is ticked. If so, remove it. The another problem is your usb port number may be changed. check it in printer properties.
Jan 08, 2010 | Office Equipment & Supplies
Printer is connected to wireless network but getting offline mess
1st you try to ping the the wireless device ip address if you getting the replay that means your wifi is working fine .check the usb cable also for testing directly install on your pc and check it.
Nov 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer Offline
If your problem still persists then If the printer and the printserver is on and connected to the printserver and the router respectively. Then try right clicking on the printer icon in the printers and faxes window to set it online. Try Printing. If it did not work, then right click on the printer icon again > Properties > Ports > set the proper network port. Apply the settings and try Printing.
Sep 27, 2006 | Lexmark N4000e Print Server
65 people viewed this question
Seeker5211
Seeker5211
