Question about GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher soap dispenser won't open.
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
Posted on Dec 28, 2007
jbjaxiis
  • 95 Answers
SOURCE: GE Nautilus Dishwasher - The soap door is stuck partcially open
Advance the timer, with one hand on the dispenser door. The timer should release the door at times during it's cycle, it may need a little help, but not very hard to turn.
Posted on Jul 06, 2008
whytfang
  • 170 Answers
SOURCE: GE Nautilus detergent cap will not open
Sometimes these get gunked up and need to be coaxed....so take a butter knife...insert it in the edge of the dispenser tray...pry gently...all the while turning the timer control knob...it should pop open at one point if not try a little more pressure...and once open .clean thoroughly..if it persists you may have a timer or control panel issue...also use factory recommended soaps...
I hope this helps...Good Luck and Good day....thank you for rating my effort.....The Fang.
Posted on Mar 28, 2009
SOURCE: Soap dispenser will not open during cucle
The dispenser is opened by a control rod inside the door. There is probably something amiss with this. Remove the back panel on the door and you'll probably see the problem.
Posted on Apr 29, 2009
  • 2976 Answers
SOURCE: Soap dispenser door not opening up
If the soap door doesn't open all the time, remove the outer door cover and remove any obstructions. There are pieces of styrofoam and cardboard inside the door that come loose from time to time, and prevent the linkage from operating freely. They can be re-glued OR eliminated.
Posted on Oct 18, 2009
Soap dispencer door dosnt seem to be opening at the right time. i find the soap undisolved in the bottom of washer, and dishes are not clean.
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 09, 2011 | GE Nautilus 24" Built-in Dishwasher
My dishwasher is not running when you turn the knob it will open and close the detergent
The soap dispenser is openned mechanically by the movement of the knob by the timer. So even when it is unplugged the soap dispenser will open if you turn the knob. Try a different plug. Otherwise check the cord. Next you would check the power supply inside.
Feb 05, 2011 | GE 25 in. Nautilus GSC3400J Free-standing...
Soap does not come out of dispenser and gets hard.
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 19, 2010 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher. Main Soap dispenser still has soap at end of cycle
Raise your hot water temperature to at least 140 degrees, try using FINISH tablets.
Jan 09, 2010 | GE Nautilus 24" Built-in Dishwasher
The door for the soap dispenser is stuck half open even after I ran it thru a couple of cycles
This may or may not be the answer you are looking for but I know with mine the soap dispenser will not close unless the outside dial is completely in the "off" position. Trying turning the dial clockwise very slightly. If you hear a click and it resets the soap dispenser position that should work. Otherwise I have no idea. :)
Aug 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Jun 27, 2008 | GE Nautilus 24" Built-in Dishwasher
GE nautilus soap dispenser "frozen" shut.
you might take door apart and check to see if insulation has fallen on dispenser arms. Ive ran into this alot.
Jan 02, 2008 | GE Nautilus 24" Built-in Dishwasher
Soap door latch won't latch close
Nov 04, 2007 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
120 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
