Question about Fujitsu ScanSnap Manager
Scansnap will scan from 0 to 5 pages then stops
After scanning anywhere from 0 pages to 5 pages (seemingly random number) the scanner stops, the blue LED begins blinking and won't stop. Everything stalls and no sheets feed. Ultimately the operation times out, suggests re-booting the computer, but has no other advice. This scanner worked perfectly at first. I really don't know what has changed to make it so recalcitrant. I've tried downloading software updates from Fujitsu site, but update does not help.
4 Suggested Answers
  • 6 Answers
SOURCE: My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
Posted on Jul 13, 2009
SOURCE: My Fujitsu ScanSnap feeder will not work. The
i have a nokia 8600 luna and i have to transfar data to my pc . need a pc suite for that.
Posted on Jan 21, 2010
SOURCE: Sending E-Mail Failed (0x80004005) - Fujitsu ScanSnap S510
You need to open Internet Explorer and add Thunderbird as your email program. Click Tools > Internet Options > Programs tab > E-mail: Select Mozilla Thunderbird from the drop down.
Posted on Feb 07, 2011
How do I stop the scanner from scanning the blank back of the page?
Somewhere in the settings for the scanner it is set to scan both sides. You need to go into the menu and change to one sided scanning. Another possibility is that you could be putting the document to be scanned in backwards.
Jul 30, 2014 | Fujitsu ScanSnap S1500M Pass-Through...
Scans are coming out upside down
First, are you putting the pages to be scanned in upside down. If not, do so. I sometimes encounter this problem but use the free version of Adobe that comes with the scanner to turn the scanned pages right side up. Hope this helps.
May 28, 2014 | Fujitsu ScanSnap S510
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
Scansnap Scanner stops suddenly when scanning multiple pages and "hangs" for a little while, stating that it's scanning the same page, before giving an error message saying that it is offline. ...
I had this problem happen also and found that it was related to Acronis True Image Home 2011. When this program was uninstalled, the problem went away. I had even rebuilt the Windows 7-64 bit OS and the problem existed until Acronis was again removed.
Nov 11, 2010 | Fujitsu ScanSnap Manager
Scanner will not pull the paper all the way through & scan. Scanner says not valid folder to save image is selected . Set the save folder for the scanned image data. I don't know what to do
Try to scan by using the quick menu as I described below:
Check for the ScanSnap Manager icon on the taskbar.
5d5f1b3.jpg Right click the mouse button over that ScanSnap Manager icon.
Select “Scan Button Settings” from the Right-Click Menu.
2344c41.jpg Select the “Use Quick Menu” check box (it must be checked).
Load the document in the ScanSnap which you want to scan.
Pres the “scan” button on the ScanSnap.
Click the “Scan to folder” icon in the quick menu when scanning is completed.
The “Scan to Folder” dialog box appears.
Check the scanned image in the “Scan to Folder” dialog box.
By clicking save buton, save the scanned data in a specified folder which you select chancing the filename as you want.
Hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Apr 09, 2010 | Fujitsu ScanSnap Manager
How do i delete error pages after scaanning?
I changed the settings from duplex (double sided) scanning to simplex (single sided) scanning under the settings tab in the scansnap organiser. this was ok since i had all one-sided documents to scan. you would need to reverse this settings change anytime you have a double-sided document to scan.
Nov 18, 2009 | Fujitsu ScanSnap S510
PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
May 26, 2009 | Fujitsu ScanSnap Manager
Odd number scanned pages look blue
Are you scanning in Duplex mode? Then cange the settings for the backside. Select Auto mode if available.
S. Mohan, Chennai, India
Nov 23, 2008 | Office Equipment & Supplies
Computers & Internet Logo
228 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
