Question about Refrigerators
The outer jam of the freezer part of the refrigerator gets hot super hot why ?
  • Refrigerators Master
  • 1,606 Answers
Check the fan which cools the compressor ( condensor fan motor ) . You need to pull the refrig out , and remove the back panel to check . Also , make sure the coils under the refrig , are clean of dust , lint , etc . If this fan motor stops , the center strip and the condensor coils will get very hot and the compressor will also get very hot . Not good for the compressor as it could help burning it out .
Posted on Oct 03, 2009
    President:
  • 1,304 Answers
You have the power adjust, summer controls, whatever its called for your model, and manufacture
but its normal, this is the YODA LOOP
or the MULLIAN htr.....
it is very normal for it to be hot to the touch, this is actually the heat that is being withdrawn from your box, in the older models, unless the paint is flaking i would not be overly concerned
Posted on Oct 02, 2009
Why is it hot on all three side
this is how a chest freezer removes the heat from the hot gas,,, it is released through the outer walls of the body of the freezer... this is normal
Oct 09, 2014 | Haier 3.5cf Chest Freezer - White
Why is my maytag msd2657he freezer hot?
That is an interesting question. Hot is a subjective term; are you referring to the inside or outside of the unit. I am not sure but I believe the condenser is part of the outer shell hence it will get warm when operating. Check the thermostat setting in the freezer, it is possible it is off. I wish I could be more help.
Jun 16, 2014 | Amana SXD524VW Side by Side Refrigerator
The top & sides of freezer outer housing getting quiet hot,but only near the door,ps-have the red light alert & rest seems ok,so going to try the defrost stuff.
If you remove the rear panel inside the freezer and examine the evaporator while running you will most times see a few rows of the evaporator with clear ice and the rest will be sweating water droplets. That is what a leak in the Freon will cause and look like. When the door frame gets hot it is sometimes caused by a defective condenser fan or blocked air flow and also reduce cooling. Warm is normal around door frame because you have hot gas flowing there to reduce sweating around doors. I will be here to answer any questions you may have, Thanks Sea Breeze
Aug 22, 2012 | Hotpoint FFA70 Bottom Freezer Refrigerator
Freezer outer shell is hot
If the outside is hot, it is because the condenser is in the skin. It dissipates the heat from the inside and is nothing to worry about. Check all the workings are clean.
Apr 21, 2012 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Outside of freezer is hot to touch
Hi
If the unit was off for a while then more heat is inside the freezer after having it off for a while. That heat gets moved out to your condenser coil. Most freezers today don't have fans to force that heat to the outside air, they run that heat through the outer cabinet and it naturally travels to the cooler surrounding air. If there is no rear cover and no fan motor near that compressor this is how yours is designed. Just give it sometime and it should be fine. However it should be warm to the touch but not so hot you can't. And also depending on how long the freezer is running and how warm it is where the freezer is will affect how hot the outside is. The reason the outside of the freezer is hot is because that's how the freezer releases its heat from the refrigerant. The longer it runs or the harder it has to work the more heat it has to hive off. So unless the freezer is not cooling there is nothing to worry about.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mar 01, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Water in refridgerator interior
You have a plugged drain in the freezer. Unplug and remove back panel in freezer. Under the evaporator there will be ice, thaw with hairdryer or steamer. There is a hole under the ice, that is the drain. Flush with hot water until it drains into outer pan. It may take awhile to get drain cleared.
Mar 20, 2009 | Frigidaire FRT21G3CW Top Freezer...
Refrigerator not cooling
Check to see if your condenser fan is running and not jammed or obstructed. That's the fan which pulls air under the unit and across the condenser coils. Can you feel air movement down there? If it isn't running, then it needs to be replaced. This can cause the hot divider between compartments and generally poor performance because the coils can't get rid of the heat..
Jul 25, 2008 | Maytag Refrigerators
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
